Speaker finish help for rosewood veneer. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-25-2012, 08:00 PM - Thread Starter
benclement11's Avatar
Hi all, I just pulled the trigger on all the parts for my speaker build. I have the rosewood veneer in the attachment coming my way.
This is my first attempt at a high quality stain job. I want a similar color to the paradigm speaker linked below. Does anyone know of good brands of stain? Or should I use a dye? And if I use a dye, will I still be able to see the nice wood grain in it?
If anyone can point me to something that is a really good guide to finishing wood that would be great. I really want them to shine.
http://www.google.com/imgres?um=1&hl=en&biw=1517&bih=714&tbm=isch&tbnid=rvJ0C-VNFmwo2M:&imgrefurl=http://www.canuckaudiomart.com/view_images.php%3Fcat%3DSpeakers%26catnick%3Dspeakers%26cfid%3D648943088%26image_id%3D2329570&docid=K4wrTL8g_zFB0M&imgurl=http://www.canuckaudiomart.com/image.php%253Fimage%253D2329570%2526is_user%253D0&w=1024&h=768&ei=yqIQULL0C87siQLOxoHwDg&zoom=1&iact=rc&dur=573&sig=106062304830736946131&page=1&tbnh=163&tbnw=238&start=0&ndsp=18&ved=1t:429,r:1,s:0,i:76&tx=125&ty=104
veneer.JPG 1942k .JPG file
Panasonic P60ST50-Yamaha RX-V467 receiver-Sony PS3-Velodyne SMS-1-Canton 430 mains, 455 center and 402 surrounds-Rythmik FV15HP subwoofer- Pro-ject Debut III turntable- I also have a pair of Mark K's DIY design, the ER18DXT's
My humble entertainment room
http://www.avsforum.com/t/1417652/midwest...
benclement11 is offline
post #2 of 4 Old 07-25-2012, 10:56 PM
qguy's Avatar
Quoted: 122 Post(s)
Liked: 91
Your veneer is too nice to stain, :-) You may want to just use someform of enhancers prior to finishin to make the grain pop out. There are some oils (Tung Oil is one of them) that are applied prior to finishing to enhanced the grain, but some of them takes weeks to dry.
Besides that Paradigms color is getting too pedestrian. I think most "Rosewood" finish is made with inexpensive veneer and stained to look like rosewood (There are several types of rosewood, ranging from brown color to deep red)
qguy is offline
post #3 of 4 Old 07-25-2012, 11:01 PM
mtg90's Avatar
Quoted: 413 Post(s)
Liked: 786
PassingInterest details his threads pretty well, check out this one: Anarchy/Dayton TM build - Page 5
mtg90 is offline
post #4 of 4 Old 07-26-2012, 05:49 AM
baniels's Avatar
Quoted: 210 Post(s)
Liked: 318
Google Waterlox. It's a really nice, easy finish to use. Hard to screw up.
baniels is offline
