Bought used elemental design cabinets: very hard to screw into the hurricane nuts, is this normal? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 07-22-2012, 11:50 AM - Thread Starter
omegaslast's Avatar
im pretty sure theyre 10-32#, bought some 10-32# screws, but it takes a lot of effort to screw them in. I dont think drivers have ever been mounted into these... are they supposed to be this tight?
I can screw it in by hand for 1 or 2 turns but then it requires a tool/drill after that.
omegaslast is offline
post #2 of 12 Old 07-22-2012, 12:16 PM
Mr.Tim's Avatar
Quoted: 277 Post(s)
Liked: 180
I don't think that is correct. Are you sure they aren't metric thread?
Tim
Mr.Tim is offline
post #3 of 12 Old 07-22-2012, 12:36 PM
JimWilson's Avatar
Quoted: 1263 Post(s)
Liked: 1560
No, they shouldn't be difficult at all. The amount of torque is essentially no different then a standard nut and bolt.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is offline
post #4 of 12 Old 07-22-2012, 01:32 PM
Colm's Avatar
Liked: 94
Tim
Or 10-24?
In either case, the threads nay be screwed up now. If so, they will need to be cleaned up with the appropriate tap.
Colm is offline
post #5 of 12 Old 07-22-2012, 02:11 PM
tsloms's Avatar
Quoted: 54 Post(s)
Liked: 59
Even with new hurricane nuts they often get a small burr inside of them. It is necessary to run a tap through them to clean them out. Otherwise you run the risk of spinning a nut. eek.gif
tsloms is offline
post #6 of 12 Old 07-22-2012, 11:36 PM - Thread Starter
omegaslast's Avatar
Originally Posted by Colm View Post
Or 10-24?
i screwed in one just a bit and stopped when it took sooo much force.
post #7 of 12 Old 07-22-2012, 11:53 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
You can rotate the driver so none of the nuts are showing, and pilot drill all new holes, then drive #10 screws into the wood slowly.
Jay1 is offline
post #8 of 12 Old 07-23-2012, 04:14 PM - Thread Starter
omegaslast's Avatar
I mean i only screwed a single bolt in about 3-4 heavy turns, i did not mount any drivers.
Im going to go try and get a 10-24#. This is rather aggravating because i have no choice but to just buy a lot of different types of screws and hope one works.
post #9 of 12 Old 07-23-2012, 07:53 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
What I'm saying is, if you dont want to deal with the hurricane nuts, dont use them. Use screws directly into the wood
Jay1 is offline
post #10 of 12 Old 07-23-2012, 08:07 PM
Socketman's Avatar
Quoted: 127 Post(s)
Liked: 147
Really ?? just push the hurricane nut out and take one to the store with you. The corresponding screw should feed in with your fingers.
Socketman is offline
post #11 of 12 Old 07-23-2012, 08:17 PM
maxcooper's Avatar
Quoted: 13 Post(s)
Or take the cabinet to the store, put it in a shopping cart, and find what you need in the store.
maxcooper is offline
post #12 of 12 Old 07-29-2012, 03:41 PM - Thread Starter
omegaslast's Avatar
Thanks for the advice guys, it did turn out to be #10-24.
Problem is the screw doesnt fit very well into the single nut where i screwed the 10-32! Ill just force it i guess, these woofers are the only ones that fit into these cabinets, so i have no plans of changing them out... ever.
