Need some suggestions on a sub replacement 15 or 18? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-29-2012, 12:32 PM - Thread Starter
squish72's Avatar
hey everyone I recently junked out my dayton hf 15 that was in my Easy Button box and need some suggestions for its replacement. Also id like to upgrade the sub but if possible keep the cost down as much as possible.
here is a link to my semi build thread http://www.avsforum.com/t/1362496/looking-to-build-some-subs-for-my-ht/30
i have onkyo 706 reciever, Oaudio 500w plate amp and the 400L easy buttom currently tuned to 16.4Hz
squish72 is offline
post #2 of 3 Old 07-31-2012, 05:18 PM - Thread Starter
squish72's Avatar
I've got about $350 or so to budget maybe could stretch it to $400 if I waited a bit but What's the better options in that price range in the 14ft3 box? I have a 6" port already cut in the box as Well. Please help me I'm not so good with numbers
squish72 is offline
post #3 of 3 Old 08-03-2012, 01:06 AM
BassThatHz's Avatar
Quoted: 2042 Post(s)
Liked: 1571
14cu ft and $400? I'd do a quad DCS450-18's in that. That would give you the most performance $ for $.
You really can't beat Pro and low-profile cones for ultimate top-end SPL output.
Once you have that done solid, you may find yourself needing far less infrasonic-style bass; which probably goes against everything you've been sold to believe up to this point.
Now none of the following would be as loud up top, but, would have more bottom-end; however you'd still be lacking in >50hz output if you go this direction firstly:
Two FI IB-18's would be cheapest and might squeeze out a few extra db down low.
A future upgrade up from that would be two FTW-21's or two XXX-15's
The 21 would have more output but the 15 would be harder to bottom out, it's more of an easy-button.
http://www.istonline.ca/mach5_ftw_21.html
http://www.sonicelectronix.com/item_36696_RE-Audio-XXX15D4.html
It really depends on how picky you are about your bass. Low bass gets very expensive, very quickly.
That's way too much box for an HF-15, you really have to be careful with <30hz stuff with a big box config like that. It's the unspoken gotcha' in the Iron-Law of subwoofers.
BassThatHz is offline
