1000W into 8 Ohms - What amp would you choose? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 07-28-2012, 03:29 AM - Thread Starter
Antripodean's Avatar
Making a move to increase the power delivered to my TD18H+ AE drivers. They are in 100L sealed cabs and operate from 23Hz (highpass 2nd order) to 300Hz
If I was just operating from 80Hz and down I wouldn't be thinking too long about it; just give them the power in whatever form is cheapest (which is class D or some variant). However, I want to drive them cleanly up to 300Hz so I'm calling out to experienced members here who have tried a few pro amps. My current amp is an AM1200S which is 2 channels of 800W into 8 Ohm bridged. It's class AB and is doing duties driving my 2 MaelXs. While it has the power, I found it a bit harsh when used driving higher frequencies.
My available options are (In Australia we don't have all the choices you might think of):
Crown MA-3600VZ - 965W into 8ohm
Camco Tecton 38.4 - 1136W into 8Ohm
Clone LG FP10000Q - 1300W into 8Ohm
Generic 1RU Class D (these are skinned in a variety of brands) - 1050W into 8Ohm
Powersoft DIGAM D4002 - 650W into 8ohm
They are definitely not all the same price and some of these are only accessible to me second hand (due to price!) but it's what I have dug up with a bit of research. There may be some other amps I am overlooking so please feel free to enlighten me wink.gif
explore the music
Antripodean is offline
post #2 of 8 Old 07-28-2012, 08:24 AM
cookieattk's Avatar
Quoted: 111 Post(s)
Liked: 89
difference between 80hz and 300hz isnt much ... not to mention class d amps work just as well as ab if not better these days.
cookieattk is offline
post #3 of 8 Old 07-28-2012, 11:24 AM
BassThatHz's Avatar
Quoted: 2032 Post(s)
Liked: 1550
In this order: K20, FP14K, iT8K, PL380, 5002VZ, FP10KQ, XLS5000, EP4K
Mono Bridged would be best; maybe even get two, for stereo operation.
Not sure about the others...
BassThatHz is offline
post #4 of 8 Old 07-28-2012, 02:38 PM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2575
bth, what is your ordering based on?
the o.p. wants 1000 clean watts in to each of his two subs. you have amps on your list that deliver 10X that amount and cost accordingly.
a behringer inuke6000 will do the trick for an order of magnitude less cost...add dsp for a hundred buck or so in order to fix the extreme rolloff of that sub sealed.
1100 watts rms per channel stereo.
http://www.behringer.com/assets/NU1000_NU3000_NU6000_NU1000DSP_NU3000DSP_NU6000DSP_WebBrochure.pdf
US$499 should be reasonable down under.
Listen. It's All Good.
LTD02 is offline
post #5 of 8 Old 07-28-2012, 02:52 PM
LTD02's Avatar
Liked: 2575
"It's class AB and is doing duties driving my 2 MaelXs. While it has the power, I found it a bit harsh when used driving higher frequencies."
you are probably clipping the amp because the 2 maels are soaking up all your current.
LTD02 is offline
post #6 of 8 Old 07-28-2012, 03:51 PM - Thread Starter
Appreciate what you say but I've heard good and bad designs in class AB and class D
An impressive list of amps that you have tried. Have you run and compared your subs up to 300Hz with these? Probably not enough power in the grid to drive a K20! biggrin.gif
Thanks, I will have a look at the 6000 as they are becoming available here. I really want to audition them but it's not easy to do that. I have a DCX so EQ duties are covered wink.gif
Good point! Something I need to keep in mind when chosing an amp is also having enough power to feed them too!
Found this review on PSW which is interesting.
explore the music
post #7 of 8 Old 07-28-2012, 05:22 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5283 Post(s)
Liked: 4167
LG clone 10,000Q gets my vote if the Behringer EP2500/4000 is not available. The clone gives you the option to power both (or more in the future) and power the Mal-X's with one amp. smile.gif
Also, consider removing the high pass filter altogether and control excursion by filling the box with bricks or something to lower the net airspace. Add that extra displacement to the <20hz. Let them contribute, I say.
Scott Simonian is offline
post #8 of 8 Old 07-28-2012, 07:43 PM - Thread Starter
Yes, the FP10000Q is the obvious choice for many reasons. Right now the TD18s have a Q of 0.5 so I can fill them up to increase that and control excursion. The more subs the merrier! smile.gif
explore the music
