How to play sub 20 hz on a TC sounds lms-r 15" - AVS Forum | Home Theater Discussions And Reviews
post #1 of 24 Old 08-09-2012, 10:58 AM - Thread Starter
WagBoss's Avatar
I was trying to play some low frequencies on just a subwoofer driver, no box yet. It is connected from my laptop via 3.5mm to rca into a receiver, then out into a minidsp, then out into a behringer ep4000 which powers my TC sounds lms-r.
If I went 1 hz below 20 it went to zero sub movement. I could get my sub pumping at 20 hz no problem. What could be causing this issue? I have seen videos of people doing 10 hz sin waves and what not.
WagBoss is offline
post #2 of 24 Old 08-09-2012, 12:37 PM
Bill Fitzmaurice's Avatar
Liked: 4630
Don't do that, unless your intent on blowing that driver.
Bill Fitzmaurice is online now
post #3 of 24 Old 08-09-2012, 01:43 PM
bwaslo's Avatar
Quoted: 66 Post(s)
Liked: 182
error...ignore
___________________________________________
DIY Synergy horn spreadsheet Synergy horn spreadsheet and pdf
XSim -free crossover designer and simulator XSim install file
Easy and cheap sound diffusers (the "Depot Diffusers") making easy DIY depot sound diffuser-panels-step by step.html
SmallSyns - point source controlled directivity in a manageable size SmallSyns
bwaslo is offline
post #4 of 24 Old 08-09-2012, 07:19 PM - Thread Starter
WagBoss's Avatar
Ok, but still, even if it was in a box it has ZERO movement. Like it's off. What would the problem be?
WagBoss is offline
post #5 of 24 Old 08-09-2012, 07:29 PM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2576
perhaps mp3 filtering or something that has chopped off your bass response.
Listen. It's All Good.
LTD02 is offline
post #6 of 24 Old 08-09-2012, 08:26 PM - Thread Starter
WagBoss's Avatar
what eletronic device would have mp3 filtering on?
WagBoss is offline
post #7 of 24 Old 08-09-2012, 08:26 PM
Point Source
beastaudio's Avatar
Quoted: 3496 Post(s)
Liked: 2826
Have you tested your response to the amp coming from all the other equipment to see what the rolloff is from your AVR/EQ/whatever else in the chain? Lots of components start rolling off near 20hz. Most sane people do not pursue past that anyways, but we surely do smile.gif
beastaudio is offline
post #8 of 24 Old 08-09-2012, 09:10 PM - Thread Starter
WagBoss's Avatar
how would i test that? I am thinking that it is most likely the headphone out on my laptop that can't output below 20 hz. I want that content though, that is the whole point i am building this subwoofer lol. Well sub 20hz from blu-rays not from my laptop, I was just testing the sub with it.
Do AVR's ever have any type of high pass filter on their LFE output? I know my minidsp is set to a 18 hz high pass filter but that still lets content through below, right? Maybe I have it too steep..
WagBoss is offline
post #9 of 24 Old 08-09-2012, 09:44 PM
Point Source
beastaudio's Avatar
Liked: 2826
If you dont have any measuring equipment, that is all good smile.gif I assumed you might have omnimic or something like REW. My fault.
headphone out could very possibly be the issue. also, AVR's dont have a cutoff, most consumer equipment starts to roll off around 20hz though, most dont care about FR below that, but WE DO!!!!!
A high pass means the upper freq's are allowed through, so a high pass at 18hz means anything lower than 18hz will be cut off. cut that off and see what you think. with the High Pass Filter you are basically neutering your response below 18hz.
post #10 of 24 Old 08-09-2012, 10:04 PM - Thread Starter
WagBoss's Avatar
well the high pass is so the driver doesn't over extend at lower frequencies. I probably have it set with a different db/hz drop than I have it modeled with. I have a mic and REW, just don't see the point of measuring, because right when I drop below 20 the sub STOPS. So I know I get 0 db below 20 and its loud at 20.
WagBoss is offline
post #11 of 24 Old 08-09-2012, 10:08 PM
Point Source
beastaudio's Avatar
Liked: 2826
headphone out speaks volumes here. I hope... full on zero response is problematic. All I am saying is most electronic equip. starts rolling around that same area. If you are able to measure, it means nothing if the sub is not getting any response below 20hz. There I cannot help you. sorry biggrin.gif try another source?
post #12 of 24 Old 08-10-2012, 02:53 AM
paskal9's Avatar
Liked: 24
i doubt your laptop headphone out ain't capable of doing below 20Hz. i have a similar test rig as you:
minidsp plugged into a dell latitude e4300 through the 3.5mm headphone out and into a bridged class d amp.
it's fairly easy to test if your laptop are capable of outputting below 20Hz tone: use a software tone generator, ramp the volume level to max on the laptop and look at the minidsp input gain screen. if there's a tone playing from the laptop then minidsp will detect the tone and give a level. make sure to remove any high pass, low pass crossover that you might have.
and do this without turning on the amp powering the sub. you don't wanna give full sine sweep to a driver in free air.
or if you have any external usb powered speakers plug them in and generate a 20hz tone. my laptop speaker could produce a low tone when i generate 20hz tone without anything connected.
paskal9 is offline
post #13 of 24 Old 08-10-2012, 06:10 AM - Thread Starter
WagBoss's Avatar
I'm going from laptop > AVR > minidsp (sub only) > ep4000> tc sounds lms-r
I'm thinking it's the settings on the high pass filter. What type of filter and what Q/ freq should I use? I want to make sure my driver doesn't over extend but I still want to be able to play lower frequencies.
WagBoss is offline
post #14 of 24 Old 08-10-2012, 06:33 AM
LTD02's Avatar
Liked: 2576
"I know my minidsp is set to a 18 hz high pass filter but that still lets content through below, right? Maybe I have it too steep..."
you have a high pass filter set and are wondering why you don't have significant spl below that frequency?
that is kind of the whole point of a high pass filter.
LTD02 is offline
post #15 of 24 Old 08-10-2012, 07:27 AM
Point Source
beastaudio's Avatar
Liked: 2826
either take the hpf off, or move it to 10hz or so. Sealed box setup right? you really dont even need one. while doing free-air, be very careful...
post #16 of 24 Old 08-10-2012, 10:20 AM - Thread Starter
WagBoss's Avatar
lol, but on my winisd model I should get content down to nearly 5 hz.
I'm not wondering about significant spl, I know it won't be significant.
But I don't even get 0.0001 mm movement. It is like it's off.
WagBoss is offline
post #17 of 24 Old 08-10-2012, 10:21 AM - Thread Starter
WagBoss's Avatar
Nope ported. 6 ft^3 box with a 3x12"x40" port. I don't have the sub in the box yet though. I know you can't hear anything really without the sub in the box, but at lower frequencies, you should still see some movement on the sub shouldn't you?
WagBoss is offline
post #18 of 24 Old 08-10-2012, 11:10 AM
Point Source
beastaudio's Avatar
Liked: 2826
For sure, at 10hz my RE's are going crazy (in box). I dont know what to tell you other than maybe try other sources, or start taking diffferent things out of the chain and see if it improves.
post #19 of 24 Old 08-10-2012, 02:11 PM - Thread Starter
WagBoss's Avatar
Gotta be my hpf, im thinking i have a 4th order on instead of a 2nd order. I'll check when I get home from work.
WagBoss is offline
post #20 of 24 Old 08-11-2012, 02:12 PM
BassThatHz's Avatar
Quoted: 2032 Post(s)
Liked: 1550
I'm more afraid for the amp than the sub.
The EP4k with its Class A/B output-stage tends to overheat and/or clip very quickly below 20hz.
Most subs can survive 10 second bursts between 5-10hz with a rest period of X, but going lower/beyond that is totally at your risk.
The videos that you've seen from notnyt, popalock and myself are done with FP14K and IT8K class amplifiers, with 18 Ultra's that are rated for handling 2kW RMS thermals.
Even with 48/db per oct at 25hz you'd still be getting some output at 19hz. This is weird.
Sounds like something digital. Try lowering the Hz in 1/10th increments and see more precisely where it is brickwalling.
Not that that helps any.
BassThatHz is offline
post #21 of 24 Old 08-12-2012, 05:45 PM - Thread Starter
WagBoss's Avatar
Also I think I figured out why it wasn't playing below 20 hz. I had a 4th order HPF set at 18 hz, and also had the EP4k's 30 hz HPF on by accident. lol so had like -60dB at 15 hz or something like that. Haven't tested it after fixing the two HPF's, but once I finish my box I can. Should be done in a couple days just finished using wood filler, have to veneer and stain now smile.gif
WagBoss is offline
post #22 of 24 Old 08-13-2012, 02:29 PM
Point Source
beastaudio's Avatar
Liked: 2826
BLEH
Gross, get rid of that stuff on the EP completely and run all your filters through the Mini
post #23 of 24 Old 08-13-2012, 02:45 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5283 Post(s)
Liked: 4167
Scott Simonian is offline
post #24 of 24 Old 08-13-2012, 03:52 PM - Thread Starter
WagBoss's Avatar
BLEH
LOL forsure, I didn't mean to turn it on, those switches are so tiny I flicked too many by accident lol.
WagBoss is offline
