DIY Thx ultra 2 subwoofer - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 87 Old 09-01-2012, 06:31 PM
saabracer23's Avatar
Liked: 29
Oops double post. Shout out for the Oregon ducks tonight!
Dan
saabracer23 is offline
post #62 of 87 Old 09-01-2012, 06:34 PM - Thread Starter
BloodFX's Avatar
Whats possible with this driver?
http://tcsounds.com/product/drivers/lms-ultra-5400/
BloodFX is offline
post #63 of 87 Old 09-01-2012, 06:35 PM
michael hurd's Avatar
Quoted: 94 Post(s)
Liked: 94
Originally Posted by BloodFX View Post
Where can i view that flat pack or buy it?
You can't buy that flat pack.... that was a picture from the Hope Arkansas plant.
What this world needs is a good 10 watt loudspeaker.... one that can produce 10 acoustic watts without spontaneous combustion.
michael hurd is offline
post #64 of 87 Old 09-01-2012, 06:37 PM
LTD02's Avatar
Quoted: 2499 Post(s)
Liked: 2832
"The greater sd and Xmax of the SVS will surely make it louder at the higher frequencies."
sd and xmax combine to create swept volume. that is what limits low frequencies. the high frequencies are limited by sensitivity and power.
"So if the driver has more sd and more Xmax that can't be good, there's going to be port compression."
that would be true if the ports were too small, but the ports on the svs are just fine.
"It is well documented that if even one port is plugged that the port chuffing is quite audible."
i'm not sure what your point is. if you have less port area, the air velocity increases. once you go past a certain point, you get chuffing. the reason the subwoofer has three ports is that at full volume, three ports are needed to keep air velocity below the point of chuffing.
Listen. It's All Good.
LTD02 is offline
post #65 of 87 Old 09-01-2012, 06:38 PM - Thread Starter
BloodFX's Avatar
BloodFX is offline
post #66 of 87 Old 09-01-2012, 06:40 PM
LTD02's Avatar
Liked: 2832
ricci and ilkka have tested it in a number of cabinets. it is one of the best. looks like ricci needs to re-test, but ilkka's data is available.
summary report:
http://www.hometheatershack.com/forums/home-audio-subwoofers/6656-subwoofer-tests-fall-2007-a.html
index of subs:
http://www.hometheatershack.com/forums/subwoofer-tests-archived/6015-index-subwoofer-tests-manufacturer-model.html
it is equivalent to between 3 and 4 epic12 subs if that helps.
LTD02 is offline
post #67 of 87 Old 09-01-2012, 07:02 PM
Liked: 29
What I'm saying is the driver in the SVS is limited in its cabinet. The ports are not fine. When you get chuffing, you get compression, you limit low end capabilities. Just like with the klipsch, it could do better in a better box. So do you disagree with the comment made about the infinity 120.9w possibly besting the SVS? I can get you a link to the build if you wish.
As LTD02 said, the LMS ultra is one of if not the best driver out there, but at a cost. I'd rather get 4 tc epics, have more output and place them around the room to smooth out your response.
Dan
post #68 of 87 Old 09-01-2012, 07:21 PM
LTD02's Avatar
Liked: 2832
"So do you disagree with the comment made about the infinity 120.9w possibly besting the SVS?"
yeah, i kind of do. the infinity 120.9w has 17.50 mm xmax and less sd than the driver in the pb13u. in 20hz tuning mode, the svs will have about 4db more excursion limited spl than the infinity. that is a pretty big beat. doubling drivers gives an additional 3db, so *two* 120.9w's might give *one* svs sub a run...
120.9w specs:
http://eu.infinitysystems.com/tl_files/catalog//Infinity/Infinity-Car/Specsheets/Kappa/Kappa/9-Series/120.9w/KAPPA120-9w_PI_EN.pdf
i'm not taking anything away from the infinity driver and the epic is in between the two.
"I'd rather get 4 tc epics, have more output and place them around the room to smooth out your response."
+1
LTD02 is offline
post #69 of 87 Old 09-01-2012, 07:33 PM
MKtheater's Avatar
Quoted: 1717 Post(s)
Liked: 1251
Originally Posted by saabracer23 View Post
The one problem with the klipsch subs is volume. Their somewhat tiny. Klipsch isn't going to be able to convince as many people to purchase 6 cubic foot ported subs, that's why is should be fairly easy to best them with quality drivers.
Dan
The only Problem with the KLipsch THX subs were price! The duals bested my SVS PB12/plus/2. Both ported, both dual 12's, almost the same power. The Klipsch had better extension and spl when the SVS was in 16hz mode which the Klipsch could go down to pretty good. The klipsch were better, however, the SVS was $1200 and the Klipsch were $3600 retail. I got the klipsch for $1500 and for that price better than the SVS, not worth it retail.
Marantz 7702 Atmos
Outlaw 7140 and 5000
Speakers- DIY mini arrays for fronts and BFM TLAH for surrounds
subs 2 XXX ported SLLT powered by IPR2-7500.
MKtheater is offline
post #70 of 87 Old 09-01-2012, 08:42 PM
LTD02's Avatar
Liked: 2832
looks like that infinity is only $136 with free shipping from newegg right now, which is a pretty good deal.
http://www.newegg.com/Product/Product.aspx?Item=9SIA1270921664&nm_mc=KNC-GoogleMKP&cm_mmc=KNC-GoogleMKP-_-pla-_-NA-_-NA
four of those would be $560 in drivers and they only need a 2000 watt amp to push the driver to its limit in a 5-6 cubic footer tuned to 16-20hz, which you can pick up for $400 in an inuke nu3000dsp. so, a little over full reference in a largish room with integrated equalization and four sources for under $1k plus wood? that is a tremendous bang for the buck.
a more expensive option would be something like this:
http://www.istonline.ca/mach5_uxl_18.html
step up to a more expensive amp, inuke nu6000dsp and put one driver on each channel. that would be another win. ten cubic footers each tuned to around 16hz will give you 124db or so in 2pi space down to 15hz and you won't be approaching the drivers' limits.
LTD02 is offline
post #71 of 87 Old 09-01-2012, 09:09 PM
Liked: 29
You could also get 8 infinity 1262w for $60 each shipped. They have 13mm Xmax each. 8 would put you at $480 for drivers, nice amp and materials should be under $1000. Only problem is placing 8 subs! I'm limited to having two :-( so I went with better quality drivers to get the most I could. Plus I have to have smaller cabinets, gotta please the wife.
Dan
post #72 of 87 Old 09-01-2012, 09:47 PM
LTD02's Avatar
Liked: 2832
i like that idea, but now you are pushing 40 cubic feet of subs. :-)
LTD02 is offline
post #73 of 87 Old 09-02-2012, 08:19 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 181
How would an Infinity Kappa Perfect 12 perform in a 300L sonotube compared to a TC Sounds Epic 12 in a 200L sonotube, both powered with a 600watt amp?
Martycool007 is offline
post #74 of 87 Old 09-05-2012, 08:36 AM - Thread Starter
BloodFX's Avatar
Are there any tutorials i can look at for designing speakers, subs and enclosures, also software to design them?
I just feel i want to educate myself some more as i feel out of my league at the moment ><.
Also what equipment do i need for testing speakers frequency's etc?
BloodFX is offline
post #75 of 87 Old 09-05-2012, 09:22 AM
RyguyOK's Avatar
Man, I've been lurking on this forum for years, and I still feel out of my league biggrin.gif
RyguyOK is offline
post #76 of 87 Old 09-05-2012, 09:42 AM - Thread Starter
BloodFX's Avatar
BloodFX is offline
post #77 of 87 Old 09-05-2012, 09:50 AM
tuxedocivic's Avatar
Quoted: 2177 Post(s)
Liked: 2047
Pick an area first.
Sealed subs
Ported subs
TL
EQ
Drivers
Active cross overs
Passive cross overs
Horns
etc.
What do you want to know about. It's going to be a little over whelming. I'd start by learning what you want to build. Like a subwoofer that meets Ultra 2 specs wink.gif
My youtube channel: Impulse Audio
tuxedocivic is offline
post #78 of 87 Old 09-05-2012, 09:57 AM - Thread Starter
BloodFX's Avatar
Originally Posted by tuxedocivic View Post
Pick an area first.
Sealed subs
Ported subs
TL
EQ
Drivers
Active cross overs
Passive cross overs
Horns
etc.
Ported subs how do you work out the size, the size of the port, tuning and what driver to put inside it?
Also whats the difference between ported and sealed?
BloodFX is offline
post #79 of 87 Old 09-05-2012, 11:18 AM
Smigro's Avatar
Quoted: 237 Post(s)
Liked: 221
I am new to all of this "building your own speakers" stuff too. I am planning on going with a sealed sub because from what I am told they are a bit easier to do as a beginner and they take up less space. I have no idea how to come up with the design, but someone from here was nice enough to plug some info. into winISD (or whatever the program is called) and let me know how big my enclosure needed to be and how much power I would need. My plan it to make a couple dual opposed 15" sealed enclosures and to power them with a iNuke6000.
I could be wrong here and if so I am sure I will be corrected, but from the info I found and what I was told the difference between a sealed sub and ported sub is basically the sound you get and how loud or how low they will go. From what I gather a sealed sub in the right enclosure and right amount of power will give you good FR down into the low teens. A ported sub will most likely have more output above it tuning frequency but if it is tuned for say 16 Hz it will drop off steeply at that 16Hz frequency. So it all really depends on what you want. To me it seems if you want really loud reference bass you will go with ported but if you want that subsonic bass that you feel as opposed to hear and don't need massive output go with sealed.
Like I said though I am new to all of this too, so take what I say with a grain of salt until someone else chimes in.
Ed
Panasonic VIERA TC-P60ST60 Plasma, Onkyo TX-NR1008 receiver, OPPO BDP-83 region free, Xbox One, PS4, eD[c]12 LCR, Klipsch R-14M surrounds, Rythmik FV15HP sub
Xbox GT / PSN ID - Smigro
BD collection http://www.blu-ray.com/community/col...0&categoryid=7
Smigro is offline
post #80 of 87 Old 09-05-2012, 11:36 AM
Liked: 2047
For the basics like that, google works well. You're also on the right forum. Start a thread, ask questions. Good luck.
post #81 of 87 Old 09-05-2012, 11:53 AM - Thread Starter
BloodFX's Avatar
My local cinema has massive ported subs with thx ultra 2 certification so does that mean they are tuned for 20hz @ -6db?
Also if they are can i get the same with a sealed sub?
BloodFX is offline
post #82 of 87 Old 09-05-2012, 12:05 PM
Smigro's Avatar
Quoted: 237 Post(s)
Liked: 221
This I would not know, but I guess you could assume. But you do know what they say about people that assume things. biggrin.gif
You could probably do better with a sealed sub...if you have enough power going to the driver. From what I have learned if done right you can get a sealed sub down into the low teens even single digits with the right components.
Ed
Smigro is offline
post #83 of 87 Old 09-05-2012, 12:21 PM - Thread Starter
BloodFX's Avatar
Yea i had a brief look at that WinISD Smigro and i have to say i don't have a clue how to use it lol.
BloodFX is offline
post #84 of 87 Old 09-05-2012, 01:02 PM
Smigro's Avatar
Quoted: 237 Post(s)
Liked: 221
At least you could look at it. I am in the market for a new computer so I could not even look at it and my work computer needs admin approval before DL'ing any programs.
Ed
Smigro is offline
post #85 of 87 Old 09-05-2012, 02:18 PM
Point Source
beastaudio's Avatar
Quoted: 4023 Post(s)
Liked: 3341
Most definitely. But most would say that you want to AT LEAST be -0 at 20hz. With two sealed 18's I am able to get a flat reference response to below 10hz. Now that is the ultimate. THX standard simply states a requirement for mixers to adhere to, but many in this area of AVS go way above and beyond that since we can.
Sealed is going to be a little easier to design and build, will be smaller, but will require more power, and probably multiple speakers to get enough output to make you happy. Ported will be a little more difficult to build but not much, the box will be bigger, but there will be more output down to its tuning frequency at which point it becomes useless. to put it one way, my 18's that I have sealed are in 22x22x30 boxes which is pretty big for sealed, but my ported 15's are in boxes made from round tubes that are 24 inch diameter and 6 feet tall!! I jhad to go this big to get the box to play as low as possible, but that is still only down to 12hz. Bottom line is start a thread, state your budget, your main goal, room size and what else you have to work with and plenty of folks will chime in to help you get a good design going.
beastaudio is offline
post #86 of 87 Old 09-05-2012, 05:21 PM
Smigro's Avatar
Quoted: 237 Post(s)
Liked: 221
Nice to know that most of what I said was correct. At least that gives me the feeling that I am learning something from you guys. biggrin.gif
Ed
Smigro is offline
post #87 of 87 Old 09-06-2012, 06:37 AM
Point Source
beastaudio's Avatar
Liked: 3341
Absolutely, you're getting it alright!! I feel I should put a caveat in there from my previous post. I am heavily biased towards sealed designs. Ive just tried everything else and with the exception of possibly ported mains, everything else is just easier and better sealed in the bass category. Yes it does cost more and takes more to outgun a ported system, but once you have that, you will never turn back. Ive tried tapped horns, heard front loaded horns, standard ported, LLT (Large Low Tuned), etc. The only one I have yet to cross off my list is an IB (infinite baffle) setup, and I guess a rotary sub, but both of those are out of the question for me so Im not in too big of a hurry...
