Electronics burn in - Can we finally put the myth to rest?? - Page 5 - AVS Forum | Home Theater Discussions And Reviews
post #121 of 138 Old 08-31-2012, 04:57 AM
caper_1's Avatar
Liked: 26
HT: Yamaha RX-V565 | 3 X Energy Take FPS, 2 X VS Surround, 2 X Take LCR | DIY Subs: SDX12 APR15 & TRIO12 Dual APR 12's | 47" LCD
Music: Yamaha RX-V863 | 2 X Energy RC-70 | MA RXw12 Sub
Bathroom: 2 X Energy Take LCR
Car: Sony Xplod HU, Xplod 6X9s, Kenwood 4"s, Alpine 12" Type-S, Rockford Amp,...
caper_1 is offline
post #122 of 138 Old 08-31-2012, 12:39 PM
gbegland's Avatar
One of the best posts of all time. BassThatHz for President! Can you talk to empty chairs by chance?
gbegland is offline
post #123 of 138 Old 08-31-2012, 01:16 PM
Bill Fitzmaurice's Avatar
Liked: 5684
In all fairness we should give equal time to the opposition point of view. In its own way it's just as hilarious. tongue.gif
http://www.morrowaudio.com/cablebreakin.htm
Bill Fitzmaurice is offline
post #124 of 138 Old 08-31-2012, 02:35 PM
Jinjuku's Avatar
Quoted: 65 Post(s)
Liked: 148
An audiophile likes to talk about how much they spent and how good it sounds.
A DIY'er likes to talk about how little they spent and how good it sounds.
Jinjuku is offline
post #125 of 138 Old 08-31-2012, 02:53 PM
Liked: 5684
post #126 of 138 Old 08-31-2012, 07:54 PM
Liked: 5684
Originally Posted by imagic View Post
Holy crap, how deep IS the rabbit hole?
A lot deeper than you might suspect. You don't even have to be terminally stupid to fall for their pitch, just uninformed. OTOH consider this site, and yes, they do actually sell their wares:
http://www.machinadynamica.com/index.html
post #127 of 138 Old 08-31-2012, 08:39 PM
Cocophone's Avatar
Their reasoning seems counter intuiative. Why would the amount of special procedures required increase as the cost also increases.
A $10 cable is ready to be used as soon as I open the packaging, but their very expensive cable requires hundreds of hours before it is ready to use.
Our cables require a total of 400 to 500 hours to completely break in. If you ordered our 2 day cable break-in service, your cables will arrive with the equivalent of 96 hours on them. If you ordered the extended 5 day breakin, the equivalent of 240 hours will be on them.
The "difficult stage" of the breakin, where the cables might be hard to listen to is between 50 to 100 hours. There can be brief periods however past this point. If you have an evening where they are hard to listen to, do not fret, this will quickly go away. All should be well the next day. When full breakin is reached, there will be no more changes with the sound.
Between 50 and 100 hours you will experience the "difficult stage" of the break-in process. The sonic potential of the cable drops to 50%. It may be difficult to listen during this time. This is when some of our customers make a pre-mature return, missing out on the full sonic glory of the product.
Our cables are ment to be hooked up and left alone. If you later move your cables, 1 to 2 days might be required for them to "settle" into their new positions. If you notice a change in the sound, all will return after the 1 to 2 days. Again, do not fret!
LOL
==Cocophone==
Cocophone is offline
post #128 of 138 Old 08-31-2012, 08:43 PM - Thread Starter
brandonnash's Avatar
Liked: 33
It's not just amazing they get people to buy into that but also that no one ran a spell check or checked for any sort of grammatical errors. I guess those that read into burn in have the same deficiencies.
brandonnash is offline
post #129 of 138 Old 08-31-2012, 10:20 PM
Bigus's Avatar
Quoted: 397 Post(s)
Liked: 385
This site and Geoff kait deserve a special nod as not only do they make many ludicrous claims, but many objective claims that can put to the test and meet the criteria for outright consumer fraud. If they weren't such a nothing business on the radar, they would be shut down and prosecuted for fraud. I don't think their fallback to mind body interaction (otherwise know around these parts as "you are imagining the effect, nothing has really changed") as a defense (specifically mentioned on their website fir just that reason) would cut the mustard in court as they make specific objective claims that can be refuted factually.
Lots of really stupid stuff there, but this line I always find especially amusing:
The original glass bottles for Brilliant Pebbles have been replaced by clear zip lock bags, which have a more linear response than glass.
Bigus is offline
post #130 of 138 Old 09-01-2012, 06:29 AM
Liked: 5684
I'm as much against the fleecing of the uninformed masses as the next guy, if not more so, but there comes a point where you've got to throw up your hands and say if anyone's stupid enough to believe anything on sites like that they pretty much deserve to be snookered. But then you've got to say where do you draw the line between obvious flimflam artists and sources like Audioquest, who IMO are just as guilty of cheating the public, perhaps more so, as their lies aren't so easy to see through.
post #131 of 138 Old 09-01-2012, 09:08 AM
Mark Henninger
imagic's Avatar
Quoted: 6505 Post(s)
Liked: 11268
OK I guess the rabbit hole is actually a black hole. Well, here's a cheap accessory that allows one to burn-in their power cords using ordinary lamps! Imagine the improvement in the quality of the light coming from that lucky lamp. http://www.musicdirect.com/p-6968-dedicated-audio-power-cord-burn-in-tool.aspx
Mark Henninger, Senior Editor at AVS Forum
imagic is offline
post #132 of 138 Old 09-01-2012, 09:22 AM
chilort's Avatar
Quoted: 16 Post(s)
Liked: 74
A colleague and I once had a project manager (I think he was a mechanical engineer) convinced a circuit wasn't working correctly because the electrons in the wiring were escaping. We told him some BS story that electrons escaping was a natural process but that this circuit seemed to have a little more electron leakage than what we were used to seeing but that we'd track it down.
It did have electrons leaking. The circuit was wired incorrectly. But I hope to this day that that idiot thinks electrons magically escape from things. And no, this was not true leakage that does occur where fractions of micro amps are lost; we were missing amps and somehow didn't have a fire.
chilort is offline
post #133 of 138 Old 09-02-2012, 10:57 AM
cuzed2's Avatar
Quoted: 200 Post(s)
Liked: 256
Too Funny!
So if the circuit would have smoked, you could have asked him:
"Is that smell AC smoke, or DC smoke ???
Cuzed2
CuznEddy Cinema
cuzed2 is offline
post #134 of 138 Old 09-06-2012, 02:54 PM
koturban's Avatar
Quoted: 225 Post(s)
Liked: 125
koturban is offline
post #135 of 138 Old 09-06-2012, 03:06 PM
pbc
pbc's Avatar
Quoted: 414 Post(s)
Liked: 214
Originally Posted by koturban View Post
Well, let's look at their math here ...
So here we learn that 2 days = 96 hours, therefore 1 Day = 48 hours.
So 5 days must therefore equal 240 hours. What's your problem man? The math works perfectly.
Now pardon me, I just moved my cable a few inches to the left and everything sounds different in my system. So I'm going to give it 1 to 2 days (or 48 to 96 hours) of time to settle back to where it was.
You AVS'ers are so cynical.
caper_1 likes this.
My DIY Subs ... http://www.avsforum.com/avs-vb/showthread.php?t=1233892
J Dunlavy:.. if you stop to think about it, no loudspeaker can sound more accurate than it measures.
pbc is offline
post #136 of 138 Old 09-06-2012, 04:14 PM
Cocophone's Avatar
You need to read more carefully:
CABLE BREAK-IN
2 day cable break-in service = equivalent of 96 hours.
Their break-in service is more efficient than normal by a factor of 2 to 1. So using their super efficient break-in procedures; 1 hour of break-in is the equivalent of 2 hours doing it yourself using conventional break-in methods.
==Cocophone==
post #137 of 138 Old 09-07-2012, 12:57 PM
pbc
pbc's Avatar
Quoted: 414 Post(s)
Liked: 214
Wow. That's like what a funnel does for beer. Much more efficient.
pbc is offline
post #138 of 138 Old 09-07-2012, 02:13 PM
Liked: 5684
They probably figure that if you buy the concept of cable break-in you'll buy anything, including their silly over-priced cables and paying for break-in, which I'd bet dollars to donuts they don't actually do anyway.
