How much does 1 gal of Duratex cover? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 08-22-2012, 08:06 PM - Thread Starter
Frosteh's Avatar
I have three 4Pi speakers and a JBL 4645c that I need to cover in Duratex. Will 1 gallon be enough for all this? I'll be rolling this on.
Frosteh is offline
post #2 of 8 Old 08-22-2012, 08:38 PM
Quoted: 3255 Post(s)
Liked: 2743
I had over a 1/2 gallon left after rolling on duratex on three 4Pi. I went for a smooth finish and used a smooth foam roller. Did two coats.
post #3 of 8 Old 08-22-2012, 08:48 PM - Thread Starter
Frosteh's Avatar
Awesome, thanks. I was actually just looking at your build over at audioroundtable. Excellend job! I'm hoping mine will turn out as well. I noticed you have yours mounted with the tweeters quite a bit higher than ear level. Was there a reason for this/does it make a big difference in your theater? I'm not quite sure how high to mount mine as it seems most people are using them as 2ch music speakers, not in a theater.
Frosteh is offline
post #4 of 8 Old 08-22-2012, 09:22 PM
desertdome's Avatar
Quoted: 1119 Post(s)
Liked: 1222
I bought a gallon and covered four dual opposed 5 cubic ft subs with 2 coats on most surfaces and 3 coats on a few. I also did a 2.5 cubic ft dual opposed sub with two coats. I still have about a pint left.
High Impact AV
desertdome is offline
post #5 of 8 Old 08-23-2012, 06:32 PM
Liked: 2743
When I finished them i stuck them on the stands I had. Not a lot of thought. On tweeter ear level alignment. I have three rows of seating and I suspect having them higher helps get the sound out to all three rows. The highest seating are bar stools.
post #6 of 8 Old 08-24-2012, 07:34 AM
tsloms's Avatar
Quoted: 54 Post(s)
Liked: 59
If you want to stretch the duratex a bit further paint the enclosure with flat black paint as a base and then add the duratex finish over that. I've done this on countless builds and it's surprising to see how much the duratex can cover.
tsloms is offline
post #7 of 8 Old 08-24-2012, 09:16 AM
Spec4's Avatar
Liked: 24
Interesting, so what's your procedure regarding the various coats of paint? Do you sand the wood before and/or the coats between? I have 4x 2.5cu.ft. MFW-15's, pair of SEOS12 + JBL 2226 mains and possibly surounds to paint. I'm guessing 1 gallon may not cover all of those so your idea is appreciated and noted.
JB
Spec4 is offline
post #8 of 8 Old 08-24-2012, 07:18 PM
tsloms's Avatar
Quoted: 54 Post(s)
Liked: 59
I had been spraying my boxes with the water based flat black paint with 2 coats and then spray 2 coats of duratex over that. That's it. No sanding between coats needed due to the texture of the duratex. I did roll the duratex on once and it turned out well but spraying is much faster if you're doing that many enclosures. Btw I use a cheapo harbor freight texture spray gun that was less than $20. A gallon of duratex will easily cover the boxes that you listed.
tsloms is offline
