Tuba HT can't play low frequencies. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 08-09-2012, 02:44 PM - Thread Starter
chocpretz's Avatar
Ive been trying to work out some kinks with my tuba ht subwoofer. I have a double baffle installed because the cone was hitting plywood. Whenever I try to play anything 30hz or lower, the driver and double baffle just shake like crazy and produce zero clean output. If i push the edges of the second baffle down with all my force, it cleans up some of the sound. Should i screw in the outer edges of the second baffle to the first, in addition to the screws holding the driver down? It also makes a sqeeking sound sometimes. All of this was tested with the access pannel off and duct seal around everything for a perfect seal.
chocpretz is offline
post #2 of 13 Old 08-09-2012, 02:49 PM
Point Source
beastaudio's Avatar
Quoted: 3496 Post(s)
Liked: 2826
squeaking unfortunately is usually an air leak... Any voids in the wood you used???
beastaudio is offline
post #3 of 13 Old 08-09-2012, 03:01 PM - Thread Starter
chocpretz's Avatar
No voids. It's barley audible but i think it has to do with not being able to tighten everything down.
post #4 of 13 Old 08-09-2012, 06:44 PM
dbldare's Avatar
If you can get the side panel, off take it off and PL Glue EVERYTHING you can.
dbl
Let's all go to the lobby
....Let's all go to the lobby
dbldare is offline
post #5 of 13 Old 08-10-2012, 02:22 PM - Thread Starter
chocpretz's Avatar
Everything internally seems to be ok. It's just the driver mounting and baffle that are giving me problems.
post #6 of 13 Old 08-10-2012, 02:36 PM
Bill Fitzmaurice's Avatar
Liked: 4629
The second baffle should have been screwed and glued to the first.
Bill Fitzmaurice is online now
post #7 of 13 Old 08-10-2012, 03:57 PM - Thread Starter
chocpretz's Avatar
Yeah that's what I figured, but I discovered this problem after the entire sub was completed.
post #8 of 13 Old 08-14-2012, 12:50 PM - Thread Starter
chocpretz's Avatar
Ok i think i discovered the main problem. After finally getting the driver mounted correctly, something inside the box is rattling pretty badly. I can't find anything by reaching my hand through the mouth so how would i go about cutting off one of the sides? Im terrified to do this.
post #9 of 13 Old 08-14-2012, 12:52 PM
dbldare's Avatar
How did you glue it in the first place? Any pics of your build?
dbl
dbldare is offline
post #10 of 13 Old 08-14-2012, 01:02 PM - Thread Starter
chocpretz's Avatar
Yeah ill try to upload some pics in a little. But i basically bought a 15'' baffle off amazon and glued it to my existing baffle as a baffle doubler and it sounds pretty solid to me. Screwed the driver down and everything looks good in that area. I glued the the side pannel by putting a ton of PL on every pannel then putting a bunch of bricks and clamps to hold it down.
The mouth is putting out some nice airflow but I can definitely hear something rattling that shouldn't be inside.
EDIT:
The image uploader doesn't like my pictures, so here's an Imgur Link. Sorry there aren't pictures for each step of the way. Also, one thing I made sure of was to sand down all of the panels so they were level when glueing the last side panel on. Obviously something went wrong there.
post #11 of 13 Old 08-14-2012, 01:32 PM - Thread Starter
chocpretz's Avatar
post #12 of 13 Old 08-14-2012, 01:33 PM - Thread Starter
chocpretz's Avatar
post #13 of 13 Old 08-16-2012, 05:25 PM - Thread Starter
chocpretz's Avatar
Ok so today I isolated where the rattling is coming from. Seems to be the top front. Whenever I sit on the top, rattling is reduced but not eliminated. So instead of drilling in screws in an attempt to hold the mystery panel down, I cut off the entire side panel that has the access hole. Thing is, everything looks good internally. All areas have generous amounts of glue and feel totally sturdy, so im not sure what is causing the rattling. My thoughts are that it's panel #8 (to those who are familiar with this build). Any ideas?
