Newbie - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-29-2012, 01:24 PM - Thread Starter
littlebigarm's Avatar
looking to get a subwoofer and/or build one. dont know where to start. i just ordered klipsch quintet satellite speakers because my basement is small and looking to get a decent sub for under 300 or build under that. thanks
littlebigarm is offline
post #2 of 5 Old 08-29-2012, 06:09 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
What's your size limit for the sub? You can build a sub that will compete performance wise with $500-$600 ID subs for under $300 total. A 20" wide x 20" high x 22" deep OD box made out of .75" material will net you right at 4ft3 volume before port/bracing/driver displacement are considered. This is a very good setup for a ported 12" sub. Take the following components
http://www.amazon.com/Infinity-Reference-1260w-1200-watt-High-Performance/dp/B0028AVGEO/ref=sr_1_1?s=automotive&ie=UTF8&qid=1346288348&sr=1-1&keywords=infinity+1260w
http://www.parts-express.com/pe/showdetl.cfm?partnumber=300-803
http://www.parts-express.com/pe/showdetl.cfm?partnumber=268-352 (use the full port length)
Installed in the above enclosure and you will be capable of the following
A window pane style brace should be used half way through the 22" dimension, with the port off set to pass through one of the cut outs in the brace. The baffle can also be doubled up, which will make the depth 22.75".
After you build a sub like this, and hear the level of performance you're getting for dirt cheap, you might consider building new speakers as well.
Jay1 is offline
post #3 of 5 Old 08-29-2012, 07:13 PM - Thread Starter
Well i appreciate the input. That sounds good and is good prices too. A buddy of mine suggested a sonotube enclosure. Do you think that would give the same quality as od materials?
post #4 of 5 Old 08-29-2012, 07:16 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
OD is outer dimension biggrin.gif Sonotube can work just fine. Personally I prefer a plywood box for all speaker construction.
Jay1 is offline
post #5 of 5 Old 08-29-2012, 07:22 PM - Thread Starter
Aight yeah i should've known that. I'm a little tired right now and was thinking right. But yeah whatever is easier for now might be best.
