Need help with an ebay purchase!! and a AMP - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 09-11-2012, 09:46 AM - Thread Starter
tdheywood's Avatar
Hi everyone i'm new to this so please help
As part of my collage course work one of the tasks is to create and buld your own speaker system...
I wanted to go my own way as everyone else is making cheap, tacky speakers supplied by the collage its self. Listens to them and they are sh*t.mad.gif Obviously i'm on budget and these are my choices:
http://www.ebay.co.uk/itm/230818597727?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649#ht_3599wt_1041
Willy, the man who sells them, said he has had excellent feedback form these but i need a AMP to work with these under 100W. Can anyone help me out with a AMP????
Tom
if you want you can always email me if you want a little more info? tdheywood@yahoo.co.uk
tdheywood is offline
post #2 of 10 Old 09-11-2012, 11:13 AM
A9X-308's Avatar
Quoted: 1506 Post(s)
Liked: 1142
Because speakers are rated at 100W, does not mean you need to use an amplifier <100W. Speakers do not behave like a fuse whereby when you exceed rating *poof* they are destroyed.
Local ebay will turn up hundreds of integrated amplifiers or older AVRs at a suitable price.
“You are not special. You are not a beautiful and unique snowflake.” Chuck Palahniuk
A9X-308 is offline
post #3 of 10 Old 09-11-2012, 11:17 AM - Thread Starter
tdheywood's Avatar
Oh so i can use a AVR to power the speakers becuase after all they will next to my TV's AVR?
Thanks for your help.. Im not clued up on this
Tom
post #4 of 10 Old 09-11-2012, 12:18 PM
beastaudio's Avatar
Quoted: 4147 Post(s)
Liked: 3504
I didn't know collages offered courses? wink.gif work on those phonetics playa.
Could you maybe swing something similar to this and start over?
http://www.diysoundgroup.com/speaker-kits/small-kits/os-speaker-kit.html
beastaudio is offline
post #5 of 10 Old 09-11-2012, 03:21 PM - Thread Starter
tdheywood's Avatar
Haha :-) that's hat I'm looking for but not the housing as it needs to be build myself from scratch :-( can you give me an idea of what type of AMP I need for the speakers I was going to buy?
Hope you can help me as I'm a little confused...
T
post #6 of 10 Old 09-11-2012, 07:15 PM
Quoted: 3891 Post(s)
Liked: 3327
So I'm grading your course work and I see you bought a speaker kit, with a pre-assembled crossover. Right away even if it looks and sounds good the best grade you get from me is a C+, If you want an A you need to do some reading on crossovers and build your own from resisters, inductors (coils) and capacitors.
Show a worksheet where you worked out the formulas for the values of the resistors. Impress me and show the resource you used to calculate the size of wire and the number of windings that went into the coil.
post #7 of 10 Old 09-11-2012, 10:38 PM - Thread Starter
tdheywood's Avatar
The speaker quality doesn't matter.... It's the casing that does as it needs to be build with strong joints such as dove tail... I'm not botherd for any A* sounding speakers providing it works.
(my marker is old)
post #8 of 10 Old 09-16-2012, 03:54 PM
ItchyTasty42's Avatar
I NEVER buy under powered amps to drive speakers with as they often run out of headroom(especially the sub bass and bass frequencies eats up amp headroom FAST) and CLIPPING fries the speakers.
An amp with slightly more wattage the the rms of the speaker is what to go for. That way the amp has extra headroom before clipping. And as music is NOT a continuous sine wave or continuous tone, it's dips and peaks in wattage, it won't blow the speaker.
Clipping however can put more than twice the power or more into the speakers than they can handle(which overheats/burns out the voice coils of the speakers), and is also a very distorted signal, not a clean signal.
For pa speakers and the higher quality expensive car subwoofers(not the budget subs) I use an amp 1.2-1.5x the rms of the sub or speaker.
For hifi speakers,studio or home cinema speakers I use an amp 1.2x the rms of the speaker or sub, no more. As pa speakers and high quality expensive car subs have much higher temperature bigger voice coils and vents around the magnet able to handle more accidental misuse/abuse than normal hifi speakers.
ItchyTasty42 is offline
post #9 of 10 Old 09-16-2012, 05:33 PM
benclement11's Avatar
How do you even know what the objective of this entire thing is? If everyone else is using stuff provided by the school, I would say he is ahead of the group by seeking out something different. I don't think he provided enough information for you to say one way or the other what he "should" be doing to impress you.
Panasonic P60ST50-Yamaha RX-V467 receiver-Sony PS3-Velodyne SMS-1-Canton 430 mains, 455 center and 402 surrounds-Rythmik FV15HP subwoofer- Pro-ject Debut III turntable- I also have a pair of Mark K's DIY design, the ER18DXT's
My humble entertainment room
http://www.avsforum.com/t/1417652/midwest...
benclement11 is offline
post #10 of 10 Old 09-18-2012, 09:45 PM
A9X-308's Avatar
Liked: 1142
Forgot to post this earlier.
There are two main failure modes with speakers; over excursion and overheating.
Damage by overexcursion need not even need to be caused by a signal that even meets the rated power of the driver or an amp. It can be a short transient so that the speaker exceeds Xmech, or by a large amplitude signal below tuning of a ported enclosure and no filtering - I saw several damaged from poor phono cartridge/arm matching over 30 years ago.
Overheating is caused by the average energy supplied to the coil and how quickly it can dissipate it. The coil does not care what signal inputs the energy, merely that it does. The coil will heat very quickly with applied energy, but will dissipate it more slowly. Most coil formers and/or cones are not metallic so do not aid in heat sinking, so the heat is left to escape by convection across an air gap from the coil to the magnet structure and thereby to the surrounding air, usually inside an enclosure. Failure here takes place often by delamination of the coil as the glue softens, the former failing and either of these causing rubbing on the inside of the magnet gap, causing further damage or jamming the cone. Sometimes the coil will go O/C but I have seen this far more often in coils that don't show signs of major overheating.
Hence my comments that a speaker does not act like a fuse - because it doesn't especially with some mild over powering or clipping.
That statement is only contingent on using amps to drive speakers wideband. It certainly does not apply to complete active systems, like my home of PA. Especially WRT sub bass (as this is an HT discussion), apply as much to systems with actively crossed subs which would be the case for almost any HT.
To imply this is always or even mainly the case is clearly hyperbolic.
And this is precisely the point.
With most HT source material having a peak to average ratio of 20dB or more, if you adjusted your system so that a 100W amplifier was just below clipping, the amount of energy applied to a voice coil would be only a couple of watts at most. If I used a 1kW (and caused no over excursion etc) and adjusted it the same, there would still only be 20-50W of equivalent heating in the coils.
Note, so there is no misunderstanding, that I'm talking about clipping of the amplifier not about clipping/compression of program material which because of the very low peak to average ratio offers such a dense with some combinations of amplifier and speaker, it's conceivable you could damage the speaker whilst never clipping the amplifier.
The only way that you can get twice the rated power of an amp into a speaker is by so massively overdriving a sine wave so that it becomes as near as dammit to a square wave. This is hardly a common occurrence in actual use, let alone testing. Unless of course you intend to do it (in which case why not simply use a square wave?) or the tester is an idiot.
Well, duh. It's now a(n almost) square wave with a decreasing amplitude (predominantly) odd order harmonics.
You are free to use whatever rule of thumb you like, but but 1.2-1.5x is pretty irrelevant if the purpose is to stop any clipping. It will realise only 0.8 to 1.8dB of difference, trivial really.
A9X-308 is offline
