What's Best for Lining Internal Subwoofer Walls? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #31 of 45 Old 10-11-2012, 01:52 PM
mjaudio's Avatar
Quoted: 39 Post(s)
Liked: 75
The reason to keep the covers on the pillows is the keep the polyfill from getting everywhere, especially around the driver. Because of that I normally just arrange them in there but do not staple or glue them which is normally not needed in a home environment were you hardly move the sub around. You want them in there snug but you don't want to compress them much and leave some space behind the subs vent.
saginawjuggalo likes this.
mjaudio is offline
post #32 of 45 Old 10-11-2012, 01:54 PM
mastermaybe's Avatar
Quoted: 362 Post(s)
Liked: 305
good deal, gracias.
James
Actual phone call (see pic to left):
Tech (responding to laughter): "I'm sorry sir, did I miss something?"
Me: "Yeah, a case of Diet Mountain Dew walking across my living room."
mastermaybe is offline
post #33 of 45 Old 10-11-2012, 10:04 PM
Stereodude's Avatar
Quoted: 3084 Post(s)
Liked: 2236
Originally Posted by mastermaybe View Post
does filling a subwoofer cabinet adversely/significantly affect internal volume.
Sound waves travel slower through the polyfill so it has the net effect of making the box seem bigger rather than taking away from the internal volume. The right amount of polyfill depends on the type of box and the box size. Sealed boxes continue to show gains from increased polyfill density well after the point increased polyfill becomes detrimental in a ported box.
In a small ~1.4ft^3 ported box of mine I found a relatively light amount of poly fill of ~8oz per ft^3 was the right amount. Additional polyfill did not lower the tuning point any more, but instead began to reduce the output of the port and the driver on the knee of the frequency response curve.
In a small ~1.4ft^3 sealed box up to 24oz per ft^3 was still showing gains though they were getting pretty small as I crammed in more and more polyfill.
Keep in mind this was loose polyfill, not a pillow.
Stereodude is offline
post #34 of 45 Old 10-12-2012, 05:18 AM
NicksHitachi's Avatar
Quoted: 182 Post(s)
Liked: 189
Since the speed of sound is constant in air and doesnt speed up or slow down, the lining/stuffing produces gas/particle friction converting some of that energy into heat. The sound wave continues on at same speed but with less "pressure."
NicksHitachi is offline
post #35 of 45 Old 10-12-2012, 06:36 AM
Bill Fitzmaurice's Avatar
Liked: 4628
The reduction in the speed of sound is cursory at best, and it does not make the box seem bigger. The higher coefficient of resistivity of damping materials, as compared to air, causes a lowering of the system Q, which in some ways emulates a larger box, but it does not duplicate it.
Said heat is a by-product of the Q lowering action, not the cause for the lowering of Q. It all boils down to system impedance, which changes with damping, and can be seen on impedance sweeps.
MemX likes this.
Bill Fitzmaurice is online now
post #36 of 45 Old 11-30-2013, 03:56 PM
mtbdudex's Avatar
Quoted: 78 Post(s)
Liked: 689
I'm building a 4 cu ft ported subwoofer, here is my Q2 from that thread post #5
http://www.avsforum.com/t/1502689/flat-pack-4-cu-ft-12-ultimax-sub-ported-box-build#post_24014680
Q2: stuffing inside ported box. I want to just line the box with stuffing, right?
I seem to remember reading that somewhere here but can't find it just now.
I did a search, came across this thread, and for a cliff notes summary:
a) do I line the internal subwoofer walls with - open cell foam or OC703 (I have a lot of extra OC703) or ??
or
b) stuff the box with some polyfill
or
c) need to measure to truly know what to do
Based on best practices, what is consensus?
mtbdudex is offline
post #37 of 45 Old 11-30-2013, 04:09 PM
Liked: 4628
I'm building a 4 cu ft ported subwoofer...
or
or
With a ported sub you're primarily trying to damp internal midrange reflections that otherwise might reflect out the ports or reflect back to the cone. Midrange? Yes, their source being above-bandwidth content not filtered out by the crossover, and harmonics of in-bandwidth content created by the driver. A couple of inches of any of the usual materials will do. Type 700 has the advantage that it takes less of it to give the same result. You can use stuffing to lower the Q of a ported enclosure, but that's better accomplished via the duct length, and if you do so with stuffing there's a loss of low end sensitivity.
steve nn and mtbdudex like this.
post #38 of 45 Old 12-01-2013, 10:58 PM
noah katz's Avatar
Quoted: 878 Post(s)
Liked: 304
Originally Posted by Bill Fitzmaurice View Post
You can use stuffing to lower the Q of a ported enclosure, but that's better accomplished via the duct length....
Port length primarily affects fB, no?
Effect on Q would depend on surface area to cross sectional area ratio due to configuration, i.e. round, slot, etc.
And said Q varies with drive level/port velocity.
vitod likes this.
Noah
noah katz is offline
post #39 of 45 Old 12-07-2013, 06:07 PM
mtbdudex's Avatar
Quoted: 78 Post(s)
Liked: 689
or
or
Thx Bill;
I've got two types of leftover material, lots of 2" thick OC703 and also 2" thick blended cotton and recycled paper based.
http://www.acoustimac.com/ecoinsul422/
spare%2520acoustic%2520material%25201.JPG . spare%2520acoustic%2520material%25202.JPG
I need to put the wall lined material before I put the top on, so just attach that on all the walls? ie all 6 sides?
I can use some adhesive glue.
I read it's best to have the back of the port un obstructed by the diameter of the port, so I will not have material directly reward of the ports.
Port%2520clearance%2520-%2520material.JPG . Port%2520clearance%2520-%2520material%2520top%2520detail.JPG
mtbdudex is offline
post #40 of 45 Old 12-07-2013, 08:43 PM
Liked: 4628
Either should work OK, all five sides is best, you don't need to do the baffle.
post #41 of 45 Old 12-08-2013, 08:08 PM
Quoted: 182 Post(s)
Liked: 189
I used 2" OC703 in one of my sub builds and fastened with construction adhesive and green button roofing tacks...
Worked good. :-)
post #42 of 45 Old 12-13-2013, 04:26 AM
mtbdudex's Avatar
Quoted: 78 Post(s)
Liked: 689
I ended up using the 2" thick blended cotton and recycled paper based, as I had lot's of that stacked up in leftover triangle shapes.
cut pieces to fit, glue on back ........................................lining "done", top lining will be done after top is glued on
mtbdudex is offline
post #43 of 45 Old 12-13-2013, 05:23 AM
Quoted: 182 Post(s)
Liked: 189
I spy a DIYSG ported 12 flatpack..... ;-)
What driver you using?
post #44 of 45 Old 12-13-2013, 06:10 AM
mtbdudex's Avatar
Quoted: 78 Post(s)
Liked: 689
12" Dayton Ultimax driver, amp is iNuke3000 DSP, got the 3000 for future 2nd sub.
mtbdudex is offline
post #45 of 45 Old 01-28-2016, 07:24 PM
januza's Avatar
Quoted: 179 Post(s)
Liked: 107
I am putting insulation foam in my cabinet.. any special requirement for glue?
januza is online now
