Need opinions on which amp I should go with - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-19-2012, 06:53 AM - Thread Starter
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 176
Hey guys, I am currently saving up to buy a few sub drivers to use in a DIY project, but in the mean time I want to try and get my MFW-15 up and running so that I can continue to enjoy watching movies and listening to music. My original MFW-15 amp bit the dust, and the second amp purchased from Kevin at MotorCityAudio was bad as well.
So with all of that being said, I need to purchase a new amp to drive my MFW-15. I plan on soldiering the driver directly to the binding post so that I dont have to fill in the hole left by the stock amp and can just connect it directly to my new amp. My budget is limited to $170 bucks. I am planning on purchasing a plate amp from PE and building a custom enclosure for the amp.
Here are my choices, please let me know if these will work ok with my MFW-15:
1. Yung SD300-6 has 300 watts and a 6db bass boost at 30hz as well as hpf & lpf, phase controls, ect....
2. Dayton SPA-250 250 watts with a built in hpf & lpf, as well as phase controls ect..
3. Bash 300watt with built in hpf & lpf + phase controls ect...
Which would be ok to use with my MFW-15 in a temporary situation until I can purchase the necessary materials and hardware to build 3 to 4 DIY subs?
Martycool007 is offline
post #2 of 3 Old 10-18-2012, 07:08 AM
nograveconcern's Avatar
Quoted: 91 Post(s)
Liked: 128
Thread is a bit stale and you may have already bought something, but I would caution you on the Yung SD300-6. I bought one thinking the 6db boost would be variable or at least switch-able but it's not.
On the upside it does add impact to the sound for movies, but it makes your response anything but flat. So, make sure you want six db of boost at 30 if you get the -6 model.
The class D amps are nice for having lower power consumption and heat, so the yung amps are still a good choice. I just wish I would have gotten the standard model.
nograveconcern is offline
post #3 of 3 Old 10-20-2012, 07:57 AM - Thread Starter
Quoted: 280 Post(s)
Liked: 176
I ended up soldering the drivers + & - to the binding post, then building a custom enclosure out of MDF and covered in truck liner for the Yung 300 watt plate amp that I am using with it. Hooked it all up a week or two ago and it sounds good. Of course I am still yearning for more! I will be using the driver in my MFW-15 to put in an F-20, and I also plan on using the same outboard Yung 300 watt plate amp to power the F-20. I am also going to be building some other subs, such as the SSD-15 or SSD-18 in both a sealed and ported enclosure to compare.
