i need a favor modeling this thiel 8" cs2,2 woofer - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 08-28-2012, 06:22 PM - Thread Starter
tundrSQ's Avatar
http://www.thielaudio.com/THIEL_Site05/Pages/Specials/CSWoofers/21cmwoofspecsheet.pdf
Nominal inpedance 4 Ω
SPL@2.83V-1m 2π 91 dB
Coil material Copper
Coil resistance 2.8 Ω
Coil diameter 39 mm
Number of layers 2
Wire diameter 0.32 mm
Coil length 19 mm
Cone diameter 0.173 m
Moving mass 41 g
Mech. resistance 2.4 kg/s
Resonance 26 Hz
Vas 71 l
Qm 2.8
Qe 0.41
Qt 0.36
Flux density 1.02 T
Gap height 6 mm
Bl 6.8 T•m
Maybe its been done already, but i am looking to use 2 of them as a car subwoofer....sealer or ported...looking for SQ over output.
Not sure what amp i would run yet...but thinking mono bridged to 2ohm and maybe 200 watts.
Is it possible to shoehorn 2 of these into a small sealed or ported box based on the t/s?
If i went ported i could be tuned at 50hz without worrying too much.
Tim
tundrSQ is offline
post #2 of 12 Old 08-28-2012, 06:42 PM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2576
yes. models very nicely in a 1 cubic foot enclosure per driver, but you could go smaller, less than 0.5 cubic feet might be getting a little small.
anywhere from 0.5-1.0 cubic feet gives a -3db point of around 55hz. in a car, cabin gain will really extend the -3db point.
and 100 watts per driver in the 0.5 cubic foot per driver build is ok, but in the 1.0 cf per driver, that is a little too much. only 50 watts or so per driver would be required to push the driver to its excursion limit.
Listen. It's All Good.
LTD02 is offline
post #3 of 12 Old 08-28-2012, 06:59 PM - Thread Starter
tundrSQ's Avatar
awesome thank you!!!! I will let you know how it sounds.
Tim
tundrSQ is offline
post #4 of 12 Old 08-28-2012, 07:21 PM
LTD02's Avatar
Liked: 2576
:-) no problem...
LTD02 is offline
post #5 of 12 Old 08-28-2012, 07:27 PM - Thread Starter
tundrSQ's Avatar
i will probably split the difference and go .70 per driver and add polyfill...i will build a simple box to start and see how it sounds before i build it into the walls of the hatch.
Tim
tundrSQ is offline
post #6 of 12 Old 08-28-2012, 07:35 PM
awblackmon's Avatar
Quoted: 48 Post(s)
Liked: 57
I have a single 8 inch driver in my Tacoma PU and have to say the bass is very good. May not be way loud at 20 hz but it does sound like the bass goes deep enough for my liking when I am listening to my music.
Mitsubishi 3800 projector onto 103 inch DIY AT screen. Marantz 8802A Sound ably handled with DIY LCR speakers. Surrounds are Paradigm in wall speakers. Overhead speakers for Atmos and DTS:X are minimus 7. DIY IB sub system. Two pairs of Dayton 15 inch in separate manifolds. Power amps are Harman Kardon Signature 2.1 doing basic 5 bed channels. Kenwood KM-X1 6 channel for L/R wide and four overhead speakers. Kenwood Basic M1D doing Subwoofer work.
awblackmon is offline
post #7 of 12 Old 08-28-2012, 07:45 PM - Thread Starter
tundrSQ's Avatar
thats all i am going for here...the sound with the hybrid audio comps is "almost" good enough to not need a sub...but i just need a little something more...
PS..i have an 18" ported sub in my HT...so i do like bass...but in this system i am going for a flat FR.
Tim
tundrSQ is offline
post #8 of 12 Old 08-30-2012, 08:05 PM - Thread Starter
tundrSQ's Avatar
Anyway to model these drivers as Infinite baffle? IMAG0121.jpeg 1369k .jpeg file
just thinking out loud...
Tim
tundrSQ is offline
post #9 of 12 Old 09-02-2012, 01:03 PM - Thread Starter
tundrSQ's Avatar
nvm...i have decided to just put them in a simple sealed box...figuring i would lose too much output going IB, same for doing an ap membrane. will be about .6cuft per driver, but will stuff the crap out of it to make it feel bigger:)
Tim
tundrSQ is offline
post #10 of 12 Old 09-04-2012, 03:42 PM - Thread Starter
tundrSQ's Avatar
change of plans..went back to IB..but am doing 4 of them.
Tim
tundrSQ is offline
post #11 of 12 Old 10-05-2012, 06:47 PM - Thread Starter
tundrSQ's Avatar
Update....i ended up putting 4 of these in the hatch as and IB....and powered them with 200 watts at 4ohms, and the SQ is amazing...i am loving these guys. I have done dozens of different sub boxes and this is probably my favorite set up in any of my cars. Really surprised me how good it sound...wish i had not waited so long to go IB. IN fact i am contemplating going IB in my HT with my 18" mach 5 driver....smile.gif
Tim
tundrSQ is offline
post #12 of 12 Old 10-05-2012, 06:49 PM - Thread Starter
tundrSQ's Avatar
Here is a picture...not complete...as i only had 2 of the drivers at the time i took this...but it gives you an idea of what i did. IMAG0126.jpg 1184k .jpg file
Tim
tundrSQ is offline
