SEOS-12 / DNA-360 / Delta 10A build - AVS Forum | Home Theater Discussions And Reviews
post #1 of 72 Old 09-05-2012, 10:30 AM - Thread Starter
lukeamdman's Avatar
Quoted: 1071 Post(s)
Liked: 1187
I started a new thread since I ended up not using any of the drivers I listed in the title of my previous thread. Construction of these starts tomorrow!
Outside dimensions of the box:
22” tall, 14.5” wide, and 9.25” deep. The front baffle, top, and bottom of the enclosures are being doubled up to 1.5”. I’ll add bracing between the 10A and the DNA-360.
After the port, bracing, and drivers the internal volume should be right around .90 cu.ft.
The slot port will be 8.25” wide, 1.5” tall, and 4.75” deep (includes the 1.5” from the front baffle). That should make a 70hz tune or very close to it.
Using my DCX I’ll fine tune the crossovers points/slopes and then build passive crossovers.
UPDATE:
lukeamdman is offline
post #2 of 72 Old 09-05-2012, 04:27 PM - Thread Starter
lukeamdman's Avatar
Liked: 1187
post #3 of 72 Old 09-05-2012, 10:25 PM
tuxedocivic's Avatar
Quoted: 1903 Post(s)
Liked: 1724
I just finished measuring my speaker. You gotta shut this woofer down above 2khz. The final result is very impressive though. Have fun smile.gif
Ryan
tuxedocivic is online now
post #4 of 72 Old 09-06-2012, 05:21 AM - Thread Starter
lukeamdman's Avatar
Liked: 1187
You end up going sealed or ported?
post #5 of 72 Old 09-06-2012, 09:43 AM
Liked: 1724
Sealed. But I'm going to try ported. Just lazy and wanted to get the cross over figured out first. Here's my results: http://www.diysoundgroup.com/forum/index.php?topic=68.msg647#new
That's with a different compression driver though.
Ryan
post #6 of 72 Old 09-06-2012, 12:33 PM - Thread Starter
lukeamdman's Avatar
Liked: 1187
Wow, very nice!
post #7 of 72 Old 09-06-2012, 12:35 PM - Thread Starter
lukeamdman's Avatar
Liked: 1187
post #8 of 72 Old 09-07-2012, 07:37 AM
BeerParty's Avatar
Originally Posted by lukeamdman View Post
All the wood is cut, and these two pieces need to dry for 24 hours
Using a nail gun sure beats pre-drilling and screws!
If you are using a nail gun why do you have to wait 24 hours? I thought the whole point of using the nail gun was so that you didn't have to wait for the glue to dry.
Chris
--Despair, Inc. "Regret"
My AviaTrix TM Build
BeerParty is offline
post #9 of 72 Old 09-07-2012, 10:59 AM
Brad Horstkotte's Avatar
Liked: 68
Woot another SEOS build, booya.
+1 on waiting for glue to dry - I glued and screwed, and got all three back boxes put together in one go.
Brad Horstkotte is offline
post #10 of 72 Old 09-07-2012, 12:33 PM - Thread Starter
lukeamdman's Avatar
Liked: 1187
That's true, and on top of that the PL400 I'm using takes longer to dry than Titebond, so you even more time to "work" before clamping. Yesterday I simply ran out of time.
post #11 of 72 Old 09-08-2012, 11:55 AM - Thread Starter
lukeamdman's Avatar
Liked: 1187
post #12 of 72 Old 09-08-2012, 12:39 PM - Thread Starter
lukeamdman's Avatar
Liked: 1187
Look what FedEx just dropped off:
These things are huge!!
There's also no markings on them. How do they tell the 350 from the 360?
I also don't see any mounting hardware, so another trip to Home Depot is in order.
post #13 of 72 Old 09-08-2012, 12:55 PM
Liked: 68
Double check the shipping box (not the individual boxes for the CDs), Erich puts a little baggie with your nuts and bolts in the box unless he forgot on this one.
post #14 of 72 Old 09-08-2012, 01:05 PM - Thread Starter
lukeamdman's Avatar
Liked: 1187
Bingo! Four bolts plus lock washers were taped to a piece of bubble wrap.
post #15 of 72 Old 09-08-2012, 03:24 PM
Erich H's Avatar
Quoted: 1406 Post(s)
Liked: 1768
The 350's and 360's use different sized bolts. Plus the 360's have different style terminals. I'll eventually get stickers for them.
Each waveguide gets wrapped in bubble wrap. Before I tape both waveguides together, I put the bag of bolts between the waveguides. Surprised you didn't see that when you opened them up. You must have really been tearing into those things! biggrin.gif
_______________________
The SEOS Waveguide Project
Erich H is offline
post #16 of 72 Old 09-08-2012, 03:51 PM - Thread Starter
lukeamdman's Avatar
Liked: 1187
You package these things really well. It took a third time going through all the packaging to find the bolts!
How tight should I fasten the CD to the waveguide?
post #17 of 72 Old 09-08-2012, 06:01 PM
bwaslo's Avatar
Quoted: 66 Post(s)
Liked: 182
Tighten it till it doesn't quite break!
Actually, just get it so that the bolts won't come loose and hold the driver firmly to the mounting plate. There won't be a lot of vibration on them so they aren't likely to work loose. Certainly more than finger-tight, but not so tight you'd need more than a small wrench to get them off. Do make sure you get them mounted so the driver port centers into the throat - do it in good lighting.
___________________________________________
DIY Synergy horn spreadsheet Synergy horn spreadsheet and pdf
XSim -free crossover designer and simulator XSim install file
Easy and cheap sound diffusers (the "Depot Diffusers") making easy DIY depot sound diffuser-panels-step by step.html
SmallSyns - point source controlled directivity in a manageable size SmallSyns
bwaslo is offline
post #18 of 72 Old 09-08-2012, 10:11 PM
Jon_B's Avatar
Quoted: 25 Post(s)
Added the slot port:
Doubled up the top and bottom:
How did you figure out the dimensions of the slotted port? I see lots of programs that give the dimensions for a cylinderical port but not for a slotted port.
Jon_B is offline
post #19 of 72 Old 09-08-2012, 10:15 PM
Liked: 68
WinISD will do circular or rectangular ports
post #20 of 72 Old 09-08-2012, 10:20 PM
Jon_B's Avatar
Quoted: 25 Post(s)
Cool, thanks Brad
Jon_B is offline
post #21 of 72 Old 09-09-2012, 02:06 AM
karlsonkab's Avatar
that is way cool - I've tried Delta 10A in a little Karlson cabinet topped with a slotted pipe waveguide and can get some serious punch. Were you tempted to do a dustcap transplant or does your lowpass pretty much kill the audibility of the dustcap's resonances? what is your lowpass filter? does it have some BSC? Is there a screw on version of that cool lookin' driver available? - I need something for coaxials. Some slot and R-J ports seem to come in ~15% lower than prediction.
karlsonkab is offline
post #22 of 72 Old 09-09-2012, 11:25 AM - Thread Starter
lukeamdman's Avatar
Liked: 1187
Sorry man, I don't really know what you're talking about. I'm new to this.
Dust cap transplant? BSC? Screw on version?
post #23 of 72 Old 09-09-2012, 02:34 PM
karlsonkab's Avatar
under pink noise, Delta 10A's dustcap seems to have some pronounced resonances. Removing it and going to a smaller & softer dustcap might help - but its a gamble - -hopefully the crossover will prevent those resonances from being excited. "BSC" = "baffle step compensation" and is often done to get a reasonably good bass to treble balance as low frequency waves will wrap around a free standing cabinet. It can be done with a larger inductor in the lowpass section or a resistor in parallel with an inductor. Re: "screw-on" - IIRC, (?) Erich mentioned one of the big compression drivers manufactured as a regular 1 3/8" thread which will screw on to standard threaded horns/waveguides and coaxial woofers. What crossover are you using?
post #24 of 72 Old 09-09-2012, 03:40 PM - Thread Starter
lukeamdman's Avatar
Liked: 1187
At first I'm going active with a DCX2496. Once I find what makes these drivers work really well together I'll build a passive.
From what I've seen from these two drivers, I'm guessing the crossover point will be somewhere around 1,500-1,600hz.
post #25 of 72 Old 09-09-2012, 08:19 PM - Thread Starter
lukeamdman's Avatar
Liked: 1187
I just weighed the boxes as they sit now with no front baffle (1.5"), no drivers, no cross bracing, and no polyfill at 21lb's. These should weigh around 45lb's when complete!
post #26 of 72 Old 09-14-2012, 10:38 PM - Thread Starter
lukeamdman's Avatar
Liked: 1187
post #27 of 72 Old 09-17-2012, 08:22 AM
BeerParty's Avatar
Had my dad over to help with this portion, and we were making great progress until the bit broke.
How deep were you cutting into the MDF when the bit broke?
You should only be cutting about 1/4" deep with multiple passes, otherwise the bit will overheat.
Chris
post #28 of 72 Old 09-17-2012, 10:27 AM - Thread Starter
lukeamdman's Avatar
Liked: 1187
These were 3/8".
So cutting these incrementally is better for the bits?
post #29 of 72 Old 09-17-2012, 11:23 AM
Liked: 68
Yup definitely. Also, I don't think you mentioned what type of bit you used, but an up spiral works well, helps clear the debris out of the path (vs. a plain flute bit).
post #30 of 72 Old 09-17-2012, 11:28 AM - Thread Starter
lukeamdman's Avatar
Liked: 1187
It was a 1/4" straight bit. I was trying to go pretty slow, but the bit was really hot when it broke.
