How do I check my driver? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 10-04-2012, 08:56 PM - Thread Starter
ozziedog's Avatar
Liked: 24
My A7-350 went out a couple of months ago and I sent the module in the amp to Daveds50 and had it fixed, but it is still not working. He said that I should check my driver with a multimeter to see if it is bad. I looked up a video on how to do this, but I could not find any one doing this to a driver with dual voice coils. Can anyone explain the process on how to do this.
ozziedog is offline
post #2 of 8 Old 10-04-2012, 09:40 PM
filtor1's Avatar
Quoted: 212 Post(s)
Liked: 166
Check each voice coil independently.
filtor1 is offline
post #3 of 8 Old 10-06-2012, 10:28 PM - Thread Starter
ozziedog's Avatar
Liked: 24
So, it read 0 on the multimeter. That means it is blown right? Is this worth fixing or should I be looking at other options?
ozziedog is offline
post #4 of 8 Old 10-06-2012, 10:55 PM
Bushi's Avatar
If the resistance of the voice coil is ~0 that means the voice coil is fine. The voice coil is just a loop of wire and has low resistance.
I've never tried it but I remember hearing people tapping the leads to a 9 volt battery for a second to see if the cone moves in or out. If it moves, it works and the amp is broken.
Bushi is offline
post #5 of 8 Old 10-07-2012, 07:01 PM - Thread Starter
ozziedog's Avatar
Liked: 24
I thought a 0 meant the voice coil was shorted.
ozziedog is offline
post #6 of 8 Old 10-07-2012, 07:03 PM
Stereodude's Avatar
Quoted: 3453 Post(s)
Liked: 2523
It does. You should measure a few ohms of resistance with a multimeter.
Just measure each coil separately. It's easier. Remove any wires from the driver before measuring.
Stereodude is offline
post #7 of 8 Old 10-07-2012, 09:16 PM
ItchyTasty42's Avatar
A working driver has the impedance of the coil slightly lower than the rating impedance of the driver. Example: An 8 ohms driver would read around 6 ohms on a multimeter.
But a blown coil has zero impedance or an infinite reading.
ItchyTasty42 is offline
post #8 of 8 Old 10-07-2012, 11:28 PM
Bushi's Avatar
Yeah I don't know what I was thinking when I posted that. Still the 9 volt test will work.
The two failure modes of the voice coil I imagine would be the insulation melting/stripped off and causing the coil to be shorted to ~0 resistance or the coil wire being totally trashed that it has very high impedance or totally severed and infinite impedance.
Bushi is offline
