Need input of first attempt at Hornresp - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-17-2012, 01:19 PM - Thread Starter
maintrain's Avatar
Liked: 37
I've been recently looking at tapped projects on this site and the LMS-R build intrigued me enough to try and model an Eclipse SW9152 that I have been sitting on for a couple years. Here are the woofer specs I'm using:
* Manufacturer: TC Sounds for Eclipse
* Model: SW9152
* Piston Diameter = 76.2 mm
* f(s)= 34.99 Hz
* R(e)= 6.30 Ohms
* Z(max)= 73.05 Ohms
* Q(ms)= 7.142
* Q(es)= 0.674
* Q(ts)= 0.616
* V(as)= 0.185 liters (0.007 cubic feet)
* L(e)= 9.22 mH
* n(0)= 0.00 %
* SPL= 62.60 1W/1m
* M(ms)= 326.60 grams
* C(ms)= 0.06 mm/N
* BL= 25.91
I followed the simple tapped horn tutorial the posted by lilmike and came up with some interesting results. Problem is I don't know if results are adequate to build an enclosure from.
Here is my first attempt:
sw9152.txt 0k .txt file
Second attempt
sw9152-2.txt 0k .txt file
I'm sure there are some parameters that are wrong in this attempt since I am getting a pop up message every time I calculate.
I'm looking forward to everyone's input.
File Type: txt sw9152.txt (402 Bytes, 32 views)
File Type: txt sw9152-2.txt (405 Bytes, 20 views)
maintrain is offline
post #2 of 3 Old 08-17-2012, 10:33 PM
Oklahoma Wolf's Avatar
Quoted: 20 Post(s)
Before you can really do anything, an accurate set of TS parameters is important. Rumor has it the specs from Eclipse on this driver aren't very accurate.
Vas in particular has to be a typo... not sure about the others.
My suggestion would be to grab Soho54's Easy Horn spreadsheet (do a forum search) once you know you have good specs and go from there. It's a huge timesaver, and will get you into the ballpark a little faster.
Oklahoma Wolf is offline
post #3 of 3 Old 08-19-2012, 02:48 PM
LTD02's Avatar
Quoted: 2525 Post(s)
Liked: 2868
you seem to be heading in the right direction.
just a minor point, on your second sim, s2 is the cross sectional area in the front of the driver, so s1-s2 can't be less than 1/2 the driver width.
what made the lms-r horn build relatively easy was that the s1-s2 length and s3-s4 length were the same and the expansion was pretty much constant. that can make things a lot easier, but the result isn't always good.
he wanted a giant horn and that driver just happened to work in it. sometimes you get a little lucky.
Listen. It's All Good.
LTD02 is online now
