Subwoofer front of box loose, rattling - PSW505 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 08-31-2012, 12:29 AM - Thread Starter
Fred Colclough's Avatar
Hi all, i have a PSW505, got it scratch and dent, and it has no front faceplate and the piece of wood that is on the front is loose on top (see pictures). when it hits hard it smacks the wood behind/ around it and rattles really bad. If i hold it in, i can blast it and i was even playing with it earlier and my upstairs neighbors came down and said apparently the entire building shook! (i was very impressed with what it can do).
Was just wondering what the best course of action would be.. fill the gap with silicon? try to screw it in in a few places? (wouldn't be great aesthetically), other ideas?
Much appreciated!
Fred
Fred Colclough is offline
post #2 of 7 Old 08-31-2012, 12:35 AM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
I'm guessing that piece is just aesthetic. Gluing it up with adhesive, like the mentioned silicon should do the trick.
Jay1 is offline
post #3 of 7 Old 08-31-2012, 12:53 AM - Thread Starter
I agree I think it's aesthetic too, I took the back plate off but theres so many panels inside you can't get to the front.
Is there any special type of silicon? my roomate suggested rubberized or...? I just don't want it to hit anything hard if it wiggles its way more loose and start rattling again.
post #4 of 7 Old 08-31-2012, 12:58 AM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
I would use PL Premium, which is polyurethane construction adhesive. You can find it at places like Lowes/HD.
http://www.homedepot.com/buy/loctite-10-oz-pl-premium-polyurethane-construction-adhesive-1390595.html#.UEBgm5YnAkQ
Jay1 is offline
post #5 of 7 Old 08-31-2012, 01:05 AM - Thread Starter
awesome, thanks! much appreciated!
post #6 of 7 Old 08-31-2012, 06:39 PM
jayHRC51's Avatar
Polyurethane glues expand as they cure, like spray foam insulation just at a much slower rate. If its wood to wood contact just use regular wood glue and a couple clamps. Or if you need to bond wood to plastic use silicone caulk and packing tape if you don't have any clamps...both are much easier to cleanup and less noticeable. Just make sure you allow adequate cure time, silicone takes a while to fully cure.
jayHRC51 is offline
post #7 of 7 Old 08-31-2012, 06:42 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
I've used PL a ton, if it expands it's extremely minimal (not an issue). Gorilla glue on the other expands like crazy.
Jay1 is offline
