Guide to install pre-outs on an AVR - AVS Forum | Home Theater Discussions And Reviews
post #1 of 68 Old 07-13-2012, 07:01 AM - Thread Starter
WagBoss's Avatar
Does anyone know of a guide to install pre-outs on an AVR that does not have pre-outs? I searched google for hour and couldn't find anything. It seems that it would be relatively easy though.
WagBoss is offline
post #2 of 68 Old 07-13-2012, 07:19 AM
miahallen's Avatar
+1....I'd like to know as well....but this might be more appropriate in another forum.
miahallen is offline
post #3 of 68 Old 07-13-2012, 07:32 AM - Thread Starter
WagBoss's Avatar
I figured that DIY speaker guys would have more experience than the AVR forum :P
WagBoss is offline
post #4 of 68 Old 07-13-2012, 07:41 AM
Bill Fitzmaurice's Avatar
Liked: 4629
With point to point wiring, yes. With an analog volume control (tap it on the input side) yes. With modern electronics, using wave soldered SMCs and VCA volume controls, not easy at all.
Bill Fitzmaurice is offline
post #5 of 68 Old 07-13-2012, 02:41 PM
A9X-308's Avatar
Quoted: 1280 Post(s)
Liked: 951
I've worked in electronics for decades and am confident in most gear, but this is not a job I would willingly take on without a schematic and layout and design will vary between brands and models so anything done will be case specific.
I'd look to find the input to each amplifier channel internally, as that would be the easiest place to take signal from and would be the natural pre out point anyway. If you're lucky, that will be a cable or cables that connect the line level section and power amp boards where you can break out the signal.
Best of luck. Considering how easily an amateur can damage something like this, I'd suggest just buying an AVR with pre outs.
A9X-308 is offline
post #6 of 68 Old 07-13-2012, 09:15 PM - Thread Starter
WagBoss's Avatar
ha yea, i didnt really think about it when I bought it, and i got it for really cheap so meh. I have the rx-v671, which is basically the rx-v667's newer model, and the 667 has pre-outs and the 671 does not. so for a schematic or layout, it should be identical to what the 667 does.
WagBoss is offline
post #7 of 68 Old 07-14-2012, 08:22 AM
petew's Avatar
Quoted: 25 Post(s)
Liked: 68
In a pinch you could build or buy some level converters from the world of car stereo. A quick google found this russound piece.
476
Building Bass - Subs
Surrounds - Easy as Pi
Storage - unRAID unDELL
Mains - Another piece of Pi
petew is offline
post #8 of 68 Old 07-14-2012, 08:26 AM
Liked: 4629
The problem with those is they're slaved to the output level of the amp. Depending on the OPs application that may or not be an issue.
post #9 of 68 Old 07-14-2012, 11:43 AM
MBentz's Avatar
Quoted: 24 Post(s)
Liked: 43
If you're lucky, it's quite possible that they use the same pcb, and just change which components get installed - in which case it's just a matter of adding parts.
That said - even being a professional audio engineer, I think it's more work than just buying the right product. If you got a good deal, it should be easy to break even selling your unit and then not a huge cost to step up to the one with preouts.
Have you ever designed a circuit before, or is this your way of trying to learn? I definitely don't want to discount the hobby side of things...
-Mike Bentz
~It's all about compromise~
MBentz is offline
post #10 of 68 Old 07-14-2012, 11:45 AM
noobzorta's Avatar
Check out the DI4000 by Behringer. I used this to convert the line out from my avr into a pro amp to drive my mains. Worked flawless and didnt add any additional noise that i noted. For about $100 it was perfect to do what i wanted, it was also able to +20db to the sub output to work perfect to drive a pro amp for that as well.
noobzorta is offline
post #11 of 68 Old 07-14-2012, 12:19 PM - Thread Starter
WagBoss's Avatar
I am an electrical engineering student 4th year. so.. yes i have designed a circuit :P
It's actually about $400.00 for virtually the same receiver, but with pre-outs. It's actually ridiculous.
http://www.amazon.com/Yamaha-RX-V671-7-1-Channel-Network-Receiver/dp/B004QR56SE
http://www.amazon.com/Yamaha-RX-V773WA-7-2-Channel-Receiver-wireless/dp/B007JF85SS/ref=sr_1_1?s=electronics&ie=UTF8&qid=1342290294&sr=1-1&keywords=rx0v773
WagBoss is offline
post #12 of 68 Old 07-14-2012, 12:20 PM - Thread Starter
WagBoss's Avatar
Yeah and it's just wasting the all the power through the voltage divider.
WagBoss is offline
post #13 of 68 Old 07-14-2012, 12:21 PM - Thread Starter
WagBoss's Avatar
I'm looking for a cost of... 4 bucks :P I bought some rca chassis mounts for 50 cents each
and that behringer unit you linked is not what I want at all, I do not have a line out on my avr. I want to install a line out.
WagBoss is offline
post #14 of 68 Old 07-14-2012, 01:05 PM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
If it gives you the same result without having the possibility of ruining your AVR then why not?
Processor: Emotiva UMC-200
Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
post #15 of 68 Old 07-14-2012, 01:22 PM - Thread Starter
WagBoss's Avatar
yes, and the post I was commenting on was telling me to buy a line-out amplifier lol.
WagBoss is offline
post #16 of 68 Old 07-14-2012, 01:38 PM
Colm's Avatar
Liked: 94
I'm looking for a cost of... 4 bucks :P I bought some rca chassis mounts for 50 cents each...
Easy part done, then. I think you need to get ahold of the schematics unless you can find someone who has made the change you want to the very same AVR. In days long past, what you want to do was easy. All you had to do was pick up the signal at the output of the volume control. Today it is more complicated. CE manufacturers typically use designs which combine rotary encoding for the volume control, source selection, tone control, volume control and other functions into a single LSI chip. You will at least need to identify the chip and its pinouts to be able to do what you want. Failing that, I guess you can always trace back from the output transistors.
Colm is offline
post #17 of 68 Old 07-14-2012, 03:03 PM
A9X-308's Avatar
Liked: 951
What power?
A9X-308 is offline
post #18 of 68 Old 07-14-2012, 03:27 PM - Thread Starter
WagBoss's Avatar
What power?
what do you mean? most of the power from the signal is being wasted as heat in the resistor in the voltage divider. If I can take the signal before the amplifier then it's not wasting the power of the amplifier as it is not being amplified.
WagBoss is offline
post #19 of 68 Old 07-14-2012, 03:32 PM - Thread Starter
WagBoss's Avatar
can't I just trace the line from the amplifier channels back to the chip... then google the chip pin layout and find where the + out is, and just take a wire off of that to the rca chassis mount?
or even just take it from right before the amplifier for the channel, where the line goes into it?
WagBoss is offline
post #20 of 68 Old 07-14-2012, 04:02 PM
noobzorta's Avatar
The unit takes line-level (speaker out) and converts into line (rca type) output.
post #21 of 68 Old 07-14-2012, 04:09 PM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2574
aren't there high level to line level convertors for about $20?
would this work:
http://www.manventureoutpost.com/products/FUSION-HL%252d02-High-to-Low-Level-Converter-(HL%252d02).html?google=1
btw, i like your initiative, its just that i've never even heard of somebody wiring up their own line level outs to a factory receiver. if you can do it...great!
Listen. It's All Good.
LTD02 is offline
post #22 of 68 Old 07-14-2012, 04:27 PM
A9X-308's Avatar
Liked: 951
I haven't looked at the specs of your AVR, so lets assume 100w/8Ω for a channel which is 28.3Vrms before clipping. The end to end resistance of the voltage divider shown in an earlier post is 4k2Ω. P=V²/R = 28.3²/4200 = 190mW at full power, and lower most of the time.
In a class AB amplifier, which almost all AVRs are, every stage except the output will be class A, so the current draw will remain the same irrespective of signal (or none), so no power saved here, and as shown, only a trivial amount actually dissipated in the output stage and into the voltage divider load.
How does plugging into a pre out (an RCA connector) stop the pre signal from also going to it's respective power amp stage? The pre out and the power amp in are in parallel (in an AVR with pre outs).
Using a voltage divider after the amp is hardly optimal, but it would work and use a trivial amount of power.
There is no guarantee that the chipset doing the VC will be a typical line item like a PGA2310 or CS3318 but if you're lucky it might be. Tapping the signal at the power amp input is what I suggested in post 5.
A9X-308 is offline
post #23 of 68 Old 07-14-2012, 04:41 PM
Kal Rubinson's Avatar
Quoted: 673 Post(s)
Liked: 460
Like this:  http://www.epanorama.net/circuits/speaker_to_line.html
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
post #24 of 68 Old 07-14-2012, 05:56 PM
Colm's Avatar
Liked: 94
Of course you can reverse engineer if you want.
FWIW a simple voltage divider, like the one Kal provided a link for, and others have suggested, across the speaker outputs is probably quicker and easier, if not as elegant. There will be very little power wasted because of the large (relative to speaker impedance) value resistors used. By using high value resistors, we limit the current, and thus the power loss. The high impedance input of whatever downstream device you add takes almost no current to drive. It just has to be the right voltage.
Colm is offline
post #25 of 68 Old 07-14-2012, 08:15 PM
LTD02's Avatar
Liked: 2574
"Like this"
neat! that looks simple enough.
LTD02 is offline
post #26 of 68 Old 07-14-2012, 08:27 PM
Liked: 4629
what do you mean? most of the power from the signal is being wasted as heat in the resistor in the voltage divider..
Not if the resistors are a high enough value, which they must be to adequately reduce the voltage. Besides, if they did dissipate a lot of power they wouldn't be half watt resistors.
post #27 of 68 Old 07-14-2012, 09:35 PM
MBentz's Avatar
Quoted: 24 Post(s)
Liked: 43
Did it work? :P smile.gif
I guess if your time is worth less than $400 then it's worth exploring. It shouldn't take too long to reverse engineer a schematic of what's in your AVR - which is where I'd start. I would be very surprised if you could find a node to just tap off and wire directly to an RCA output and work well enough to sound better than the speaker level converter. Gain structure and output impedance would be two areas of greatest concern...
-Mike Bentz
MBentz is offline
post #28 of 68 Old 07-14-2012, 09:40 PM
MBentz's Avatar
Quoted: 24 Post(s)
Liked: 43
900ohm output impedance is pretty high for a line level signal - I would try to scale the resistor values back so that the shunt resistor is more like 100ohms. Also, it's not uncommon for speaker amplifier stages to have a little DC offset - I personally would add a series cap to prevent any potential offset from transferring down stream.
-Mike Bentz
MBentz is offline
post #29 of 68 Old 07-14-2012, 09:53 PM - Thread Starter
WagBoss's Avatar
so... there is no disadvantage to just use a voltage divider? Since I already bought RCA chassis mounts, mideswell build my own line-level converter instead :P So I'd use just a 1k and a 100 ohm resistor as the divider... or a 4k and 400 ohm? Should I just grab some 1 W resistors to be safe or would 1/2 be fine?
or should I do what http://www.epanorama.net/circuits/speaker_to_line.html says and do a 33k ohm to 1k ohm as its possible for my receiver to output 105 wpc?
Or the best bet seems to be like a 10k and a 470 ohm..?
WagBoss is offline
post #30 of 68 Old 07-14-2012, 09:56 PM - Thread Starter
WagBoss's Avatar
so the behringer DI4000 will take a speaker-level out and convert it to balanced line-level outputs? Or does it only take line-level outs? It looks like it only takes line inputs, but it says it takes up to 3000 watts per channel into it?
is there any advantage to use this over just a standard voltage divider? other then the fact it has balanced outputs.
WagBoss is offline
