Help with toning down a tweeter and porting speakers I built - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-16-2012, 09:03 PM - Thread Starter
tagaiz's Avatar
I just finished building a pair of speakers in this thread. The tweeter is much more sensitive than the woofers which I was expecting but I need to tone them down quite a bit. I was thinking about adding a 3.5-4 ohm resistor to the tweeter but if I did that wouldn't that affect the crossover? Is there any way to add the resistor to the crossover without having to redesign the crossover? I'd rather not use an L-pad either. I also need help porting the speakers. I didn't even think about running them ported when I was building them but having listened to them I feel they would benefit from being ported. They're roughly 9.75 liters and I was thinking about tuning them to around 60hz so a port around 1.75x4 would work well wouldn't it? Thanks for any help.
tagaiz is offline
post #2 of 5 Old 07-16-2012, 09:12 PM
omegaslast's Avatar
omegaslast is offline
post #3 of 5 Old 07-16-2012, 09:35 PM - Thread Starter
tagaiz's Avatar
Originally Posted by omegaslast View Post
www.minidsp.com
I use one of those in my car and I love it but that's not really what I'm looking for.
tagaiz is offline
post #4 of 5 Old 07-16-2012, 11:05 PM
Nardokor's Avatar
The only way to change the sensitivity of a speaker without having to redesign the crossover is an L-pad. If you were to just add a resistor in series with the tweeter, the crossover will behave differently.
Nardokor is offline
post #5 of 5 Old 07-17-2012, 01:53 AM
A9X-308's Avatar
Quoted: 1364 Post(s)
Liked: 1022
1: Insert L pad
2: Adjust until satisfied
3: Remove L Pad and measure the two resistances
4: Substitute in 2 fixed value resistors the same as you measured from the L pad for the final setting.
A9X-308 is offline
