My First Ever DIY Sub - Page 8 - AVS Forum | Home Theater Discussions And Reviews
post #211 of 233 Old 10-31-2012, 04:50 AM
nograveconcern's Avatar
Quoted: 91 Post(s)
Liked: 128
First I've heard it. My whole house has a surge protector at the meter and I'm running throuh a conditioner/surge protector in my rack.
nograveconcern is offline
post #212 of 233 Old 10-31-2012, 05:11 AM
NicksHitachi's Avatar
Quoted: 182 Post(s)
Liked: 192
Originally Posted by mfrey0118 View Post
Can anyone comment on this:
In my opinion, unless they're incredibly robust and over sized, I'd never feed an amplifier through a power conditioner/surge protector. They don't need them, and they can do harm in dynamics limiting via voltage drop/current limiting. YMMV
Probably safer in respect to power surges.
IMO not necessary at all for sub amps unless you are trying to address 60Hz humm and even then prob not correct move.
Read up on your power conditioner current rating, its probably less than the 20A rating your stanard household circuit has, if so your power conditioner could be a bottle neck.
Things I would like plugged into power conditioner/filter:   A/V processor, pre-amp, BR player, computer, TV, Projector, and maybe EQ.  All relatively low current items.
A few facts:
My EP4000 will trip my power conditioner(APCH10) into "protect" mode, but it only states a 12A rating.
My Emotiva Amp states in manual NOT to plug into a power conditioner.
Most decent amps have their own built-in EMF/RFI filters as well as adequate capacitance, they won't benefit from the power conditioner IMHO.
NicksHitachi is offline
post #213 of 233 Old 10-31-2012, 05:21 AM
Bill Fitzmaurice's Avatar
Liked: 5687
I thought it was always prudent to have your higher end electronics hooked up to a PC/SP..?
Like 'high end' cables power conditioners are expensive solutions for non-existent problems. Surge protection is all you need, and even that is already built in to most modern gear.
Bill Fitzmaurice is offline
post #214 of 233 Old 10-31-2012, 05:21 AM - Thread Starter
mfrey0118's Avatar
A few facts:
So should I just use a standard surge protector at the wall outlet and not my Monster HTS2000?
60" 1080p 3D Plasma Panel
3D 1080p Blu-Ray player
4K 7.2 Channel AVR
mfrey0118 is offline
post #215 of 233 Old 10-31-2012, 05:26 AM - Thread Starter
mfrey0118's Avatar
Funny newbie story...
So I wanted to take the amp apart and see how the power wires were connected because I don't like the 14ga wiring, I think it's too small...anyway, I figured it was like my laptop and TV and you just had to remove as many screws as possible to get the thing apart, right? Hahaha...so I took all of the screws out that were showing on the back plate. Got the cover off and I was like "what the frack?"...the circuit boards weren't attached and there was goo making them slide all over the place...I thought to myself, "so much for Dayton QC..."...then I realized that I had done that by basically detaching everything from the frame/heat sink...so I quickly put it all back together and it seems I only need to remove the four large corner screws to get the cover off...
I got so sidetracked I forgot about the power wires...looked like they were attached in some complicated way so I think I'll leave it alone if it won't affect performance. However, I hope I didn't smear too much of that heatsink glue from underneath the boards because won't that affect the amp's heat dissipation ability?
I also have a hum now that wasn't there in the SPA500 once I installed the cable line ground loop isolator. Maybe its due to being on the power strip?
4K 7.2 Channel AVR
post #216 of 233 Old 10-31-2012, 05:27 AM
Quoted: 182 Post(s)
Liked: 192
A few facts:
If you feel the need.  All of my high current amps are plugged directly into wall outlets.
post #217 of 233 Old 10-31-2012, 07:46 AM
Liked: 5687
+1. AFAIK no amp manufacturers recommend using power conditioners, and those that do mention them advise against them, Bryston to name just one.
post #218 of 233 Old 10-31-2012, 08:05 AM - Thread Starter
mfrey0118's Avatar
OK, I took it off and put it directly to an outlet, no PC no SP.
Couple of questions...
I think my box is tuned somewhere around 30hz, because the bass gets real hot around that freq...with only 1 parametric EQ at my disposal, what is my best option for smooth response:
a) Boost at +3db the freqs directly below the tuning freq
b) Cut right at the "hot spot" until it blends better with surrounding freqs
Also, is there a way to translate Q into actual freq steps? Like, if I center the EQ at 30hz, with a Q of .25, what's that curve look like, how many surrounding freqs are affected and by how much?
4K 7.2 Channel AVR
post #219 of 233 Old 10-31-2012, 08:24 AM
Quoted: 182 Post(s)
Liked: 192
You can calculate your estimated Fc Here.
However i would tend to believe the hot 30Hz region is room related not sub related.  I could be wrong though.
You said the room is 35' long and 30Hz has a wavelength of approx 37' so if your in the back of the room thats a high pressure region for 30Hz.  You could try moving it away from the short wall by 33% which would decrease the length mode excitation but would cost you some output in that region.
To test you can measure the center of the room, that should be a low pressure region for approx 30Hz.
I don't know how to recommend boost or cut without a graph to look at and knowlege of how much headroom you have avail.  I'm guessing your headroom is tapped out so I would cut if placement doesn't solve it.
post #220 of 233 Old 10-31-2012, 08:43 AM - Thread Starter
mfrey0118's Avatar
By headroom, you mean extra amp power beyond the speakers rating, correct? I would hope this 1000 watt amp has some kind of headroom with the Epic.
4K 7.2 Channel AVR
post #221 of 233 Old 11-01-2012, 08:37 AM
Quoted: 182 Post(s)
Liked: 192
Headroom could mean excursion or power.  IDK, how much of either you have in "reserve."  My guess was based on the size room you have and a single sealed 12 working its butt off.....
Either way, response issues normally best addressed by placement, placement, placement, placement, EQ cut, EQ boost(3-6db Max).  In that order.  IOW, If you've got a 10db peak your not gonna be able to boost the rest to match at very high playback levels without running out of excursion or power as you turn up the volume.  You might get away with it up to say 85-90db but not much higher as you'll prob run out of "headroom" in the boosted areas.
post #222 of 233 Old 11-03-2012, 06:52 AM - Thread Starter
mfrey0118's Avatar
Well, now I have some kind of vibration in the enclosure...seems to be coming from the cone...only happens on certain freqs...guess I'll take it apart later this weekend to see if any of the t nuts came loose.
One of the things I read about the Epic before buying was there were some issues with the adhesive used on some of the guts and it things would come loose sometimes...hopefully, that's not the case here but if so, I can do a warranty repair/exchange...how do I confirm what the rattling is? Any handy methods?
4K 7.2 Channel AVR
post #223 of 233 Old 11-03-2012, 09:01 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 181
Does anyone know how much real world power that Dayton 1000 watt plate amp actually puts out at both 8 ohms and 4 ohms? Does it really do 1000 watts into 4 ohms? I am debating on which amp to go with as my budget is limited. Other amps considered are the iNuke 1000dsp, EP1500, and possibly an iNuke 3000 (non dsp version). Sorry for the highjacked post OP! I think you might benefit from answers to these questions as well!
Martycool007 is offline
post #224 of 233 Old 11-03-2012, 09:53 AM
Stereodude's Avatar
Quoted: 3454 Post(s)
Liked: 2526
About 950 watts into 4 ohms (based on one-third power duty cycle).
Stereodude is offline
post #225 of 233 Old 11-04-2012, 05:34 AM
Quoted: 182 Post(s)
Liked: 192
Run some sine waves free air at very low power and see what you hear.
Careful with in and out on those tnuts stripping one can be a pain.
Is it possible that your bottoming the driver? We all tend to push our systems a little harder once we get used to them.
post #226 of 233 Old 11-04-2012, 08:28 AM - Thread Starter
mfrey0118's Avatar
You are so right about pushing them. I always try to build a system that I know can take full (reference) volume sustained without damage...I think I'm there now...these BIC venturis handle everything my 609 can throw at it and that's without any external amplification, processing in the chain.
The Epic seems to simply stop getting louder when I push it into the red temporarily (amp gain close to halfway), which to me seems to be a good sign of quality distortion management.
So in answer to your question, no I don't think I'm bottoming it out. Anyone know what the voice coils are made of? I had a ceramic chip break off of my Solo Barics one time and it caused some odd behavior/sounds...this vibration is not loud, I have to have my ear up to the cone, and it only happens on certain freqs, say 30-45hz region, and only at lower volume so I'm thinking something's loose or maybe some enclosure sealant broke off and got into the housing...or maybe the adhesive I used to seal the T nuts dried up and cracked off during high excursion and fell into the sub?
I'm still getting 138dbs at 50hz sine wave at the speaker, so I don't think it's blown or anything.
As far as dedicated amps, preamps, DSPs, etc, that's all stuff I'm completely unfamiliar with in home audio as of now. The miniDSP and room calibration set is my first attempt...I'm looking forward to getting my hands a little dirtier.
4K 7.2 Channel AVR
post #227 of 233 Old 11-05-2012, 06:46 AM - Thread Starter
mfrey0118's Avatar
OK I think I've isolated the vibration problem and also discovered an air leak problem. It's the amp. When I ran a 16hz sine wave (got up to 117db at speaker before distortion), I could hear audible chuffing coming from the back of the box. When I put my ear up to the plate amp, I could hear the air wushing out at or near the 3 RCA jacks (2 line and LFE).
I think I may have a bad seal from when I accidentally took the mounting screws off trying to remove the amp's back cover...
Upon hearing the air leaking, I also realized the slight rattling sound is coming from the same area, and one of the small screws is stripped around the RCAs...hopefully all of this is fully fixable.
Anyone know what type of adhesive/heat sink goo they use for the amp circuit boards to sit against the back plate? I may need to add more since so much got smeared around when it came loose...
4K 7.2 Channel AVR
post #228 of 233 Old 11-05-2012, 07:54 AM
Liked: 5687
Slightly OT, but this points out one reason why on-board mounting the amp can be problematic; the other is that remotely locating the sub amp from the rest of the electronics greatly increases the possibility of ground loop noise. Even if it's a plate amp mounting it in it's own box placed close to the receiver generally works better than on-board.
post #229 of 233 Old 11-06-2012, 03:54 AM - Thread Starter
mfrey0118's Avatar
Yeah, but this was totally my fault, though. If I hadn't unscrewed everything inside the amp when I was trying to remove the cover none of this would've happened. Since I've put the ground loop isolator on my cable line, ground loop hum is no longer an issue.
4K 7.2 Channel AVR
post #230 of 233 Old 12-06-2012, 05:50 AM - Thread Starter
mfrey0118's Avatar
OK, so now I've got an unbalanced 2 x 4 MiniDSP and the Omni Mic room measurement system...I'll start posting actual graphs when I learn more about how to use all this stuff (which may be a minute 'cause I think my mic as the 60hz hum issue and I'll need a replacement), but I was taking real rough measurements last night from the central listening area, about 11 feet from my sub and I was getting about 115db on 18hz sine wave and well over 120dbs for the 26hz sine wave...at 11' from the sub in this room, that's not too shabby, eh?
4K 7.2 Channel AVR
post #231 of 233 Old 02-16-2013, 07:08 AM
Eyleron's Avatar
Quoted: 267 Post(s)
Liked: 168
Your dB sound too high. Is this realistic for a 12" driver 11 feet with large space with little PVG?
SEOS Fusion 10 Max, 88 Special, Volt 10 LX, SVS PB10 and DIY SI18 subs, Denon X4000, JVC RS400 & 2.35:1 AT Screen
Eyleron is offline
post #232 of 233 Old 07-20-2013, 09:27 AM - Thread Starter
mfrey0118's Avatar
Well, my sub rocks pretty well, and no problems to speak of. I've left the Omni calibration BiQuad values the same for months and this thing really shakes the couch on DTS soundtracks. biggrin.gif
4K 7.2 Channel AVR
post #233 of 233 Old 11-21-2013, 03:29 PM
jer181's Avatar
Quoted: 88 Post(s)
Just a question for you all....
I currently have an Pioneer SC-67 with 2 KEF Q900 as fronts. I have 2 x 12" Audiobhaun (similar to Audiobahn AW120T) sitting in my basement for years. Does anyone know or recommend trying to integrate these into my home theatre set up?
If so, what would it all entail? I wouldn't use the dual band pass box, as its old and ******.
jer181 is offline
