Easiest way to pull driver out ... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 08-05-2012, 07:24 AM - Thread Starter
pbc
pbc's Avatar
Quoted: 347 Post(s)
Liked: 206
I know I've read this in some threads, but what is the easiest way to pull a driver out of a box that has been stuck there for a while? In the past I've kind of tilted the box forward and caught it (put soft pillows under it just in case), but this isn't overly bright for several reasons and I'm always frightened of either cracking the wood around the circular cut out or the cone being damaged.
Metal hooks of some sort or wire?
My DIY Subs ... http://www.avsforum.com/avs-vb/showthread.php?t=1233892
J Dunlavy:.. if you stop to think about it, no loudspeaker can sound more accurate than it measures.
pbc is offline
post #2 of 8 Old 08-05-2012, 08:21 AM
Erich H's Avatar
Quoted: 1406 Post(s)
Liked: 1771
These will work:
http://www.harborfreight.com/hand-tools/precision-hand-tools/4-piece-pick-and-hook-set-66836.html
_______________________
The SEOS Waveguide Project
Erich H is offline
post #3 of 8 Old 08-05-2012, 12:22 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
I had a stuck driver and a metal hook wouldn't pull it out. I actually did some small damage to the enclosure from pulling so hard that the pick slipped from the hole. Luckily the terminal plate was right behind the driver so I put the screws back in just enough and pushed a piece of wood through the terminal plate. Budged it enough that the metal pick was able to pull it out.
Mrkazador is offline
post #4 of 8 Old 08-05-2012, 05:39 PM
N8DOGG's Avatar
Quoted: 967 Post(s)
Liked: 1041
I've had to use the paint can lid removers a few times. I have one driver that is pretty much glued in. A man that one will suck to get out on day lol
N8DOGG is online now
post #5 of 8 Old 08-05-2012, 09:57 PM
Face2's Avatar
Quoted: 334 Post(s)
Liked: 201
Loosen the screws just enough so the woofer can move then play some deep bass notes. Sometimes just leaving the screws loose overnight is enough for the driver to come free.
DIY speaker?
Face2 is online now
post #6 of 8 Old 08-06-2012, 09:23 PM
qguy's Avatar
Quoted: 122 Post(s)
Liked: 91
DIY speaker?
qguy is offline
post #7 of 8 Old 08-06-2012, 09:59 PM
Socketman's Avatar
Quoted: 129 Post(s)
Liked: 148
i have had this happen to my diy's, i threaded a large woodscrew lightly in a hole and used a spoon hooked on the screw head to leverage it out.
Socketman is offline
post #8 of 8 Old 08-09-2012, 01:59 AM
Poison Nuke's Avatar
if possible, lay down the enclosure so that the drivers are topside, remove the screws and then search for some bigger screws which fit in the holes of the basket and lift the chassis with the screws.
Is there no terminal in the enclosure? Sometimes it is possible, after removing the terminal, to push directly the magnet of the driver.
Poison Nuke is offline
