DIY Sub time...need help with driver selection - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 08-15-2012, 01:55 PM - Thread Starter
likelinus's Avatar
Quoted: 120 Post(s)
Liked: 51
Right now I have a Klipsch KSW-15 sub that I've been using since around 2002 and It's been decent so far, but I'm ready for something new and thinking about the DIY route. Ultimately I'd like to stay in the 15" range at around $200 or less per sub. I've looked at the Dayton HO in a small sealed, but I just don't know what else is out there! Ideally I'd like to stay on the smaller side of the enclosure and would like something sealed or ported as long as it's not huge.
So what suggestions do you have for a driver under $200? Do you think I would see a nice improvement with something like the HO driver versus the KSW?
likelinus is offline
post #2 of 11 Old 08-15-2012, 04:17 PM
Danielson99's Avatar
Quoted: 82 Post(s)
Liked: 63
small size and loud = lots of power
If you want the smallest enclosure I'd make it somewhere between 2.5-3.5cft and feed it 500w's of power. Should get down to 20hz before it starts dropping off. Roughly a 21" cube externally.
If you want more output then I'd go ported in the 5cft range with 300w of power and tuned to the low 20's but not sure of the exact port length/size.
With either of those subs you'll see a big difference in that Klipsch sub, especially in sound quality. The biggest reward will be in building it yourself. Sealed is definitely the easiest way to go for a first build.
Danielson99 is offline
post #3 of 11 Old 08-15-2012, 06:00 PM - Thread Starter
likelinus's Avatar
Quoted: 120 Post(s)
Liked: 51
I've built sub boxes several times for my cars and it's fairly simple when doing a sealed enclosure, for sure. I'm more than willing to look into ported and go that route, but I just don't know enough about how to figure out the tuning part. I need to do some reading I guess. But 5cf might be too large for the space since it's actually in a living room. The 21" cube is a perfect size since the Klipsch is 19 1/2" x 17.5", so it would be near the same size. I can live with that, but I'm not sure wife would like something more than twice the size, lol.
So does anyone have recommendations on subs in that price range?
post #4 of 11 Old 08-15-2012, 06:40 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
You can do a ported HO 15 in a 21" cube, you just have to take a little extra effort with the ports. Something like a pair of 4" x 34" long ports would be needed to tune you in the low 20's without port noise being an issue. All you need to do is place 90 degree PVC elbows in the back of the cabinet
http://www.lowes.com/pd_23362-1814-PVC+00304++1200_0__?Ntt=4%22+pvc+dwv+90-degree+long+sweep+elbow&productId=3132793&rpp=16
So you run PVC pipe from the port opening to the elbows on the back wall, and then up from the elbows, leaving 4" clearance from the interior port opening to the top of the cabinet. This setup will be a perfect match for a 500 watt plate amp like the ones PE sells. This is what the sub would be capable of.
Jay1 is offline
post #5 of 11 Old 08-15-2012, 07:52 PM - Thread Starter
likelinus's Avatar
Quoted: 120 Post(s)
Liked: 51
Very cool and great information. So is the advantage of tuning the box with a port is the ability to go lower? Curious as to what the difference would be in a sealed enclosure at 21" cubed and the benefits of the port.
post #6 of 11 Old 08-15-2012, 07:58 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
The difference is much greater output and flatter response near the tuning point. You can eq a sealed box to be flat, but that will kill your headroom. It's basically free output, since a plate amp has a high pass filter limiting your low end whether you go sealed or ported, there's no reason not to go ported unless you absolutely cant fit a box of the required size to port.
Jay1 is offline
post #7 of 11 Old 08-15-2012, 08:16 PM - Thread Starter
likelinus's Avatar
Quoted: 120 Post(s)
Liked: 51
Oh ok, very interesting and I appreciate the information. I can certainly fit a sub that size and honestly I really want two, but I just got a new projector, screen and a in-wall built-in entertainment center to hold everything. So I'm not going to spend a lot right now, but I'd like to get two drivers and two BASH amps and I'll build the enclosure myself. Very doable and I love the idea.
So am I to assume that the HO/HF is a good buy in that price range? Sticking around that size case, is there any other recommendations?
post #8 of 11 Old 08-15-2012, 08:42 PM
LTD02's Avatar
Quoted: 2341 Post(s)
Liked: 2577
hey bud, there are many solutions. you have to consider the full enclosure and the room, not just the driver.
there are many different tradeoffs.
take a look at lilmike's f20 cinema sub. it might be what you are looking for.
Listen. It's All Good.
LTD02 is offline
post #9 of 11 Old 08-16-2012, 08:29 AM - Thread Starter
likelinus's Avatar
Quoted: 120 Post(s)
Liked: 51
Good point. The room is actually a living room and one reason why I'm trying to keep the box size to a minimum. The room itself is probably 25 x 17, but it opens up to the breakfast area and kitchen, so from a space perspective it's much larger and is an open floor plan. We haven't been disappointing in the KSW-15, but I'd like a little more and something tighter. The KSW is a little sloppy when it goes low. If that makes sense. That is one reason why I'm considering 2 subs but may wait to see what 1 higher quality sub produces first.
I checked out the f20 and there's no way I could get away with a 4 foot wide sub in the living room. I doubt my wife would go for that. lol Looking for something smaller smile.gif
post #10 of 11 Old 08-16-2012, 02:23 PM
Quoted: 82 Post(s)
Liked: 63
What if it was only 16 1/2"w x 32"d and 92" tall? Small footprint right? It would be seriously louder than any ported sub you are contemplating....but I'm thinking your wife might get that look on her face when she saw it.
You'd probably be better off building 2 seperate enclosures for your space, even based off of 12" drivers. Better frequency response across your listening area.
post #11 of 11 Old 08-16-2012, 03:17 PM
LTD02's Avatar
Liked: 2577
"lol Looking for something smaller..."
the 390ho gets good reviews and works in smallish cabs.
some of the other low priced excursion monsters have inductance problems, so i wouldn't point you in that direction.
the -hf has better sound quality in theory than the -ho because of its lower normalized inductance (le/re). i have not seen an a-b comparo. folks don't seem disappointed with either.
LTD02 is offline
