SEOS-12 + DNA 360 + Deltalite-II 2512 Build - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #91 of 143 Old 03-20-2013, 02:57 PM - Thread Starter
Scott C.'s Avatar
Thanks for the email, Ryan. It definitely helped me get back on the right track.
Here's a test that's basically the crossover you sent me, with a couple tweaks on the HP. (Ignore the rising response from like 5kHz up. I didn't have a small enough capacitor for the RC contour, so it rises too much right now)
The bass sounds much better now. The problem at about 7-800Hz is there, but I'm working on a design right now that should mitigate that.
Sounds Good to Me... keeping track of my audio projects.
Scott C. is offline
post #92 of 143 Old 03-25-2013, 06:31 PM - Thread Starter
Scott C.'s Avatar
Alrighty. This time I've got the real final design, incorporating some baffle step compensation. Many thanks to tuxedocivic for the help, and guiding me to what I think is a good stopping place.
Here's the circuit that I'll be using for my crossover:
And this is what it looks like inside:
(Horizontal)
(Vertical)
Also, here's a comparison of what it looked like before the BSC design, and the final design. (It also leads me to believe that the hump at about 500 Hz is just from being in the room, since it shows up on both indoor measurements, but not the ones taken outside using the pre-BSC crossover)
I've ordered the parts, and they're on their way. Hopefully by the end of the week I'll have the boards soldered up and installed and I can start enjoying these speakers!
Scott C. is offline
post #93 of 143 Old 03-25-2013, 06:52 PM
tuxedocivic's Avatar
Quoted: 1910 Post(s)
Liked: 1730
500hz is a little high for a room issue but I agree that it is. Also the dip at 225hz. Those are also a multiple of of each other.
Looks great!
Ryan
tuxedocivic is online now
post #94 of 143 Old 03-29-2013, 03:42 PM - Thread Starter
Scott C.'s Avatar
Finally complete and set up! I love these things. They're so clear, especially at high levels. I can listen to these at levels where I was experiencing discomfort with my other speakers. It's been a long process and I'm glad to finally enjoy these.
Many thanks to EricH, tuxedocivic, and Bwaslo for the parts and the help to get these completed!
Here's the finished XO layout:
Before
After
I literally started laughing after I set them up. They look absolutely ridiculous in my tiny space-- especially with my little TV.
Scott C. is offline
post #95 of 143 Old 03-29-2013, 03:58 PM
Sibuna's Avatar
Quoted: 373 Post(s)
Liked: 429
LOL have you seen my pics? i feel the same way
those look great as well
Sibuna is offline
post #96 of 143 Old 03-29-2013, 04:05 PM
Liked: 1730
Ryan
post #97 of 143 Old 03-29-2013, 04:15 PM
btinindy's Avatar
Quoted: 38 Post(s)
Liked: 56
They look really good! Where are you crossing them over to the sub? They should really crank compared to the smaller infinity's. nice work!
btinindy is offline
post #98 of 143 Old 03-29-2013, 04:18 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
Mrkazador is offline
post #99 of 143 Old 03-29-2013, 05:56 PM
Erich H's Avatar
Quoted: 1407 Post(s)
Liked: 1775
Originally Posted by Mrkazador View Post
_______________________
The SEOS Waveguide Project
Erich H is offline
post #100 of 143 Old 03-29-2013, 06:09 PM - Thread Starter
Scott C.'s Avatar
Haha, thanks guys! They're crossed over at 80Hz
Scott C. is offline
post #101 of 143 Old 04-09-2013, 09:06 AM
loudsubz's Avatar
Nice build!
I am thinking about doing the same thing. I have 2 X 2512 and 2 X Delta Pro 12a. I currently have them in a BFM OmniTop 12 but wanted to try something different.
Would these be ok for pro sound applications (small weddings, clubs etc) ?
loudsubz is offline
post #102 of 143 Old 04-09-2013, 10:25 AM
Bill Fitzmaurice's Avatar
Liked: 4663
Originally Posted by loudsubz View Post
Nice build!
You'll give up about 5dB of sensitivity.
Bill Fitzmaurice is online now
post #103 of 143 Old 04-09-2013, 10:44 AM
loudsubz's Avatar
Thanks Bill.
With the Seos-12 WG do you get about the same horizontal dispersion as with the melded array in your cabs?
loudsubz is offline
post #104 of 143 Old 04-09-2013, 11:07 AM
Liked: 4663
Thanks Bill.
Not by a long shot, nor can they be vertically arrayed, and they don't have the vertical pattern control you want for long throws in acoustically bad rooms. For what they're intended for they're a good design, they're just not intended for the same use as OTops are. By the same token that's why OTops aren't recommended for HT use.
post #105 of 143 Old 04-09-2013, 12:18 PM
FOH
FOH's Avatar
Quoted: 38 Post(s)
Liked: 234
Scott, very nice.
Love the before and after pics. Remember to experiment with toe angles.
Bill makes a good point. But yes, for a small wedding, they'd be great properly set-up and aligned with an adequate LF system.
Active 16.8kw, 7.3 system
(2)Seaton SubM-HP, (4)18" IB
FOH is offline
post #106 of 143 Old 05-08-2013, 12:34 PM - Thread Starter
Scott C.'s Avatar
Well I finally managed to get outside to test out the final crossover design, and I have to say I'm much happier with the low end. Where it used to roll off starting at 500Hz, it's now rolling off at 100Hz outdoors. It looks a little different than I remembered on the upper end, but I guess that's just because I never got to test the final design outdoors. I've still got a lot to learn, but I'm very happy with this design. +/- 2.5 dB is good enough for me.
Anywho, here are the plots. This first one is an overlay of all 3 of the speakers. They're very consistent.
Next is the horizontal plots. I forgot to include the legend, but each trace is 10* farther off axis.
Scott C. is offline
post #107 of 143 Old 09-17-2013, 10:27 PM
LTD02's Avatar
Quoted: 2341 Post(s)
Liked: 2578
bump. that looks quite nice!
Listen. It's All Good.
LTD02 is offline
post #108 of 143 Old 09-18-2013, 08:11 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2684
Nice bump. I am going to give this thread a thorough read. Lots of good in here. biggrin.gif
Mfusick is offline
post #109 of 143 Old 10-04-2013, 02:12 PM - Thread Starter
Scott C.'s Avatar
Thanks guys. Just moved a couple months ago (and upgraded the video portion of my setup biggrin.gif). Unfortunately there still isn't a good spot for my third one. I'll just have to wait until I can have a dedicated room. The MFW-15 subs actually ended up working very well as stands for these. It's not the perfect placement for the subs, but it does well enough, and puts the SEOS right at ear height.
Overall I'm extremely pleased. I've cranked these bad boys up a few times, and either I have some very tolerant neighbors or the construction of this place is unnaturally good. Either way I try not to push my luck.
LTD02 likes this.
Scott C. is offline
post #110 of 143 Old 10-04-2013, 02:18 PM
cuzed2's Avatar
Quoted: 187 Post(s)
Liked: 236
Scott C.,
MFW-15s for stands?
Your setup looks good.
Cuzed2
CuznEddy Cinema
cuzed2 is online now
post #111 of 143 Old 10-05-2013, 03:21 PM
LTD02's Avatar
Liked: 2578
so the all important question is...did it count for course credit? :-)
LTD02 is offline
post #112 of 143 Old 10-05-2013, 07:29 PM - Thread Starter
Scott C.'s Avatar
Scott C. is offline
post #113 of 143 Old 10-05-2013, 08:22 PM
LTD02's Avatar
Liked: 2578
that is a really nice "core" setup that you have there--high sensitivity mid/tops and powered subwoofers to try to keep up. i'm sure that i'll point more than one person to your picture and say..."just do that!"
those walls look a little naked. maybe next project could be to wrap up some rigid fiberglass board with some acoustically transparent material for some mid-bass rear and side wall absorption.
LTD02 is offline
post #114 of 143 Old 10-07-2013, 01:34 PM - Thread Starter
Scott C.'s Avatar
Unfortunately placement isn't ideal for sidewall absorption. Left is open to the dining/kitchen area which is good, but right is a window. I'm looking into some heavy curtains. As for the front wall, the treatments would need to go all the way down behind the speakers, correct? I'm kind of my own enemy in this case since this is my general (only) living area and I think it would look weird to have something on the wall go down behind the speakers. Thankfully the waveguides help in those respects, and I don't mind waiting for a dedicated room to reach that next level smile.gif. If I could do it now, though, that'd be great. Any suggestions?
Scott C. is offline
post #115 of 143 Old 10-07-2013, 08:54 PM
LTD02's Avatar
Liked: 2578
just think'n about that rear wall and your mid-bass...
maybe something simple like this:
http://www.mh-audio.nl/CancellationFreq.asp
LTD02 is offline
post #116 of 143 Old 10-07-2013, 08:59 PM - Thread Starter
Scott C.'s Avatar
Hmm. I might be able to make something work. Do you think 2" of oc703 or whatever number it is would attenuate enough of the midbass?
Scott C. is offline
post #117 of 143 Old 10-07-2013, 09:07 PM
LTD02's Avatar
Liked: 2578
http://www.bobgolds.com/AbsorptionCoefficients.htm
Scott C. likes this.
LTD02 is offline
post #118 of 143 Old 10-08-2013, 06:18 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 176
I would go with two 2' by 4' panels made out of two layers of stacked 2" OC703 behind the mains on the front wall. So that would be 4" total and I would recommend using a 4" air gap between ths panel and the wall.
LTD02 likes this.
Martycool007 is offline
post #119 of 143 Old 10-08-2013, 08:24 AM
LTD02's Avatar
Liked: 2578
+1
LTD02 is offline
post #120 of 143 Old 10-08-2013, 11:16 AM
FOH
FOH's Avatar
Quoted: 38 Post(s)
Liked: 234
I agree and often point out SBIR effects too.
However, if possible, one can also move the mains backward as close as possible to the boundary. Thus raising the interaction frequency up out of the omni range, and more into the directional range.
Or, just for argument, best case results yielded from full baffle wall, flush-mounted, of course not applicable here, but want to illustrate the theoretical ideal (half space/2pi loading efficiencies, no SBIR, low diffraction).
Scott C, love the nice clean system, nice pic, thanks for sharing ..
FOH is offline
