My New Folded Horn Design!!! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 33 Old 09-02-2012, 11:20 PM - Thread Starter
mtyler7807's Avatar
This is my new folded horn design. I needed feed back to see if I need to change anything. I am about half way on 2 of the cabinets. I got two eminence 18's on the way now. to put in them. each one will stand about 4 feet high. I got the dimensions out in the shop. I can get them to someone if they need them. Right now I have 2 Peavey black widows in single peavey cabinets and I am looking for more bass. the two fifthteen do ok on kick drum and mids but just enough for tonal bass. hopefully this works great. I had priced some new cabinets but they just cost to much compared to what it would cost to build them for. I can build and load 3 of these with 18's for the price of one of those cerwin vegas. So do you all think it is a good design? I used google sketchup to make the blue print designs the best I could. At the top where the access panel for the woofer it will be double ply of 3/4" MDF. Every thing glued and screwed and I'll coat the whole cabinet with armor plate.
mtyler7807 is offline
post #2 of 33 Old 09-03-2012, 02:26 AM
Brad Horstkotte's Avatar
Liked: 68
Did you use hornresp or similar to model the horn?
Brad Horstkotte is offline
post #3 of 33 Old 09-03-2012, 06:59 AM
Bill Fitzmaurice's Avatar
Liked: 4628
+1. The horn path length appears far too short to work well as a subwoofer, maybe half what it should be. Where folded horns are concerned the best results come from using as small a driver as has sufficient Vd for the application in as large a horn as packspace will allow, not as large a driver as will fit into as small a cabinet as possible. The Cerwin Vega folded horns are fine examples of how a folded horn sub should not be built. And assuming that these are intended for portable pro-sound use you do not want to build them from MDF; well braced 1/2" BB plywood is far stronger but much lighter.
Bill Fitzmaurice is online now
post #4 of 33 Old 09-03-2012, 08:02 AM - Thread Starter
mtyler7807's Avatar
I figured i may have something wrong. thanks for the quick response. I still have time to add to the height and depth of the cabinet. i have made a really rough chaange diagram. it will be taller on the top. i added a longer port inside.
post #5 of 33 Old 09-03-2012, 08:04 AM - Thread Starter
mtyler7807's Avatar
post #6 of 33 Old 09-03-2012, 08:15 AM
Assoc. Editor @ AVS Forum
imagic's Avatar
Quoted: 4939 Post(s)
Liked: 8364
If you shrink the driver, the horn effectively becomes larger. When you re-design, consider that fact and that a quality 12" is a better driver size for something like this. At 12" you will get more performance for your money, a good 18" costs much more. I hate to say it but the Eminence 18's are going to sound muddy in your application. I owned one of these: B-52 LX1818 which use Eminence 18's. It never lived up to it's specs, for the exact same reason your design is likely to be compromised. Shrink the driver, or be prepared to build a horn that takes up half a room.
Mark Henninger
imagic is offline
post #7 of 33 Old 09-03-2012, 08:21 AM
Tom Bley's Avatar
Quoted: 593 Post(s)
Liked: 529
On Bills THT builds I could clearly see and follow the horn path and see it getting larger toward the mouth of the horn but, I can't tell hide nor hair from your sketch or model of what's going on, sorry. I guess I have the same question as Brad. Maybe I should go grab another cup of coffee. smile.gif I'm just here to observe & learn. smile.gif
Tom Bley is online now
post #8 of 33 Old 09-03-2012, 08:30 AM - Thread Starter
mtyler7807's Avatar
I thought for sure those b-52's would sound good. they have a really high price tag. Too high for some wood. I was using 18's to use only two and two peavey 15 cabinets for parties. Do you think the 12's would do the same using two cabinets. or do you want me to put two drivers in each horn cabinet?
post #9 of 33 Old 09-03-2012, 08:40 AM - Thread Starter
mtyler7807's Avatar
do you have a link for bills design. I'm new here. I have bulit alot of subwoofer cabinets for cars, but loud speaker design is a art. I would love to build a awesome cabinet, I could make some money where stay dealing with loud speakers. Everyone down here wants folded horns.
post #10 of 33 Old 09-03-2012, 08:43 AM - Thread Starter
mtyler7807's Avatar
Originally Posted by imagic View Post
If you go to Guitar Center you can see the so-called folded horns that serve as inspiration. They are not good designs, to say the least - http://www.guitarcenter.com/Cerwin-Vega-EL-36C-18--Folded-Horn-Subwoofer-105125371-i1432728.gc
Not so much a horn as a cheap hybrid of T-line, bandpass and pseudo-waveguide. The real goal is to create as loud a mid-bass boom as possible for the least $$$. The confusion comes from the fact that they are marketed as folded horns. T
That is the horn that my friend has that made me want one. He has a QSC 2450 pushing bought of them. His love gogo music for parties and it does the kick drum from the music great from two of them.
post #11 of 33 Old 09-03-2012, 08:44 AM - Thread Starter
mtyler7807's Avatar
Do you have the link for that build. I am new here.
post #12 of 33 Old 09-03-2012, 08:57 AM
Liked: 4628
Instead of wanting what your friend has, go to a music store and audition some subwoofers,
One will not find high quality folded horn subs in music stores. They exist in high end PA cabs from many manufacturers, but they aren't found in G-C and the like.
post #13 of 33 Old 09-03-2012, 09:09 AM - Thread Starter
mtyler7807's Avatar
This will be mostly for smooth jazz, new rap(which has the bass drop), gogo like chuck brown , pure pleasure, new diemsions,etc ( alot of kick drum). I have heard the EV folded horns and the older carvin ones before they came out with the dual 18 T cabinets. With the genre of music I listen two the cerwin vegas did the best over all, for the size of the cabinet. Right now I am using some black widow 15's but they just don't do it anymore. When I stepped up from my Nikko 130 amp(real good amp for being older) to the two crown powerbase 2's.
post #14 of 33 Old 09-03-2012, 09:11 AM - Thread Starter
mtyler7807's Avatar
Thats why I am here. The ones that I have heard are the ones some of friends have. We have one store call winter sound that has a lot of this but you can't listen to them until after you buy them.mad.gif
post #15 of 33 Old 09-03-2012, 09:12 AM
imagic's Avatar
Liked: 8364
Have you checked this out? http://www.guitarcenter.com/EAW-LA400-Bent-Bass-Horn-Subwoofer-100485005-i1171677.gc
edit - from the description: The LA400 defies conventional wisdom, which states that an 18" woofer is required to drive a bass horn. 18" woofers simply do not have the rigidity required to drive the high acoustic impedance present in a horn throat. As a result, traditional 18" bass bins get loud, but only produce one note very well. The LA400 in contrast uses a proprietary heavy duty 12" woofer. The woofer has the motor structure of a traditional 18" device, and its cone is reinforced to be a better engine for compact horn-loading. This woofer is then loaded onto a properly designed bass horn which matches path length to cone area and maximizes driver efficiency. The result is tight, punchy sub bass response that not only will shake your foundation, but is articulate and musical as well.
That's what we're talking about here, they are actually selling it. Copy that design.
Mark Henninger
imagic is offline
post #16 of 33 Old 09-03-2012, 09:24 AM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
Why not build an F20? It's a great design that gets really loud all the way down to 20 Hz. Why reinvent the wheel when you don't have to?
http://www.avsforum.com/t/1329971/lilmikes-cinema-f-20
Processor: Emotiva UMC-200
Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
post #17 of 33 Old 09-03-2012, 09:30 AM - Thread Starter
mtyler7807's Avatar
post #18 of 33 Old 09-03-2012, 09:58 AM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
Why is that so funny?
post #19 of 33 Old 09-03-2012, 10:25 AM
dbldare's Avatar
+1
I think the OP's 'tag line' under his screen name needs to be edited to -- "Bass >40Hz is the answer to everything". Or simply just change it to "Mid-Bass" is the answer to everything....
dbl
Let's all go to the lobby
....Let's all go to the lobby
dbldare is offline
post #20 of 33 Old 09-03-2012, 01:17 PM
Point Source
beastaudio's Avatar
Quoted: 3487 Post(s)
Liked: 2821
I would second the f-20. For outdoor parties it would kill. especially for that "bass drop" you are looking for. just for music, you dont need to get much lower and the output is rediculous with a very modest pricetag.
beastaudio is offline
post #21 of 33 Old 09-03-2012, 02:58 PM
Liked: 4628
It's not suited for pro-sound use, which has little to no needs below 35Hz, and sensitivity is all important.
post #22 of 33 Old 09-03-2012, 03:06 PM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
The build lists the sensitivity between 92-94. That looks pretty good to me. Plus you're biased! You just want him to build one of your Tubas! But you're right. The sensitivity of your models are well above the F-20.
post #23 of 33 Old 09-03-2012, 03:12 PM
Point Source
beastaudio's Avatar
Liked: 2821
Not to mention the OP wants some of the lower than 35hz stuff you get with some of the new rap tracks. Not to say that a good high(er) efficiency pro cab wouldnt do the trick, cuz it would as well. Just thinking of good horn designs with good bottom end down to 20hz..
post #24 of 33 Old 09-03-2012, 03:14 PM
Tom Bley's Avatar
Quoted: 593 Post(s)
Liked: 529
http://www.billfitzmaurice.info/THT.html
mtyler7807 likes this.
post #25 of 33 Old 09-03-2012, 05:52 PM
Liked: 4628
I don't care what he builds, but if it was a Tuba the last one I'd recommend would be a THT, for the same reason: wrong tool for the job.
post #26 of 33 Old 09-03-2012, 07:47 PM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
I should have been more specific. I meant to say one of your Tuba Pro designs. They are very impressive.
post #27 of 33 Old 09-06-2012, 07:10 PM - Thread Starter
mtyler7807's Avatar
Sorry about the slack off, been stuck at work for a couple of days. Going threw post now to get the right idea of what to do. Good site so far.
post #28 of 33 Old 09-06-2012, 07:11 PM - Thread Starter
mtyler7807's Avatar
Sure do, he posts here quite a bit
post #29 of 33 Old 12-22-2012, 06:27 AM
okopti's Avatar
Hi I really like you design and would like to have them. If you should have one for MID HIGH I would love them
Okpoti
okopti is offline
post #30 of 33 Old 12-22-2012, 07:30 AM
Gaugster's Avatar
Quoted: 63 Post(s)
Liked: 56
I struggled like many to balance driver size and cabinet size. After reading as much as I could find, one of the main parameters is to match the woofer to the enclosure.
That said, the recommendation to downsize to a smaller diameter woofer sounds like very good advice. The goal being to match the self resonance of the speaker too the path length of your box.
This is the last thing you want to compromise.
Gaugster
Gaugster is offline
