Seos dna360+2226h+dcx2496+ati1505 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-24-2012, 06:08 PM - Thread Starter
datranz's Avatar
Quoted: 57 Post(s)
Liked: 40
waiting for omnimic from parts express
datranz is offline
post #2 of 5 Old 08-24-2012, 06:33 PM
LTD02's Avatar
Quoted: 2341 Post(s)
Liked: 2577
sounds great, but the pics aren't displaying properly.
Listen. It's All Good.
LTD02 is offline
post #3 of 5 Old 08-24-2012, 06:40 PM
JackNC's Avatar
Quoted: 135 Post(s)
Liked: 37
what's an ATI 1505 (google) Oh! Just what you need to make active crossover + equalization an no-brainer! No more waiting for someone else to design a crossover. There is also the emotiva xpa5 at $899 for 5x200W, I;m going with a pro-amp for the mid plus SURE amp board for the DNA-360.
JackNC is offline
post #4 of 5 Old 08-24-2012, 06:48 PM
bwaslo's Avatar
Quoted: 66 Post(s)
Liked: 182
Make sure you put a blocking cap in series with the DNA-360 -- you don't want DC offsets or power transients from the amp zonking the driver. Something like 50uF or more should do.
___________________________________________
DIY Synergy horn spreadsheet Synergy horn spreadsheet and pdf
XSim -free crossover designer and simulator XSim install file
Easy and cheap sound diffusers (the "Depot Diffusers") making easy DIY depot sound diffuser-panels-step by step.html
SmallSyns - point source controlled directivity in a manageable size SmallSyns
bwaslo is offline
post #5 of 5 Old 08-24-2012, 08:09 PM - Thread Starter
datranz's Avatar
Quoted: 57 Post(s)
Liked: 40
packaging was topnotch, the horn felt very solid. quality stuff.
thanks for the tip bwaslo.
hope to finish the box by next weekend.
datranz is offline
