IB box design question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-10-2012, 11:20 AM - Thread Starter
Silock's Avatar
I have 4 AE IB15s. Should I design the box as a cube, so that I have 3 mounted vertically and 1 on top, or should I build a longer box with 2 opposing each other?
I have room for either design, and I've seen it done both ways, but I'm not sure which way is best, or if it even matters.
Silock is offline
post #2 of 3 Old 09-10-2012, 01:48 PM
Point Source
beastaudio's Avatar
Quoted: 3592 Post(s)
Liked: 2896
Id go two opposing each other as that will be the only way to keep the box inert. The other way yields itself to box vibrations.
beastaudio is offline
post #3 of 3 Old 09-10-2012, 02:43 PM
Bill Fitzmaurice's Avatar
Liked: 4903
To clarify, opposing does keep the box from dancing, as there are equal but opposite forces to prevent that issue. Opposing per se doesn't do anything to stop vibration of the box panels, though the smaller baffle/back that opposing allows helps in that regard. But I'd still go with all separate boxes, for the better placement options that allows.
Bill Fitzmaurice is online now
