DIY mains and center channel build thread - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-14-2012, 10:49 AM - Thread Starter
rezaN's Avatar
Hey guys. After extensive research, I finally started my project a while ago and decided to post some pictures. The use of these is gonna be 50/50 between movies and music, but my main goal was sound quality.
I will be using all Seas speaker. For the mains I'm using 2 10" seas prestige woofers (H1209), 2 6" mids (E0049) and a Magnum tweeter for each channel. For the center I'm using 2 8" Sease prestige woofer, 1 5" mid and seas tweeter.
The cabinets are going to have 2" think MDF walls all around with heavy bracing and lined with a rubber compound and stuffed. The wood was cut by a friend using CNC.
The mains are going to be tri-amped with a DEQX x-over. The center will have active x-over designed by Madisound. All speakers are from Madisound.
As for the Subs, I'm using 2 12" TC sound LMS-R in 2 ft3 ported box tuned to 25 hz and 1 18" Maelstrom X-18 in a 10 ft3 box tuned to 18 hz. Running the subs will be 2 marathon 5050 amps ( I know over kill)
so here are some pictures of work in progress.
rezaN is offline
post #2 of 5 Old 08-14-2012, 10:58 AM
BllDo's Avatar
Quoted: 572 Post(s)
Liked: 373
Those are some pretty impressive components. Should be nice.
BllDo is offline
post #3 of 5 Old 08-15-2012, 07:11 AM
cptomes's Avatar
Nice bracing...
cptomes is offline
post #4 of 5 Old 08-15-2012, 08:40 AM
filtor1's Avatar
Quoted: 77 Post(s)
Liked: 78
I look forward to seeing more of this one. smile.gif Great job so far!
filtor1 is online now
post #5 of 5 Old 08-24-2012, 08:55 AM
fschris's Avatar
Quoted: 18 Post(s)
subscribed to this one
ASROCK H67 GE / HT/Core i3
Emotiva XPA2 Gen2 x2
Carver AV-705 5Channel AMP
Zaph 2.5MM TT'S DIY
Emotiva UMC 200
2 x MFW 15 Clones DIY
fschris is offline
