Does port positioning affect sound? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-28-2012, 07:03 PM - Thread Starter
WagBoss's Avatar
I am putting a 3" x 12" slotted port on my subwoofer. I was originally planning on front firing port, but I then I realized I could just do a down firing and it would be completely hidden. Note the subwoofer will be front firing.
So my question is, is it ok to have a front firing subwoofer with a down firing 3"x12" slotted port? Thanks.
WagBoss is offline
post #2 of 5 Old 07-28-2012, 07:23 PM
LTD02's Avatar
Quoted: 2344 Post(s)
Liked: 2581
that's fine. the wavelength of the sound from the port dictates where it will be ok. in your case, up down left right front back (sounds like a cheat code :-) doesn't matter. just make sure that you give your ports enough room to function--at least one port diameter to a boundary.
Listen. It's All Good.
LTD02 is offline
post #3 of 5 Old 07-28-2012, 07:31 PM - Thread Starter
WagBoss's Avatar
one port diamater to a boundary? What do you mean? Like I can't use the walls as part of the port? Or do you mean when the port ends, there needs to be at least one port diameter for the "air intake" ?
WagBoss is offline
post #4 of 5 Old 07-28-2012, 08:09 PM
Prmntgen's Avatar
Decent article on ports/placement:
http://www.trueaudio.com/st_ventq.htm
Prmntgen is offline
post #5 of 5 Old 07-29-2012, 07:21 AM - Thread Starter
WagBoss's Avatar
Thank you that answered my question.
WagBoss is offline
