Driver replacements for ED owners? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 08-29-2012, 02:22 PM - Thread Starter
chrischaos's Avatar
Quoted: 22 Post(s)
Liked: 30
Hey all. I thought i would ask the DIY community for a little help. Since ED is now dead, many customers will be hooped if their drivers fail. Unfortunately, the various model driver specs are not available on the website anymore. If any members have the specs or know of a suitable replacement for any of their drivers, please post.
chrischaos is offline
post #2 of 11 Old 08-29-2012, 02:33 PM
Mark Seaton's Avatar
Quoted: 496 Post(s)
Liked: 1300
Great minds think alike? wink.gif Good idea.
Here is what Chris Schempp posted in the other thread. I also recall eD had posted internal volumes and tuning frequencies in the spec section of many of the products. I might take some archive digging as most of the models aren't listed in the store anymore.
Originally Posted by Chris Schempp View Post
13Av.2(*-325/650 subs):
Qts: .45
Qes: .48
Qms: 7.48
Fs: 23.29Hz
Re: 2.81
Vas: 55.79L
Mms: 257.0g
Bl: 14.81T*m
SPL: 83.50dB
Sd: 556cm²
Xmax: 28.75 (Physical Linear)mm
Voice Coil: 76.0mm
Magnet Width: 7.500"
Cutout Diameter: 12.000"
Mounting Depth: 10.050"
Weight: 59lb
Total Height: 10.050"
Displacement: .12 ft³
Outside Diameter: 13.500"
19Ov.2(I believe A7S-450 and very old A7-450s also A7-900):
Qts: .369
Qes: .37
Qms: 7.5
Fs: 26.00Hz
Re: 3.5
Vas: 228L
Mms: 307.0g
Bl: 22.10T*m
SPL: 90.5dB
Sd: 1200cm²
Xmax: 22.0mm
Voice Coil: 62.5mm
Magnet Width: 8.200"
Cutout Diameter: 16.375"
Mounting Depth: 9.625"
Weight: 42lb
Total Height: 10.600"
Displacement: .10 ft³
Outside Diameter: 18.375"
16Ov.2(*-350/700 subs)
Measured Specifications (Via LMS)
X Parameters
XMag 21.00MM XSUS 26.00MM XMax 21.00MM
Thiele Small Parameters @ x=0
FS - 23.00Hz
Qe - .42
Qm - 3.0
Qts - .36
Vas - 254 Ltr
Sd - 0.0872 m^2
Re - 7.0 ohm
Nominal Diameter: 15” (375.0 mm)
Continuous Power Handling: 650 Watts
Available Configurations: Dual 2
Xmax (one-way, linear): 21.00MM
Mounting Depth: 8.125”
Driver frontal Diameter : 15.375“
Motor Diameter: 7.20”
Driver Displacement: 0.08 ft³
Additional Information
Electro-Mechanical Parameters @ x=0
Sd - 0.0872 m^2 effective radius
Bl - 22.10 T*m
Re - 7.0 ohm
Manufacture Model : 16Ov.2 Subwoofer
Description : 15” Low Frequency Transducer
Motor Topology : Overhung Ceramic Motor
Overall Outside Diameter : 15.375”
Mounting Diameter : 13.750“
Depth : 8.125”
Magnet Diameter : 7.20”
Voice Coil Size : 2.5”
e3.12(I think A2-300):
Qts: .31
Qes: .35
Qms: 3.33
Fs: 21.5Hz
Re: 3.7
Vas: 162L
Mms: 142.0g
Bl: 15.00T*m
SPL: 88.47dB
Sd: 545cm²
Xmax: 16.0mm
Voice Coil: 50.0mm
Magnet Width: 5.700"
Cutout Diameter: 11.000"
Mounting Depth: 5.750"
Weight: 14lb
Total Height: 6.250"
Displacement: .06 ft³
Outside Diameter: 12.375"
e5.12(A3-300/upgraded driver):
Can't find in wayback machine
e5.10(I believe *-250 products):
Qts: .36
Qes: .38
Qms: 6.00
Fs: 24.1Hz
Re: 4.4
Vas: 52L
Mms: g
Bl: 17T*m
SPL: dB
Sd: 350cm²
Xmax: 25.4mm
Voice Coil: 50mm
Magnet Width: 6.5"
Cutout Diameter: 9.200"
Mounting Depth: 6.125"
Weight: 20lb
Total Height: 6.75"
Displacement: ft³
Outside Diameter: 10.9375"
Mark Seaton
Seaton Sound, Inc.
"Make no little plans; they have no magic to stir men's blood..." Daniel H. Burnham
Mark Seaton is online now
post #3 of 11 Old 08-29-2012, 07:14 PM - Thread Starter
chrischaos's Avatar
Quoted: 22 Post(s)
Liked: 30
Thanks for the help and thread bump Mark. Looks like i was writing here while you were posting in the other thread. Id like to agree with your great minds comment but sadly when it comes to this stuff yours is the only great mind in this equation:rolleyes: hopefully the community can come up with some replacements. I know i will probably like to try a different driver someday if i can still use the same box i had made.
post #4 of 11 Old 08-29-2012, 07:45 PM
dominguez1's Avatar
Quoted: 903 Post(s)
Liked: 616
From a depth perspective, the Mach 5 UXL-18 would be a good replacement for the 19OV.2. However, you would have to increase the diameter of the hole some.
dominguez1 is online now
post #5 of 11 Old 08-29-2012, 08:34 PM
MKtheater's Avatar
Quoted: 1592 Post(s)
Liked: 1123
What about a TC sounds LMSR-12 for the 13av2? The cabinets are stellar and would love to drop in two of these guys to compare.
Marantz 7702 Atmos
MKtheater is online now
post #6 of 11 Old 09-24-2012, 03:47 PM
Mark Masterson's Avatar
I really need the a3-300 driver specs, who makes the thing? my driver died and I am currently screwed. Thanks.
Mark Masterson is offline
post #7 of 11 Old 09-24-2012, 04:17 PM
LTD02's Avatar
Quoted: 2341 Post(s)
Liked: 2578
sorry to hear about your driver problems, but who cares about dead driver specs?
what you need to know are the enclosure and amplifier specs, then a good set of drivers can be matched even if they have different specs than the ed specs (which seemed to have some questions surrounding them in the past anyways).
Listen. It's All Good.
LTD02 is offline
post #8 of 11 Old 09-24-2012, 06:04 PM
SULLY12's Avatar
Any one that has a two year old or newer a2 300. That above info is wrong. I took mine out to see what it looked like and was less then impressed with the driver . Alex would never tell me the truth. But when I wanted to talk to matt about making a clone since they are out of biz he honestly replied that it is theayton classic driver that cost $85 at parts express. Wow. No wonder mine bottoms out all the time. They go from the original 16 mm xmax to 9.5. Kinda dis honest on there part. But if you have a newer a2300 you probably have his wimpy pe driver.
SULLY12 is offline
post #9 of 11 Old 09-24-2012, 06:09 PM
Face2's Avatar
Quoted: 334 Post(s)
Liked: 202
I have a A5-300 with a plate amp that sends a hum through the woofer(not a ground loop) plus a spare 12" driver. rolleyes.gif
Face2 is offline
post #10 of 11 Old 09-26-2012, 10:43 PM
Looneybomber's Avatar
Liked: 25
How have you isolated your 110v power supply to the amp to eliminate ground loop hum?
YID DIY
Looneybomber is offline
post #11 of 11 Old 09-27-2012, 07:13 AM
Face2's Avatar
Quoted: 334 Post(s)
Liked: 202
Yes, powering up the sub on an isolation transformer and without any other connections hooked up, it still hums.
Now it's taking up space in a spare bedroom...
Face2 is offline
