Stereo Integrity's new HT Subwoofer - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 12Likes
post #271 of 2273 Old 12-18-2012, 02:45 PM
popalock's Avatar
Quoted: 1273 Post(s)
Liked: 1776
Originally Posted by Aaron Smith View Post
Looks like as a group we were collectively deprived of being able to purchase reasonably priced 18's for too damned long! biggrin.gifI bought 8 of them as well 2 weeks ago
Originally Posted by bass addict View Post
LOL, no kidding.
Add me to the plethora of 8's list with 6 + 1 backup + 1 15" just because. biggrin.gif
Montana representing!
popalock is offline
post #272 of 2273 Old 12-18-2012, 04:28 PM
Fatshaft's Avatar
Quoted: 591 Post(s)
Liked: 906
Would putting 4 dual opposed (1 per corner) of these 18`s yield better results than 4x 21`s? (1 per corner)
Tks
My Build Thread
Equipment Speakers:
3x 1099's for LCR duty
4x Fusion 8's for surround duty
8x subs: 4x FTW21's and 4x SI18's
Fatshaft is offline
post #273 of 2273 Old 12-18-2012, 04:33 PM
bass addict's Avatar
Quoted: 370 Post(s)
Liked: 446
Achievement Unlocked
Psychotic Episode Averted
bass addict is offline
post #274 of 2273 Old 12-18-2012, 04:37 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5954 Post(s)
Liked: 4997
Tks
Do you own the 21's already? If yes, I'd keep them.
Scott Simonian is offline
post #275 of 2273 Old 12-18-2012, 04:56 PM
Fatshaft's Avatar
Quoted: 591 Post(s)
Liked: 906
wow I`m a little surprised by this....I would`ve thought that 8x 18`s would be better than 4x 21`s.
And yes I already have the 4x 21`s.
Scott, I guess you forgot about my 4x 21`s build thread.
My Build Thread
Equipment Speakers:
Fatshaft is offline
post #276 of 2273 Old 12-18-2012, 05:01 PM
wth718's Avatar
Quoted: 194 Post(s)
Liked: 311
Tks
That would likely be no, I would think. 2 of these are comparable to the UXL. You have a 21 inch version of the UXL. You win. lol
wth718 is offline
post #277 of 2273 Old 12-18-2012, 05:06 PM
Aaron Smith's Avatar
Quoted: 152 Post(s)
Liked: 67
Dude must have lost his 5-finger ring. Weirdly, one of his two watches looks exactly like my Citizen Eco-Drive.
Aaron Smith is offline
post #278 of 2273 Old 12-18-2012, 05:08 PM
gpmbc's Avatar
Quoted: 340 Post(s)
Liked: 207
Fatshaft, just going off manufacturer specs, 4 of the ftw 21s net 44L of displacement. 8 of the SI 18s = 43L. Sensitivity would probably be close too but from what josh said of the 18s, they have a very compliant surround which might be more amp friendly depending on enclosure. I'd say the 18s will serve you better the higher you venture into the midbass region so it depends also on the bandwidth you'd like them to cover. My big question is what aren't the 21s doing for you that you wanna venture out?
gpmbc is online now
post #279 of 2273 Old 12-18-2012, 06:34 PM
Bass Enabler
Liked: 4997
Nope but I did have to confirm. Maybe you had sold them by now? confused.gif *shrugs*
You have four FTW's, amiright? Those are excursion monsters and have larger voicecoils. Per driver, you will have a lot more output. Monster output.
These are nice but not on par with what you have now. I would think that going with eight of these would be more of a lateral move. Now eight LMS-U's.... a whole different story, sir. wink.gif
Nothing wrong with supplementing your quad 21's with more drivers though. I won't discourage that. No way. smile.gif
post #280 of 2273 Old 12-18-2012, 08:39 PM
brian6751's Avatar
Quoted: 1112 Post(s)
Liked: 1101
Anyone figure out a recommended box volume for these yet? Single and dual opposed
That's not science! - Cyborg
Steam ID: The Barbeerian
Rivers Edge Theater
brian6751 is offline
post #281 of 2273 Old 12-18-2012, 08:56 PM
Bass Enabler
Liked: 4997
3-7cuft per driver.
Really depends on how much power you're going to use. 4-5cuft is a nice middle ground.
post #282 of 2273 Old 12-18-2012, 08:59 PM
brian6751's Avatar
Liked: 1101
1000 watts into each driver. How about if dual opposed?
Rivers Edge Theater
post #283 of 2273 Old 12-18-2012, 09:05 PM
Bass Enabler
Liked: 4997
Makes no difference being dual-opposed or not. It's the equivalent airspace per driver. That's what you pay attention to.
I'm going to (most likely if I order these) use two 8cuft cabs dual-opposed, four cubic per driver. They will take 1,250w just fine.
post #284 of 2273 Old 12-18-2012, 09:07 PM
brian6751's Avatar
Liked: 1101
What do you suggest for 1000 watts each then? I'm using a ep4000 per pair
Rivers Edge Theater
post #285 of 2273 Old 12-18-2012, 09:15 PM
Bass Enabler
Liked: 4997
Well.... I just told ya I'm going 4cuft per driver and that will take 1,250w just fine. wink.gif
Might be a large-ish box for some but you can downsize a bit if you want. I'll be using a ep4000 for mine too but I'll just use one to power four for a while until I can get larger amps.
post #286 of 2273 Old 12-18-2012, 09:30 PM
brian6751's Avatar
Liked: 1101
Four per driver it is then. Thanks Scott!
Rivers Edge Theater
post #287 of 2273 Old 12-18-2012, 09:34 PM
Bass Enabler
Liked: 4997
It also helps that Josh tested them in a 4.2cuft sealed cab in his Data-Bass tests. So that way, you can look at the tests and know exactly what to expect at home.
post #288 of 2273 Old 12-18-2012, 11:06 PM
Quoted: 370 Post(s)
Liked: 446
Scott,
If you're not running into over excursion issues, why wouldn't you build a bigger cab to pick up some low end. These looked like they model much better using the recommended 6cf cab as opposed to the 4.
post #289 of 2273 Old 12-18-2012, 11:48 PM
Bass Enabler
Liked: 4997
That and where I intend to put them..... can't go much larger. You'll see. smile.gif
Also, we are talking about 4 out of 12 18's in a 2,000cuft bedroom HT room. I'll have plenty of low end. biggrin.gif
post #290 of 2273 Old 12-19-2012, 01:50 AM
popalock's Avatar
Liked: 1776
Tks
Really, fatshaft? Really???
So you are looking to upgrade from table walking...
...to what? Table flipping?
I'm with Scott, keep the FTW21's. Add 4 dual oposed cabinets and stack your FTW21's on top... You have a FP10KQ Clone powering the FTW's, right? Throw another one in the mix and that should put you in x8 LMS-U territory...
Do it...
Where you at in Canada again? That might be worth a road trip...
popalock is offline
post #291 of 2273 Old 12-19-2012, 02:49 AM
popalock's Avatar
Liked: 1776
Hey, why isn't your video working anymore fatshaft?
The fact that fatshaft is even looking at these and contemplating a potential upgrade seriously makes me laugh out loud...
Scott didn't forget about your thread bro...
Post 262 of fatshafts build thread:
Thanks Scott...
One thing I'm pretty sure of and mark my words "There's no way I'll be upgrading my subs...EVER!" wink.gif
Scott, please proceed with the "inevitable I told you so" referenced on post 272 of fatshafts thread...
I guess I'm going to have to go back and redact my inital redaction of fatshaft wanting more bass. A double redact!!!
popalock is offline
post #292 of 2273 Old 12-19-2012, 03:40 AM
Fatshaft's Avatar
Quoted: 591 Post(s)
Liked: 906
Video works fine in my original thread
BTW, I`m not upgrading, so you can`t use that against me...sorry. It`s seems like I`d be downgrading so you see it doesn`t count wink.gif
I guess I'm going to have to go back and redact my initial redaction of fatshaft wanting more bass. A double redact!!!
Popa, you misread...I`m looking to change the 21`s to the 18`s from SI
Wouldn`t that now be LESS bass?
My Build Thread
Equipment Speakers:
Fatshaft is offline
post #293 of 2273 Old 12-19-2012, 03:44 AM
Fatshaft's Avatar
Quoted: 591 Post(s)
Liked: 906
Thanks for the response...I appreciate it.
My Build Thread
Equipment Speakers:
Fatshaft is offline
post #294 of 2273 Old 12-19-2012, 04:12 AM
Stereodude's Avatar
Quoted: 3334 Post(s)
Liked: 2434
Stereodude is offline
post #295 of 2273 Old 12-19-2012, 08:05 AM
Quoted: 152 Post(s)
Liked: 67
post #296 of 2273 Old 12-19-2012, 08:09 AM
Quoted: 152 Post(s)
Liked: 67
Originally Posted by Stereodude View Post
Yes -- all I need to do is upgrade my Mr. T Starter Kit, incorporate some Flavor Flav elements, and take a crash course on 'Street Sign Language' and I am there, dude! smile.gif
post #297 of 2273 Old 12-19-2012, 08:28 AM
Electrodynamic's Avatar
Quoted: 447 Post(s)
Liked: 672
LOL! Nothing like browsing a HT subwoofer thread and finding pictures like this thrown in there. biggrin.gif:cool:
Electrodynamic is offline
post #298 of 2273 Old 12-19-2012, 08:30 AM
brian6751's Avatar
Liked: 1101
Oh! It gets better! Stick around!
Rivers Edge Theater
post #299 of 2273 Old 12-19-2012, 09:28 AM
Bass Enabler
Liked: 4997
Yeeapp. Gettin' close to 30.
I think that the even mention of a change or addition is telling enough. Fatshaft needs and wants more subs. tongue.gif
Yeah!
post #300 of 2273 Old 12-19-2012, 09:50 AM
Bass Enabler
Liked: 4997
*groan*
Hovering an order form to get nine 18d2's....
Stereo Integrity Siht18
