Converting "Book-Shelf" speakers into "In-Wall" speakers? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-13-2012, 04:49 PM - Thread Starter
EpicVegas's Avatar
I wan't to convert my Sony Floor & Book-Shelf speakers into In-Wall speakers, is this possible? They are too bulky for my home theater room.
The Speakers:
Front Center Sony SS-F6000
Front L&R Sony SS-CN5000
Rear L&R Sony SS-B1000
EpicVegas is offline
post #2 of 5 Old 07-13-2012, 06:03 PM
JimWilson's Avatar
Quoted: 1268 Post(s)
Liked: 1567
Define "convert". Do you mean remove the drivers from the current enclosures and bolt them to the wall? If so, I would contend that to be a bad idea. It's not what those drivers were designed for, and I suspect they would sound very bad if you did that.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is offline
post #3 of 5 Old 07-14-2012, 04:00 AM
BrokenCrank's Avatar
This article explains baffle step and even discusses something similar to what you propose: http://www.salksound.com/wp/?p=42
Mounting the drivers in the wall will be the easy part...but the result may not be what you want acoustically. A redesign of the crossover will likely be in order. If this is not something you are prepared to do, perhaps selling the speakers you have will generate some funds to replace them with speakers designed for in wall use.
BrokenCrank is online now
post #4 of 5 Old 07-14-2012, 07:18 AM
Bill Fitzmaurice's Avatar
Liked: 4640
True, if the original crossovers incorporate baffle step compensation. IME most speakers do not, especially at this price point. But I wouldn't mess around with the cabs in any event. If the OP must do so I'd cut into the wall to inlay the speakers as much as possible and that's it.
Bill Fitzmaurice is offline
post #5 of 5 Old 07-14-2012, 12:30 PM
WagBoss's Avatar
cut a hole in the wall and just stick the bookshelf in :P
WagBoss is offline
