F20? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-27-2012, 07:08 AM - Thread Starter
mph33rd's Avatar
my living room is on the small side but I want to build this bass horn anyways. the wife want like this at all. here's a suggestion... there's a large vent in the floor where an old heater used to be. I used to do hvac, I know it will be hell to get that heater out from under the house. if I do... there will be a perfect place to mount a sub. I know I could a large IB but I want the F20. can you mount a bass horn under the house and have the mouth face up through the floor? please tell me you can and it actually perform well.
mph33rd is offline
post #2 of 6 Old 07-27-2012, 08:51 AM
stormwind13's Avatar
Quoted: 62 Post(s)
Liked: 96
If you are going to do through the trouble to hide the sub, i'd just go IB- it'll be easier and will probably have more output depending on what driver/amp combo you use.
stormwind13 is offline
post #3 of 6 Old 07-27-2012, 09:55 AM
lilmike's Avatar
Quoted: 70 Post(s)
Liked: 178
Sure, you can, if it will physically fit in the space you have. Others have done even bigger horns under their house.
As far as performance??? I know how an F-20 measures groundplane, I have no idea what your room will do to that. Before you go through the trouble, it would be a good idea to make sure that the opening is in a good spot in the room. With subs, just like real estate, it is all about location, location, location.
lilmike is offline
post #4 of 6 Old 07-27-2012, 11:17 AM - Thread Starter
mph33rd's Avatar
the opening is behind the couch.... couch is facing the TV and monitors of course
mph33rd is offline
post #5 of 6 Old 07-27-2012, 04:21 PM
dB-Kicker's Avatar
In most living spaces, rooms have more effect below ~~300hz (increasingly more so as you descend in frequency) on the response of woofers and subwoofers than the actual drivers do. "Behind the couch" doesn't give us enough information to be very helpful - other than to tell you it's a quasi near field position. Like Mike said... "Location, location, Location!"
Realistically you should qualify the room. There are freeware programs available that allow you to measure your room acoustics which are more capable than what we had for professional gear less than a decade ago.. (REW comes to mind).
Your best bet? Take a small woofer - place it in your preferred listening location -then measure the response at all possible subwoofer locations. If the one behind the couch works - then use it! smile.gif
dB-Kicker is offline
post #6 of 6 Old 07-27-2012, 04:28 PM
LTD02's Avatar
Quoted: 2499 Post(s)
Liked: 2832
+1 to what kicker and lilmike said.
if that baffle location causes big nulls at your listening position, it won't matter how good the sub is, the overall experience will be poor.
Listen. It's All Good.
LTD02 is offline
