Seos 12 plastic or fiberglass - AVS Forum | Home Theater Discussions And Reviews
Old 09-10-2012, 01:22 PM - Thread Starter
ozziedog's Avatar
Liked: 24
Can anyone tell me if there is a performance difference between the fiberglass Seos 12 and the plastic Seos 12. I am sure the fiberglass looks better but is it worth the extra cost?
ozziedog is offline
Old 09-10-2012, 02:07 PM
bwaslo's Avatar
Quoted: 66 Post(s)
Liked: 182
No perf diff. The most inert one would be the 'solid surface' one, but all are so thick it wouldn't matter.
___________________________________________
DIY Synergy horn spreadsheet Synergy horn spreadsheet and pdf
XSim -free crossover designer and simulator XSim install file
Easy and cheap sound diffusers (the "Depot Diffusers") making easy DIY depot sound diffuser-panels-step by step.html
SmallSyns - point source controlled directivity in a manageable size SmallSyns
bwaslo is offline
