Phantom center with constant direcitivty speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 35 Old 07-19-2012, 02:19 AM - Thread Starter
omegaslast's Avatar
Using QSC K12 i have no desire to go back to using a center channel.. just wondering who has used waveguide speakers with a phantom center and experienced the same thing.
imagic likes this.
omegaslast is offline
post #2 of 35 Old 07-19-2012, 03:35 AM
kgveteran's Avatar
Quoted: 487 Post(s)
Liked: 178
I've done a number of installs where i choose not to use a center and have gotten great results.... Pesky neighbors visiting dont quite get it, but the sound was great..
kgveteran is offline
post #3 of 35 Old 07-19-2012, 05:00 AM
Maxjr's Avatar
I have been running a pair of 4Pi's for half a year and also have no desire to use a middle channel. Speaker setup is so much easier not having to worry about that pesky center channel.
Maxjr is offline
post #4 of 35 Old 07-19-2012, 05:31 AM
Mark Henninger
imagic's Avatar
Quoted: 6596 Post(s)
Liked: 11344
Assuredly. I have a pair of B-52 LX-1515 as my mains with a phantom center, it is the absolute clearest sound. I will never use a center channel again. For the longest time I was happy with two channels handling the whole show, but now I run a 4.1 system. Every attempt to go back to 'conventional' speakers results in unhappiness. I'm sold on phantom center with waveguide compression drivers.
Mark Henninger, Senior Editor at AVS Forum
imagic is offline
post #5 of 35 Old 07-19-2012, 08:20 AM
noah katz's Avatar
Quoted: 1107 Post(s)
Liked: 387
Same here, works fine.
It's great to get the millstone of a center channel off the neck, what with its too-low position, early reflections from floor and screen, and need for more amp channels if using external amps or biamping.
I have 18Sound 12ND710 + BMS 4552ND/XT1086 with lots of toe-in, will be replacing with JBL 2206 + SEOS12/360
Noah
noah katz is online now
post #6 of 35 Old 07-19-2012, 11:13 AM
bwaslo's Avatar
Quoted: 68 Post(s)
Liked: 188
Ditto. I've done it with dipoles, econowave variants and Synergys. Haven't noticedany need (but then, didn't try to compare with a real center)
___________________________________________
DIY Synergy horn spreadsheet Synergy horn spreadsheet and pdf
XSim -free crossover designer and simulator XSim install file
Easy and cheap sound diffusers (the "Depot Diffusers") making easy DIY depot sound diffuser-panels-step by step.html
SmallSyns - point source controlled directivity in a manageable size SmallSyns
bwaslo is offline
post #7 of 35 Old 07-19-2012, 11:38 AM
beastaudio's Avatar
Quoted: 4147 Post(s)
Liked: 3504
removing the center will compress the signal down obviously, to send the info to the L/R. I noticed a difference in sound at times without the center but with a pretty broad listening area, I had trouble pinning down the center image across them. It was great at the MLP, but couldnt get it close anywhere else. The big question is, does this compression of the signal to downmix the center's info cause any issues?
beastaudio is online now
post #8 of 35 Old 07-19-2012, 11:54 AM
Mark Henninger
imagic's Avatar
Liked: 11344
Sure a center channel is likely a good idea if you are showing to a crowd, but for 2-3 people phantom center seems to image well enough. Then again the specific horns in use probably affect this, with more directional horns projecting a more accurate image within a smaller listening area and vice-versa with wide-dispersion tweeters. I'm curious what speakers you are using. Here's a picture of mine, B-52 LX-1515...
imagic is offline
post #9 of 35 Old 07-19-2012, 01:26 PM
desertdome's Avatar
Quoted: 1330 Post(s)
Liked: 1523
There is no data or dynamic range compression when moving the center to the L/R so I'm not quite sure what you are talking about. If there is an issue, we wouldn't be able to use bass management and combine 8 signals together. This is no different than combining the multiple channels in a digital audio workstation when mixing music or movie audio.
There is a reduction of 3 dB to the center channel before it is combined with the L/R, but that won't make any noticeable difference in quality.
High Impact AV
desertdome is online now
post #10 of 35 Old 07-19-2012, 05:56 PM
noah katz's Avatar
Liked: 387
I wouldn't call it compression; downmixing at most.
I don't think mixing the center into L/R is in any danger of harming the signal quality.
Is this with constant direcitivty speakers?
If so, have you experimented with toe-in?
Noah
post #11 of 35 Old 07-19-2012, 06:23 PM
LTD02's Avatar
Quoted: 2553 Post(s)
Liked: 2888
hey omega, lots of folks are in your camp. it works, so just enjoy.
Listen. It's All Good.
LTD02 is offline
post #12 of 35 Old 07-19-2012, 08:51 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5972 Post(s)
Liked: 5035
Not sure how it works on today's modern AVR's but back not long ago it was known that Dolby decoders would apply dynamic compression when or if the center channel and/or subwoofer channel was not used.
Scott Simonian is offline
post #13 of 35 Old 07-20-2012, 08:14 AM
desertdome's Avatar
Liked: 1523
I use an HTPC and forgot about that. I never could figure out if it was tied to the decoders or just to the receiver offering Dolby Dynamic Range Compression. I think for some receivers it still happened even when decoding DTS-HD.
High Impact AV
post #14 of 35 Old 07-20-2012, 10:17 AM
beastaudio's Avatar
Liked: 3504
Signal compression, that is what I am getting at. As Scott suggested above, this WAS the case, if it still is, I dont know. DD you are correct about bass management, but Dolby has taken this into account while at the same time assuming one would use a center channel as well. When removing that, the decoder has to RE-compensate for a channel not being there and that is when artifacts and issues can come about.
Noah, this was with JTR t-12's, so not horns, and could have been part of the problem.
I will say after stating all the above that I preferred a phantom center setup myself before I got my A-T screen and the triple 8 for the center. When before I had major issues with any center keeping up (obviously) and placement as it was basically on the ceiling above the screen.
post #15 of 35 Old 07-20-2012, 12:00 PM
noah katz's Avatar
Liked: 387
Yikes
Ah, AT screen is another story.
I'm just not willing to give up the gain and other advantages of my Hipower.
Noah
post #16 of 35 Old 07-20-2012, 12:25 PM
beastaudio's Avatar
Liked: 3504
post #17 of 35 Old 07-20-2012, 02:00 PM
A9X-308's Avatar
Quoted: 1506 Post(s)
Liked: 1142
I've used phantom centre for years with horn/CD based speakers and direct radiators (KEF 104/2). For a brief time I used a KEF coax centre with the 104/2, but found the difference trivial.
Re DD signal compression with no centre: I've read this is so, but seen no actual evidence so far beyond assertion that this is the case.
As I don't use the internal amplifiers it's moot for me anyway, as I simply mix the C into L&R at line level post AVR.
“You are not special. You are not a beautiful and unique snowflake.” Chuck Palahniuk
A9X-308 is offline
post #18 of 35 Old 07-20-2012, 02:15 PM
Bass Enabler
Liked: 5035
post #19 of 35 Old 07-20-2012, 02:24 PM
A9X-308's Avatar
Liked: 1142
I did it as a 'just in case' rather than compelled by evidence. Considering what I was building anyway, it added 2 resistors and a connector, so less than $1 and 10 minutes work. Better than finding out the compression is actually correct and having to add it later.
A9X-308 is offline
post #20 of 35 Old 07-20-2012, 02:37 PM
Bass Enabler
Liked: 5035
post #21 of 35 Old 07-20-2012, 03:12 PM
MarkHotchkiss's Avatar
Liked: 85
Hi A9X-308,
. . . Considering what I was building anyway, it added 2 resistors and a connector, so less than $1 and 10 minutes work.
Can you explain how you did it? I did it with 4 op-amps and some resistors, because I was afraid of causing cross-talk between left and right. It was a pretty brute-force approach, and I thought that there had to be a better way.
MarkHotchkiss is offline
post #22 of 35 Old 07-20-2012, 03:32 PM
A9X-308's Avatar
Liked: 1142
Standard inverting audio mixer using an opamp (in my case a hybrid forced class A LM4562). Feed C into summing node of L and R opamps via selected resistor to get it to -3dB.
The Land R opamps were already in place to feed signal to the modified DCX, so all I needed to add were the additional resistors, a short length of cable and an RCA.
A9X-308 is offline
post #23 of 35 Old 07-20-2012, 04:34 PM
Liked: 85
Thanks, A9X-308, now I see. Having some of the opamps in place makes it a little simpler.
What I thought was awkward with my circuit was that I used two opamps to buffer the center channel, one to drive left and the other for right. I was trying to avoid any resistor path between the left and the right where crosstalk might occur. Each of those two opamps scaled by one half, while the left and right buffers were 1:1. I then summed with resistors.
But back on topic:
Can someone explain what is meant by "constant directivity speakers"? This thread makes it sounds like it is important to getting a good phantom center, but I have no idea why.
post #24 of 35 Old 07-20-2012, 05:13 PM
mtg90's Avatar
Quoted: 488 Post(s)
Liked: 961
Bill Waslo wrote this very good article on them:
Setup of Controlled-Directivity Waveguide Speakers
mtg90 is offline
post #25 of 35 Old 07-20-2012, 06:18 PM
A9X-308's Avatar
Liked: 1142
You could do it with 4 resistors and no opamps. I needed the opamps to get the correct gain structure and drive for the low Zin of the ADC
Crosstalk is not really an issue, as you can get very good imaging from an LP with frequency dependent CT usually no better than 30dB down.
A9X-308 is offline
post #26 of 35 Old 07-20-2012, 11:37 PM - Thread Starter
omegaslast's Avatar
very interesting discussion going on, i heard about the compression issue on receivers as well.. and that only certain high end receivers bypass dolby to do the phantom center mixing outside of that processing.
That was a while ago.
Main reason i brought up this subject is a lot of people bring up in the SEOS thread ordering 3, or struggling with what theyre going to do with their center channel, and frankly i just dont see the point of dealing with it having heard some proper waveguide speakers.
post #27 of 35 Old 07-21-2012, 05:14 AM
Mark Henninger
imagic's Avatar
Liked: 11344
It all depends on the surround processing being used, but in a nutshell Dolby EX is much more flexible and capable than Dolby Pro Logic. Since it is a newer technology, once upon a time it was only available of high-end receivers.
imagic is offline
post #28 of 35 Old 07-21-2012, 01:18 PM
MoFinWiley's Avatar
I am heavily considering a phantom build for my new living room. (SEOS12 w/deltalites) smile.gif
I cant seem to find any REAL data on the compression aspect for all of the newer codecs. Unfortunately it seems like Dolby no longer offers the same kinds of detailed engineering write-ups like they used to. Their website is just filled with marketing nonsense now.
MoFinWiley is offline
post #29 of 35 Old 07-21-2012, 08:30 PM
noah katz's Avatar
Liked: 387
Originally Posted by Roger Dressler View Post
Because AVRs have to support phantom center regardless of the source codec, Dolby, DTS, PCM, that is all done downstream of the decoder. So there is no compression from the DD decoder. It does not know that any downmixing is being done.
Noah
post #30 of 35 Old 07-23-2012, 04:03 PM
Bone215's Avatar
why doesn't somebody ask dolby
deeper than the deepest ocean
Bone215 is offline
