Close mic measurements of a passive radiator sub - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By bwaslo
  • 1 Post By bwaslo
post #1 of 22 Old 10-05-2012, 03:52 PM - Thread Starter
Stereodude's Avatar
Quoted: 3334 Post(s)
Liked: 2434
I have a sub I built years ago with a Tumult and 4 Adire 15" PRs that has been sitting in storage until I got my hands back on it today. Frankly speaking I've always been unhappy with its performance. I'm trying to figure out why it sucks. Step one is to measure it and compare it to the predicted model. Dragging it out into the middle of a field and measuring it ground plane isn't practical. So... I can close mic measure (with REW) the driver with and each of the 4 passive radiators and then add them all together and get a reasonably accurate measurement of the sub (assuming I'm consistent with the distance between the mic and each driver / PR) right?
Stereodude is offline
post #2 of 22 Old 10-05-2012, 06:23 PM - Thread Starter
Stereodude's Avatar
Liked: 2434
IE: Can I combine all these:
and get this:
and consider this a valid measurement of the subwoofer's overall frequency response?
post #3 of 22 Old 10-06-2012, 06:35 AM
JackNC's Avatar
Quoted: 140 Post(s)
Liked: 39
If done correctly, close mic will tell you the anechoic response (what it would measure out in the field, speaking loosely) but it won't tell you what it will sound like in a room where response is dominated by room-modes/standing waves.Yes you can add responses from diagram to contributions from the ports or passive radiators. In each measurement the mic distance has to be not only constant but as close as possible to the source to limit contributions from the other sources.
The close mic response dosen't include reflections but, if the sub doesn't sound good, chances are its the reflections (leading to cancellation notches and standing waves) that are the cause. What you need to do is measure it in room with mic at the listening position and then try different positions for the sub and also try to correlate notches with distance to nearby floor/ceiling/wall boundaries.
JackNC is offline
post #4 of 22 Old 10-06-2012, 07:25 AM
MBentz's Avatar
Quoted: 25 Post(s)
Liked: 43
What steps are you taking to get the combined response? It is possible to measure each portion separately and sum the two to know what the system is doing, but you have to do an actual summation that also takes the phase information into account. The combined response you're showing doesn't seem to be showing that.
Do you have the winISD model that predicts the expected performance?
-Mike Bentz
~It's all about compromise~
MBentz is offline
post #5 of 22 Old 10-06-2012, 07:25 AM - Thread Starter
Stereodude's Avatar
Liked: 2434
Thanks for the reply.
I realize that the room is the other dominant factor and that close mic response / quasi anechoic ignores that. My first goal is to find out if the sub is anywhere close to the predicted model in the simulation software. In the graphs I posted above the mic distance was perpendicular and a little over 1" away from the surface of the center of the driver or PR. It was as consistent between the driver and PRs as I could get. I will try again later today with the mic closer and see if anything changes.
My concern is that the software simulation says I should get this frequency response:
But, I measured this:
post #6 of 22 Old 10-06-2012, 07:43 AM - Thread Starter
Stereodude's Avatar
Liked: 2434
I used the mathematical addition function in REW. I'm pretty sure it considers phase since the result of adding two traces together shows phase. I just didn't show the phase in the graphs I posted.
Here's a graph showing both SPL and phase: (Click the thumbnail for full size)
WinISD, no. Unibox, yes.
post #7 of 22 Old 10-06-2012, 01:48 PM - Thread Starter
Stereodude's Avatar
Liked: 2434
So, I went back and measured again today. This time the mic was about 7/16" from the driver / PRs and was as consistent as possible. I also calibrated the sound card in between yesterday and today though the effect is basically negligible.
Day 2 Results: (Click the thumbnail for full size)
Comparison of yesterday and today: (Click the thumbnail for full size)
I feel pretty comfortable that this is the net frequency response of the sub and it's nowhere near the predicted response. frown.gif
post #8 of 22 Old 10-06-2012, 02:03 PM
Looneybomber's Avatar
Liked: 27
The measured response is acting like the Vas is a little smaller, fs a litte lower, and the Qts a litte higher than spec'd.
YID DIY
Looneybomber is offline
post #9 of 22 Old 10-06-2012, 04:18 PM
MBentz's Avatar
Quoted: 25 Post(s)
Liked: 43
Do you have all xovers disabled?
-Mike Bentz
MBentz is offline
post #10 of 22 Old 10-06-2012, 05:12 PM
bwaslo's Avatar
Quoted: 68 Post(s)
Liked: 188
You generally can't just sum up the responses, you also have to take into account their area. The microphone when close measures only the pressure right where it is at, but that pressure generally exists across the entire area of the driver or passive radiator (or a port), and its the pressure times the area (related to the amount of air that moves) that counts.
So if the moving area of the port or passive is P and the area of the driver is D, then you have to correct the passive's contribution by adding the value (in dB) to it's curve before summing:
10*log(P/D)
If the passive has less area than the driver, then you'll be adding a negative amount of dB.
If all the passives are the same, measure one of them, and in the correction formula, make P equal the sum of all their areas, then just sum those two values (driver and the combined passives)
Stereodude likes this.
___________________________________________
DIY Synergy horn spreadsheet Synergy horn spreadsheet and pdf
XSim -free crossover designer and simulator XSim install file
Easy and cheap sound diffusers (the "Depot Diffusers") making easy DIY depot sound diffuser-panels-step by step.html
SmallSyns - point source controlled directivity in a manageable size SmallSyns
bwaslo is offline
post #11 of 22 Old 10-06-2012, 05:12 PM
LTD02's Avatar
Quoted: 2500 Post(s)
Liked: 2834
could all that be caused by very large inductance? inductance can create a peak as well as rolloff the top end. i just can't remember seeing it that bad.
ilkka measured one in a sealed.
http://www.hometheatershack.com/forums/subwoofer-tests-archived/5753-diy-adire-audio-tumult-15-mk1-sealed-100l.html
Listen. It's All Good.
LTD02 is offline
post #12 of 22 Old 10-06-2012, 06:03 PM - Thread Starter
Stereodude's Avatar
Liked: 2434
I fed the output of the REW system straight into my QSC PLX 2402. No crossovers, EQs or filters were in play.
post #13 of 22 Old 10-06-2012, 06:06 PM - Thread Starter
Stereodude's Avatar
Liked: 2434
10*log(P/D)
Thanks for the reply. I will do this later when I get back on the system with REW and the measurements.
post #14 of 22 Old 10-06-2012, 07:34 PM
bwaslo's Avatar
Quoted: 68 Post(s)
Liked: 188
Umm, I think I made a goof there.
Should be 20*log(P/D).
bwaslo is offline
post #15 of 22 Old 10-06-2012, 08:41 PM - Thread Starter
Stereodude's Avatar
Liked: 2434
So, the passives are 824cm^2 and the Tumult is 749cm^2. So assuming I understand your post correctly... Per the formula I should add 0.83dB to each passive's measurement before summing the responses.
Without further ado, here's the new composite (blue trace) and the old composite (red trace): (Click the thumbnail for full size)
It only amounted to .9dB at the largest point though.
post #16 of 22 Old 10-06-2012, 09:29 PM - Thread Starter
Stereodude's Avatar
Liked: 2434
It'd have to be double digit inductance like 20 mH to cause that sort of roll off.
post #17 of 22 Old 10-06-2012, 09:50 PM
LTD02's Avatar
Liked: 2834
measured at what frequency? like impedance, inductance varies with frequency and is commonly measured at 1khz, which is kind of meaningless for subs.
LTD02 is offline
post #18 of 22 Old 10-07-2012, 05:03 AM - Thread Starter
Stereodude's Avatar
Liked: 2434
Well, I was simply increasing the Le in Unibox until I saw similar roll off characteristics.
post #19 of 22 Old 10-07-2012, 10:03 AM - Thread Starter
Stereodude's Avatar
Liked: 2434
Okay, so I pulled the driver and close mic'd it free air and got this: (Click the thumbnail for full size)
post #20 of 22 Old 10-07-2012, 10:18 AM - Thread Starter
Stereodude's Avatar
Liked: 2434
While I had the driver out I measured it with my DATS with the coils in series and got this: (Click the thumbnail for full size)
Feeding the measured T/S parameters back into the Unibox model gives me this: (Click the thumbnail for full size)
post #21 of 22 Old 10-07-2012, 10:33 AM
LTD02's Avatar
Liked: 2834
...in addition non-linearities in the inductance. inductance creates back emf. if the back emf is significantly different at different frequencies, the frequency response will be non-linear.
if you eq it for flat response, does it still suck?
LTD02 is offline
post #22 of 22 Old 10-07-2012, 03:48 PM - Thread Starter
Stereodude's Avatar
Liked: 2434
I haven't tried that. I did replace the Tumult with an AE AV15-H D2 and was pretty impressed. It sounds much better and not surprisingly measures much better too.
Comparison between the two drivers in the same 220L box with the same PRs: (Click the thumbnail for full size)
I guess trying to buy the biggest and baddest driver around doesn't mean you're going to get the best performing sub. Or, in this case even a decent performing sub. $384.84 down the drain after shipping (~10 year ago) and a lesson learned. redface.gif
