NEW SUB FROM PARTS EXPRESS DAYTON 18 HO" - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 103 Old 01-28-2013, 04:35 AM
nograveconcern's Avatar
Quoted: 91 Post(s)
Liked: 128
Originally Posted by ack_bk View Post
There are some new inexpensive USB mics that really make it (REW) easier to use. One from PE and one from Minidsp. It is pretty much plug and play:
http://www.parts-express.com/pe/showdetl.cfm?partnumber=390-808
http://www.minidsp.com/products/acoustic-measurement/umik-1
I am not sure if you read through Gorilla83 thread on dual opposed boxes using the Dayton 18 HO's but it is a good thread to read through and should give you some good ideas.
nograveconcern is offline
post #92 of 103 Old 01-28-2013, 02:21 PM
ack_bk's Avatar
Quoted: 613 Post(s)
Liked: 697
Originally Posted by nograveconcern View Post
Very cool. Am interested in your feedback on it.
ack_bk is online now
post #93 of 103 Old 02-16-2013, 12:14 AM
fish323's Avatar
Quoted: 18 Post(s)
What size sealed cab looks optimal for a single 18 on only 500 watts?
fish323 is offline
post #94 of 103 Old 02-16-2013, 07:17 AM
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 234
With only 500w you want to lean towards the larger cabs to pick up some efficiency down low. I would go for 4cf or more.
But, keep in mind that it takes large changes in enclosure to significantly affect FR. 1/2 a cubic foot is negligible.
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
post #95 of 103 Old 02-20-2013, 02:43 PM
fish323's Avatar
Quoted: 18 Post(s)
It seems like 4 cf is the size people are going with when using around 1k watts per driver. How much larger are you talking to reach a different frequency response with 500 watts?
fish323 is offline
post #96 of 103 Old 02-21-2013, 06:12 AM
Quoted: 91 Post(s)
Liked: 128
fish, 6 cu ft looks good with 500w. I don't think I would go larger. Stuffing with poly fill will help some too.
4cu ft. looks good with 700+.
post #97 of 103 Old 02-21-2013, 11:12 AM
fish323's Avatar
Quoted: 18 Post(s)
fish323 is offline
post #98 of 103 Old 02-22-2013, 10:35 AM
djkest's Avatar
Quoted: 35 Post(s)
Liked: 44
Am in the process of building mine right now. It will be around 4.0 cubic feet.
Exterior dimensions are going to be 20.75" wide, 27" high, and 19" deep. The driver is recessed 0.75". Nearly done but I am thinking I might do some additional bracing.
With only 75 watts to it (half of my emotiva amp) it got pretty loud in my basement. Doesn't soon particularly good running full-range, however.
djkest is offline
post #99 of 103 Old 02-22-2013, 11:50 AM
bass addict's Avatar
Quoted: 441 Post(s)
Liked: 507
Looking good.
Achievement Unlocked
Psychotic Episode Averted
bass addict is online now
post #100 of 103 Old 02-23-2013, 06:32 AM
Gomdaf's Avatar
Those of you who have mounted these, did you use any type of gasket? I have a 1.5" baffle with a .75" recess.
Gomdaf is offline
post #101 of 103 Old 02-23-2013, 01:33 PM
Quoted: 441 Post(s)
Liked: 507
Depends on the mounting surface. If coating with Duratex I'd use a gasket. Mine are mounted directly over a primered base with no gasket and no issues.
post #102 of 103 Old 02-23-2013, 03:08 PM
Gomdaf's Avatar
Thanks. Reason I ask is it seems like it already has a gasket of sorts on it from the factory
Gomdaf is offline
post #103 of 103 Old 02-23-2013, 03:09 PM
djkest's Avatar
Quoted: 35 Post(s)
Liked: 44
It's already got some high density foam on the back, it's fine if you are mounting it to a relatively smooth surface. smile.gif
I will be using the factory gasket on mine.
djkest is offline
