Anyone in Sav, Ga area to help with sub box? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 08-08-2012, 03:47 PM - Thread Starter
mulalleybs's Avatar
I can bring beer. biggrin.gif Haha
mulalleybs is offline
post #2 of 9 Old 08-09-2012, 09:03 AM
BillCinLR's Avatar
BillCinLR is offline
post #3 of 9 Old 08-09-2012, 10:32 AM - Thread Starter
mulalleybs's Avatar
Originally Posted by BillCinLR View Post
See if this might help:
http://www.diysoundgroup.com/subwoofer-flatpacks.html
Bill C
it would, unfortunately the biggest box they have is 4.5 cubic feet the sub I have is a 18" FI Q so it has to be like 8+ feet
post #4 of 9 Old 08-09-2012, 02:44 PM
Point Source
beastaudio's Avatar
Quoted: 3519 Post(s)
Liked: 2835
That sub will do just fine in 4.5 cuft. No need for 8 cuft as there will be zero driver protection involved. 22 inch cube is perfect.
beastaudio is offline
post #5 of 9 Old 08-09-2012, 03:03 PM - Thread Starter
mulalleybs's Avatar
Hummm ok. Everytime I've heard it talked about on the other home theater forums people say it needs a huge box to sound right. Ive heard numbers as high as 20 sq ft. The guy I bought it from had it in an 11 sq ft box though.
post #6 of 9 Old 08-09-2012, 05:49 PM
Point Source
beastaudio's Avatar
Liked: 2835
The previous version IIRC needed a much bigger box, but as the current design stands now, you can stuff it in a much smaller box than previously. Perhaps just a bit more power, but in my experience, limiting the excursion via box size and adding some more power is a win win with space limitations. I was previously looking at an 8 q18's setup where each box was about 8 cuft for a PAIR. WinISD confirmed this was great option with ample power. I think I was looking at doing a LG 10000Q with a pair per channel. Ill try and find the graph that Scott Simonian drew up comparing that to some other similar options, but it was only for 4 fi Q's. I will say for sure they modeled very well in that small of a box, you just couldnt hit em with only 200 watts, it was a shade more than that eek.gif
post #7 of 9 Old 08-09-2012, 06:06 PM - Thread Starter
mulalleybs's Avatar
Haha, well I'd have to say your budget is definitely larger than mine. Unfortunately I recently found out that the Q I bought was the older version, but it was still cheaper than the SSD I was going to get so I figured it would still be a better route.
post #8 of 9 Old 08-09-2012, 07:06 PM
Point Source
beastaudio's Avatar
Liked: 2835
no prob then!!! Reach out! a few folks around here will post some graphs if you ask nicely, and they will show you exactly what you will get with 12 cuft vs 8 vs 4. Good people abound in this area, we are all in it together! haha
post #9 of 9 Old 08-09-2012, 07:07 PM
Point Source
beastaudio's Avatar
Liked: 2835
also, savannah to asheville is a haul, but id be willing to help build if you wanted to venture this way.
