LMS-R 15 in 6 cubic foot box, setup in room - AVS Forum | Home Theater Discussions And Reviews
post #1 of 29 Old 07-19-2012, 10:10 AM - Thread Starter
mikeciccarelli's Avatar
So I made a couple of posts and have done some more research regarding my basement home theater setup with the LMS-R 15" sub.. Right now the sub is tuned to 20 Hz and the output is "ok" but I'm thinking I should be able to get more out of it. More meaning I have too many nulls/void/modes in the room. I really can't move the sub anywhere else in the room as it is pretty large in size (the sub) and I want to keep it up front. Also I have more than a couple of listening positions for friends and family.
I downloaded Room EQ wizard and did some testing.. Should I post the waterfall output? Anything else? I can calibrate the soundcard but I can't calibrate the MIC as it is the newer Radio shack model and there isn't a file that I know of available for it. Also in my basement it is carpeted flooring with dry wall all around. I also have 2 Areas in the ceiling that hang a bit lower because of the vents being run for the AC in the above rooms. From research I was thinking of doing the following.. maybe someone can add to it?
1) buy another lms-R and use the ep4000 in 2 channel mode for awhile and then add another amp later. Not sure how much later I would add another amp so keep that in mind. Also keep in mind that the additional sub would be kept up front.. I would put one on the left and one on the right side of the center channel (as the boxes fix under the projector screen).
2) add some DIY bass traps.. I'm trying to get a price/quota for oc 705 now (plus it might be a fun DIY project). Was thinking of adding it in the left front corner and also above the listening position to block the parts of the AC vents that hang down...
3) get some sort of EQ... minidsp looks like it would be fun to mess around with but I'm not sure how I feel about buying plugins.. Can minidsp or other EQ's so phase shifts for 2 subs?
thanks,
mike
mikeciccarelli is offline
post #2 of 29 Old 07-19-2012, 10:18 AM
K-Wood's Avatar
What, if any, EQ are you applying now? Audyssey or anything like it? You may get some improvement by playing with the sub's phase setting and/or the distance setting in your AVR, as well as by moving the sub slightly. Can you post your FR and waterfall graphs from REW? That would help as well. While it's true that a second sub can smooth some of the room's modes and nulls, it's worth trying to get the FR as flat as possible with the single sub first. Also, please post your room dimensions (LxWxH).
BTW, you should be fine with the RS meter as a microphone as long as you're focused on the 10-200 Hz range with your measurements.
Ken
K-Wood is offline
post #3 of 29 Old 07-19-2012, 10:18 AM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5302 Post(s)
Liked: 4184
I'd go for all three, if possible. Also, don't use OC705 for "bass traps". It's too dense. I'd make some panels with R-19 or something that is similarly soft and fluffy. Yes, the MiniDSP can EQ and phase shift two different subs. In fact it can for up to four of them, if I am not mistaken.
Scott Simonian is offline
post #4 of 29 Old 07-19-2012, 10:26 AM - Thread Starter
Thanks for the reply Scott! Always appreciated.. .from my reading online a lot of people recommend the oc705 though specifically for bass traps.. I'm all for using R-19 cause I believe you can get that at Lowes and such (where oc 705 has to be ordered from someplace magical it seems)... I'm still learning. I was actually just going to do some testing tonight with cushions to see if it makes any difference at all. Not sure if this is even worth testing (throwing some larger sized pillows in the corner of the room just to get an idea).
I'm really liking the technical aspects of the minidsp but they are based in Hong Kong and do not have any resellers in US. This is all personal preference but I wish someone in the states would carry it and I could call up and order... For 125 or so bucks it seems like it would solve some of the problems...
I guess I could always buy a receiver with XT32 in it.. looks like the onkyo 818 model (which is relatively new as of now) has it built in and isn't overpriced..
Mike
post #5 of 29 Old 07-19-2012, 10:37 AM - Thread Starter
Ken
Ken,
Right now I'm doing very little EQ sub wise. I have a pioneer 1021-K receiver and it does have it's own room correction in but no EQ specifically for bass.. I forget if I can even adjust the distance setting for my sub (I can for the other 5 speakers though). I'll definitely double check tonight. http://www.pioneerelectronics.com/PUSA/Home/AV-Receivers/Pioneer+Receivers/VSX-1021-K/
Right now in its almost finished state the box I would guess weighs around 150 pounds.. so it is a pain to move.. I have tried moving it around the open (open meaning no furniture in the way) front left hand corner and didn't see any better results (actually seemed worse in most cases). I even placed the back of the sub against the left hand side wall so the sub was facing the right hand side, no good.
Also since I'm using a pro-amp and built the sub I'm not sure there is any way for me to adjust or change the phase at all...
I will try to get some graphs posted very soon of my ouput.. I will also try to get some pics of the room up.
thanks,
Mike
post #6 of 29 Old 07-19-2012, 06:35 PM
BassThatHz's Avatar
Quoted: 2034 Post(s)
Liked: 1562
Typically most rooms have 3 to 10 nulls and peaks, ranging from +-5 to +-15db.
Cubic and L-shaped rooms tend to be the worst for room-modes.
There is no room that has none... unless the walls are made of rice-paper and it's located at the precipice of Mount Thor.
Theoretically: +1 cone gives +3db, +1 amp gives another +3db (if they don't cancel each other out.)
The EP4k only has two phase options, in-phase and out (by flipping the wires manually at the terminals, hehe)
Having a good DSP for subs is a "must have" in most rooms.
Yes, post your REW FR. What is your LxWxH?
BassThatHz is online now
post #7 of 29 Old 07-20-2012, 08:51 AM - Thread Starter
The room dimentions are 14x20x8 but in the rear of the room it extends a bit (think L-shaped basement room)..
What are existing options for DSP/EQs/room corrections? My list so far would be
1) new receiver with XT32 (I don't think I want to go with anything less than XT32)... 800 bucks
2) the behinger FBQ2496 .. sort of requires PC as well... (price includes way cheap laptop form clearance bestbuy, 300+120) ... 420 bucks
3) the 400 dollar DSpeaker 8033 anti-mode bass thing.. I checked and the seller in the US listed the cheaper model as out of stock... 400+ bucks
4) minidsp is out as no US sellers of the product. Plus I would need laptop as #2 does..
My laptop I was testing with is just flat out too old (old celeron with 512 meg of memory).. I tried running room eq for linux as well on it and it was still just too slow.. So i'm guessing I need a new laptop for room eq testing..
Any other options?
thanks,
Mike
post #8 of 29 Old 07-20-2012, 10:07 AM
K-Wood's Avatar
Mike: The Behringer Feedback Destroyer can usually be found for less than $100. Before you conclude that you need a new laptop, you might try downloading the Behringer software to see if it will run on your laptop. As I understand it, the EQ is done in the device and the software merely provides a way to set the parameters, which are then loaded into the device.
Alternatively, is your laptop sufficient to run REW? If so, then you can generate the EQ filters in REW and load them directly into the BFD through its MIDI interface. I think you can do the same thing with the FBQ2496 if you decide to go that route.
Plug your room dimensions into Bob Golds Room Mode Calculator here to see where your likely modes and nulls are.
BassThatHz:
Can you explain what you mean? Are you referring to the effect of adding another subwoofer?
Ken
K-Wood is offline
post #9 of 29 Old 07-21-2012, 08:55 AM
Looneybomber's Avatar
Liked: 25
BassThatHz:
Ken
Doubling cone area or doubling power theoretically gains you 3db each. So doubling both power and woofers gains you 6db. In practice though, you will place the subs in different parts of the room to smooth frequency response, so your net gain will never be +6db across the entire bass spectrum.
YID DIY
Looneybomber is offline
post #10 of 29 Old 07-21-2012, 12:23 PM
BassThatHz's Avatar
Liked: 1562
If you are going the Behringer route, don't get a FBQ2496 or a DEQ2496, get a DCX2496 instead. The FBQ and DEQ won't have the all features you will need, like HP/LP XO's, Pre/Post Gain/Delay, and Phase, along with the EQ.
Also you can add up to 6 subwoofers with it, without requiring the purchase of yet another box.
The FBQ is a simplified version (10%) of the DEQ, the DCX has most of what the DEQ has (85%)... plus it adds the aforementioned stuff, which is more critical than optional to us DIY'ers.
The only advantage the MiniDSP has over the DCX is that it has adjustments down to 10hz rather than 20hz; and it can be cheaper... depending on what you need out of it. (Did I miss anything?)
Since you mentioned it, the MiniDSP requires a computer, a DCX does not.
The Anti-Mode is a waste of money IMO.
post #11 of 29 Old 07-21-2012, 02:29 PM
MoFinWiley's Avatar
Mike
Rumor is that PE will start carrying the minidsp "soon"
Steve
MoFinWiley is offline
post #12 of 29 Old 07-21-2012, 08:46 PM - Thread Starter
well I got rew on linux working so i was able to do some tests finally... i have xbmc loaded up on some old hardware... had to hook up old usb SB card cause output is via hdmi... i will post some graphs soon.. took me 3 hours to realize i needed regular java as fedora comes with the icedtea version... initial graphs look flat except < 15 hz it gets a little crazy....
Just an fyi... all xt32 receivers are more than 1400 :-) so i wont be getting xt32... I think i want to get another sub... prolly another lmsr... then get another amp later on... i might wait for minidsp if PE is going to sell it.
post #13 of 29 Old 07-22-2012, 04:48 PM - Thread Starter
Attached is the output.. These were done at -22 db FS sweep level under the calibrate screen... Otherwise I would always go too high on the output...
[ I removed the ROOM EQ graphs as they were wrong.. will update below ]
here is a brief layout of the room.. off to the right hand side would be the steps to go upstairs:
When just using the RS meter I'm getting up to 100 db pretty often with 1 15" LMS-R @ around 12 feet...
post #14 of 29 Old 07-23-2012, 10:09 AM
K-Wood's Avatar
You seem to be getting alot of infrasonic energy in the 5 to 10 Hz region. Is that your sub, or background noise? My guess would be background noise based on the fact that it doesn't decay in the waterfall like the other frequencies.
K-Wood is offline
post #15 of 29 Old 08-06-2012, 12:46 PM - Thread Starter
Well just as an update... I added another lms-r 15" and put it up front to the right of the center channel (see picture above) and it didn't make much of a difference for my specific problem. Having spent a decent amount of 2 subs and pro amp I wanted it to work... I bought the new denon AVR-2113CI.. this seemed to finally fix my problem.
Ultimately I'd like to add another amp, 1 for each sub but really the ep4000 seems to be handling them nicely in stereo @ 4 ohms. I think with the EQ'ing the receiver is doing it doesn't make the amps clip nearly as much.. Yes I could have gone the cheaper route of just an EQ but I was worried it wouldn't fix all the of the problems.. All in all I wish I just would have gotten a receiver with Audyssey EQ XT but this project didn't start out to be where it is today..
I wonder how much there really is to the Audyssey XT hardware/software.. Is it more than just an EQ for the subs? Seems like it..
Mike
post #16 of 29 Old 08-06-2012, 02:32 PM
noobzorta's Avatar
You and i have a similar combo, sans the amp. The 1021k was not able to produce enough signal for my inuke before i changed some eq gain settings. This might be an issue for you? I have a 12in variant in a ported box, and i am able to hit peaks in 120ish pretty easily, along with extension down to 15hz decently.
noobzorta is offline
post #17 of 29 Old 08-06-2012, 03:04 PM - Thread Starter
I bought an art cleanbox II to boost my signal.. I found that with this setup and other setups that I've used proamps in home theater that I needed the art cleanbox pro II... In the past I bought 1 for use in a different room with a crown xls 1500.. In that specific case I was hoping it would helped with the hum (ground loop) I was getting... Note that my amps I use do not have any DSPs (I think the inuke might let you tune "stuff" a bit more).
Couple of notes about cleanbox pro 2
1) Not sure it actually "cleans" up the ground loop hum.. I believe this actually was fixed some other way on my crown xls 1500.. just got lucky. With the ep4000 I had to ground the chassis to get rid of MOST of the ground loop/hum.. I still hear a bit of hum if I really crank the gains (which I don't have to do in most cases).
2) If you buy a cleanbox pro 2 it allows you to boost single to proamps so that you don't have to crank the output signal from the receiver (helpful if you want to use proamps in addition to "normal" all-in-one subs). For both the crown xls 1500 and the ep4000 I have cleanbox pro 2's.
I'm going to do some more testing tonight.. I had to finish up on the 2nd LMS-R box.. At around 10-12 feet from the sub I was getting around 105 db max with 1 15" but I really couldn't "hear" the bass.. It seemed like it was constantly out of phase with a single sub.. With the 2 15's I'm hoping to get a bit more now.. Regardless of the placement, number of subs and art cleanbox the biggest difference was just using Audyssey.. Reading the Audyssey page I could have gotten away wth MultiEQ but went with the Denon that has XT.
thanks,
Mike
post #18 of 29 Old 08-06-2012, 03:43 PM
Point Source
beastaudio's Avatar
Quoted: 3517 Post(s)
Liked: 2834
Couple things, audyssey also sets the delay for your sub to help with the eqing process. Two, the cleanbox pro II will start to roll-off around 20hz or a little below, so get rid of it and go for a more suitable signal booster/converter, or just buy the DCX2496 as others have suggested to get MORE EQ, MORE VERSATILITY, and 24 db's of signal boost should you need it. Running a sealed setup, with those subs, you are capable down to 10hz, dont rob yourself of that last 10hz...
The audyssey xt is def. a step up, and xt32 is an even BIGGER step up. Trust me, ive already done it. went from a denon 2311, to 3311, to now a 4311, as well as a cleanbox pro, to a tiny little eq box, to a berry mic2200, to now the dcx 2496 and the options I get are unreal. the DCX is a bit of a beast to figure out at first, and I actually bought an SMS-1 out of frustration as it REALLY does all the eqing for you, and you can see it on the screen, but alas, i havent decided to give up on the dcx yet, so I may just sell the sms-1.
Some other conversion boxes to check out if you dont want to go that route yet, are the henry matchbox HD, the samson s-convert, or the other that I all have in my back room right now and cant remember the name (maybe the ati mm1100).
beastaudio is offline
post #19 of 29 Old 08-06-2012, 08:32 PM - Thread Starter
at this point the new receiver is running at -12 db so I'm guessing I could just completely ditch the pro II as it adds around 15 db I think max? And right now I have it around 1/2 to 3/4's gain... I should really just get rca to xlr cables and be done with it.. Ultimately it was never not having enough power or signal or low enough bass... it was completely bad room acoustics. I think since I've gone with the new denon I won't need a DCX at all.. just rca to xlr cables...
I built the subs for ported setup.. no plans on going to sealed as I seem to be getting plenty of <20 hz material.
On that note.. where can I buy rca to xlr cables.. hoping they may help with the ground loop. I heard monoprice got hacked awhile back so I'm on the fence of buying from them...
thanks,
Mike
post #20 of 29 Old 08-06-2012, 10:13 PM
Point Source
beastaudio's Avatar
Liked: 2834
thanks,
Mike
stay on the fence, look elswhere for rca-->XLR cables. I got two seperate lots and neither of them were wired properly. Check on amazon for another supplier. I would tell you where i got mine if I remembered tongue.gif
post #21 of 29 Old 08-07-2012, 01:25 AM
BassThatHz's Avatar
Liked: 1562
Inverse square law says that a sub doing 117db at 3ft will do 105db at 10ft. Everytime you double the distance you have to subtract 6db. So going from 3 to 6ft is -6db (111db), going from 6 to 12ft is another -6db (105db).
Adding a second LMS-15 and a second EP4k would give you 108db, assuming zero loss.
I have 9 subs powered by two EP4k's and an iTech8k, and I average about 120db at an LP of ~10ft. (Closest subs are 3ft, farthest subs are 15ft.)
I figure that if I buy 3 FP10000Q's and add another 9 subs I should be able to squeak out about another 3-5db.
On that note, you really need two types of subs: high excursion for the <50hz stuff and pro-style for the 50-200hz stuff.
One is good for simulating earthquakes, and the other for high-impact events.
Your graphs look fine, but isn't 60db a bit low for taking sweeps? My aging air conditioner is outputing 62db (I just measured it) eek.gif. Shouldn't it be at least 80db for better noise rejection?
The more distortion free the subs are, the quieter it will "appear" to sound, because "sound + noise" is less than just the "sound" by itself;
but your brain is telling you... but I spent all this extra money to get MORE!!!
post #22 of 29 Old 08-07-2012, 08:28 AM
Point Source
beastaudio's Avatar
Liked: 2834
Good points made there by BTH. Lots of folks perceive distortion as louder and better, but once you grow accustomed to distortion-free playback, it is unreal...
Biggest point made though, is that is too low to run sweeps. you ambient noise floor in the room will come into play and you dont listen at those levels do you? You need to run the sweep around the levels you enjoy your music or movies, and go from there. Room interactions wont necessary change, but you will drown out some of the other ambient sounds in the room by running the sweeps higher. In REW youll just need to re-calibrate your spl to accept higher numbers and adjust accordingly...
post #23 of 29 Old 08-07-2012, 08:43 AM - Thread Starter
I agree... I think eventually I will be upgrading my fronts to get some more 100-200 Hz sound... The denon I bought doesn't have any pre-outs so I can't just buy some nice woofers and add.. I have to replace.
I also agree that 60 db was a bit low... Between the ep4000 (I have been thinking of replacing fan or moving it soon.. moving it might be a better option if I get rca-xlr cables) and the projector and yes my AC I'm getting a bunch of background noise... Also these tests were before the Denon so I had no EQing on the low end at all.. because of this I was getting a nasty spike somewhere causing room EQ to max out during my tests (going above the headroom). Last night I was mostly just listening to some music and relaxing a bit after I moved everything back into place.. tonight I will hopfully make up some new graphs and post here (or later in the week)..
Right now the Denon's auto Audyssey setup has it set to 120 Hz for the sub.. I know this is quite high but is it working for the time being. End goal might be to take my current fronts and move them to the rear.. Perhaps I can look into DIY fronts to replace my current Klipsch's.. I'm not the best woodworker and my patience runs thin sometimes (waiting for stuff to dry, DOH). I know PE has a nice kit for the fronts but they seem a bit limited.. I guess I can just buy 2 nicer 12" woofers and go to town on making my own fronts..
thanks,
Mike
post #24 of 29 Old 08-07-2012, 08:53 AM - Thread Starter
Yes... I think I'd like to do the following...
1) move the ep4000 so I don't hear the fan as much.. I don't want to replace fan voiding the warranty.
2) Limited on what I can do with the projector but I may look into options but not really concerned about fan noise.
3) Mess around with Room EQ.. As you mentioned I have to get it to use higher SPL.. I tried to do this but I always seemed to go above the "headroom" when taking measurements. I'll play around with it tonight and try to make up some graphs at a higher db for sure.
I agree that the bass seems to be distortion free but at the same time I still knew something was a bit wrong as I was getting massive bass in certain parts of the room (and very limited parts).. The room itself just isn't the best layout (L shaped and even more so there are other things wrong). Audyssey seemed to fix this for the listening positions and even the whole room.. My wife really noticed the difference with audyssey filling the room modes (which seemed to be anywhere in the middle of the room). I'd like to look into room treatments but this is beyond my scope for right now.. I'd just be throwing insulation all over the place, heh...
thanks,
Mike
post #25 of 29 Old 08-07-2012, 09:21 AM
Point Source
beastaudio's Avatar
Liked: 2834
Check out ATS acoustic's website, They are killer for cheap panels, and excellent quality.
I Think there is something to be said for "L" shaped rooms. They just suck... My room has a small hallway breaking off the back AND a staircase that takes off from the other corner, so double L shaped. I think this is the majority of the problems I still have. My main LP just doesnt do it for me like it should, which really stinks... The bass is more prominent in ALL other areas of the room including the hallways and no matter how many things ive tried with my limited placement options, there just isnt anything that has made it improve over all the other seats. I have managed to get things much better, but then I move to another seat and it is still that much more better there (had to do it). Im looking into walling off the hallway off the one back corner of the room, which wouldnt be a big deal at all and would be good in the winter since that area of the house is not heated where as my theater room certainly is...
Also fwiw, the fan mod is super easy on the ep4000, and they are dead silent afterwards, ive had one running, and running hard for 2 years or so, and it never has even gotten warm. Yea it voids the warranty but when you can go out there and get another one for around $200 after a few years, if it fails, I look at the benefit of a quieter room for those two years as much more valuable.
post #26 of 29 Old 08-08-2012, 08:09 AM - Thread Starter
BTW, Feeling dumb at this point.. I will have to redo all my graphs as my room EQ setup was wrong.. I will have to use my laptop as I can't calibrate my linux media center PC as it uses HDMI.. (not sure why no one pointed this out, but I feel dumb).. You can't redirect hdmi out back into the sound card frown.gif I was trying to calibrate via my speakers and MIC (this is completely wrong).
Anyways.. i'm going to delete my old graphs above (if it let's me) as they are just wrong...
I'm installing linux on my laptop has that has normal headphone out and mic in.. I can loop back to calibrate my sound card..
thanks,
Mike
post #27 of 29 Old 08-08-2012, 10:20 AM
WagBoss's Avatar
I have an RCA to XLR for my behringer ep4000 and I got it off monoprice. It was cheap like 4 bucks and it is very nice build quality.
WagBoss is offline
post #28 of 29 Old 08-08-2012, 11:51 AM
Point Source
beastaudio's Avatar
Liked: 2834
Im not saying they are all bad, and the ones I have actually work, a little bit. Im just saying they had some QC issues with their cables and I would rather buy from somewhere that has a little bit better track record with them. I have bought dozen upon dozens of other things from monoprice and have never had issues with anything else. Love their stuff, just not the conversion cables...
post #29 of 29 Old 08-08-2012, 07:57 PM
WagBoss's Avatar
I was just letting the OP know, didn't even know you got yours from monoprice lol.
WagBoss is offline
