7 x RE Audio XXX 18" subs, Infinite Baffle Sub, Ultimate IB build - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #271 of 540 Old 12-02-2012, 05:22 PM
HFGuy's Avatar
Quoted: 197 Post(s)
Liked: 171
What is your impression of the Quest speakers so far ? Did they solve the buzzing problem you had with the Seatons ?
HFGuy is online now
post #272 of 540 Old 12-02-2012, 05:41 PM
pnw
pnw's Avatar
Quoted: 47 Post(s)
Liked: 76
Originally Posted by JapanDave View Post
It was always going to be 2 of each of the RE drivers, just which route should I go. 2 at the top of the wall and 2 on the bottom or the 2 to the left and the 2 to right.
In any case , I am going to use a single channel for each of the RE drivers for the time being while I get the LMS drivers and cabs built.
Assuming you are EQing in pairs??? Measurement is the only way to be sure of the best combination. Also test a cross corner configuration.
pnw is online now
post #273 of 540 Old 12-02-2012, 06:11 PM - Thread Starter
JapanDave's Avatar
Quoted: 160 Post(s)
Liked: 116
I love the Quested speakers. I don't have any issues with my ears with these. I can listen to them all day long without any problem. Very detailed ,but absolutely no harshness with the soft dome drivers, also base extention is very good
Yes, I was thinking of EQ'ing 2 speakers as a single sub. But, I have been contemplating just not using base management on the RS20i and EQ all 8 subs speperately as well as EQ'ing the other 6 channels separartely. This will just mean that all the subs will get all LF content instead of having the option to get the LF content from each speaker.
My build thread
My 8 x RE XXX 18" Subwoofers, IB build
Couldn't pour water out of a boot with instructions on the heel.
Do you know what Nemesis means?
JapanDave is offline
post #274 of 540 Old 12-02-2012, 06:13 PM - Thread Starter
JapanDave's Avatar
Quoted: 160 Post(s)
Liked: 116
Double post.
My build thread
post #275 of 540 Old 12-02-2012, 06:52 PM
HFGuy's Avatar
Quoted: 197 Post(s)
Liked: 171
Glad you got it all settled, yours was one of the first few threads I followed since getting back into the A/V hobby. You still using the datasat ?
HFGuy is online now
post #276 of 540 Old 12-02-2012, 11:14 PM - Thread Starter
JapanDave's Avatar
Quoted: 160 Post(s)
Liked: 116
Thanks. Yes , I am using the RS20i these days.
Just watched Tron with out any of the gaps sealed in the wall with only 2 connected up and all I can say is "Earthquake". These things are insane, the windows upstairs vibrate on the ULF, which I can only attribute to the actual sound waves. Please remember my house is completely built out of solid reinforced concrete and the thinnest wall is 10" thick, which just goes to show how powerful ULF sound waves are. There is virtually no vibration from the drivers they are that well braced, so I am relieved in that aspect.
I will report back when I have everything sealed.
Here is a quick pic.
My build thread
post #277 of 540 Old 12-03-2012, 09:52 AM
FOH
FOH's Avatar
Quoted: 38 Post(s)
Liked: 234
That's a glorious picture!
Briefly;
Basic premise, EQ all 8 globally, but time align in seperate groups.
If needed, I'd EQ the small sealed for their enclosure size (somewhat of a LT boost), align the two signal groups (the IB drivers, the box drivers) in time, global EQ for the overall room response, adjust low pass of small sealed, if needed for less localization.
It's possible you may need to subtly shift time alignment of box subs if localization is problematic. This is a final step, all other aspects first.
Love that pic, there exhists such an inherent advantage to baffle mounting (ie efficiency, eliminate SBIR, diffraction etc).
Great so far, the optimization is the hard part though, all about methodology.
Good luck
Active 16.8kw, 7.3 system
(2)Seaton SubM-HP, (4)18" IB
FOH is offline
post #278 of 540 Old 12-03-2012, 10:12 AM
HFGuy's Avatar
Quoted: 197 Post(s)
Liked: 171
Wow !! I am so jealous. I not sure I wanna know the price of that Quest setup, be years before i can have something like that.
HFGuy is online now
post #279 of 540 Old 12-03-2012, 11:57 PM - Thread Starter
JapanDave's Avatar
Quoted: 160 Post(s)
Liked: 116
Briefly;
I am not sure I understand when you say "EQ all 8 globally"?
Thanks, and Yes, Quested speakers are not cheapest speakers. I can't wait untile I get these sealed up. I just received a box of silicon to seal the gaps in the wall. Then I will start on EQ and that is when the fun starts.
My build thread
post #280 of 540 Old 12-04-2012, 08:00 AM
FOH
FOH's Avatar
Quoted: 38 Post(s)
Liked: 234
What I mean is as a set, all together.
There's many different ways to approach system/room EQ. Typically, I'd recommend you EQ globally once each of the two groups are contoured the way you want them.
Subwoofer drivers often need some boosting of the bottom octaves to overcome the air-spring of the box. Obviously, IB alignments oftentimes need much less of this boost than small boxes, but either way, shape the -3dB point the way you want. Also, if the bass management results in localization issues with the box subs out in the room, then the low pass of that sub group may need some adjustment later.
Now you need to move to the time domain, and assure the box subs and the IB drivers sum maximally in phase throughout their pass-band, especially and most importantly at the upper end of their shared range. Then globally, you align the entire group of all 8 subs to the mains in the time domain. Again, the shared/overlapping range is key here. Then globally EQ the FR output, but only from about 200hz or so downward. Above this point becomes a minefield acoustically, as it transitions out of minimum phase characteristics and we'll leave it at that. Much to complex an issue and I'm not able to articulate it well.
System EQ'ing isn't a trivial endeavor, be methodical and all will be fine. You can't EQ out the nulls, just gently knock down the bumps and the peaks, and use as little EQ as needed for any deviation. With as many LF sources as you have, once the time domain is sorted, you're likely to be quite pleased with the native system response without much global shaping.
Others may have various approaches as well.
On to the baffle wall,...after you seal it up, what's your intention for any covering? I'm guessing Dennis et al, has explained, however you need to be mindful of any small ingongruities, protrusions along the face of your baffle wall. The closer to the LCR elements, the more significant each protrusion. Unless you have a nice smooth, surface, you can benefit from absorption treatment. Felt is ideal is you need surface treatment, foam can be useful too. Often fiberglass duct liner type stuff is used too. Just a polite heads up, and you're likely already on top of it anyway.
Good luck Dave, pics would really be appreciated.
FOH is offline
post #281 of 540 Old 12-04-2012, 03:18 PM - Thread Starter
JapanDave's Avatar
Quoted: 160 Post(s)
Liked: 116
Ok, I see what you mean now. I was considering going the route you explained, but I was a little unsure as to how to integrate them after treating them as a group. As you already know, the Dirac live EQ is great for designing your own house curve. I am sure you have already seen this, but if you haven't this is what can be done with sub.
The beauty of this software is that you can shape the curve to what ever you want. All you have to do is click on a point on the red line, drag it to where ever you want and it readjust the curve to where you have set the curve at that particular frequency point. You could make it zig zag all over the place, have a bump at what ever frequency you want, it really is limitless.
I borrowed this from Peter (Cineramax)
This a pic of the higher frequency region.
______________
Thanks for the heads up on the wall finish. Dennis has given me instructions on how to finish the wall and it does include absorption. More pics when I get that far.
My build thread
post #282 of 540 Old 12-04-2012, 03:54 PM
mjaudio's Avatar
Quoted: 39 Post(s)
Liked: 75
mjaudio is offline
post #283 of 540 Old 12-04-2012, 04:46 PM
FOH
FOH's Avatar
Quoted: 38 Post(s)
Liked: 234
I've heard the Dirac system, over a quite nice 7.4 system; Seaton Catalysts, w/4 SubMersives, honestly I didn't care for it until a great deal of additional manipulation was performed. Dirac, it is however an incredible system.
FOH is offline
post #284 of 540 Old 12-04-2012, 05:16 PM - Thread Starter
JapanDave's Avatar
Quoted: 160 Post(s)
Liked: 116
Originally Posted by mjaudio View Post
Thanks!!!
Would that be a Cedia?
My build thread
post #285 of 540 Old 12-05-2012, 12:18 PM
FOH
FOH's Avatar
Quoted: 38 Post(s)
Liked: 234
Thanks!!!
Yep, Cedia.
By the end of the evening, the balance warmed up and became much better. Point is, I sure didn't care for the choices made via the software. I don't care for my Audyssey either. I can achieve a much better result myself.
FOH is offline
post #286 of 540 Old 12-05-2012, 06:38 PM - Thread Starter
JapanDave's Avatar
Quoted: 160 Post(s)
Liked: 116
Yep, Cedia.
I don't like the sound Audyssey gives in the end. Almost seems flat or maybe a better way to describe it is lacking dynamics.
Dirac is a different animal IME. I am yet to dive deep into EQ'ing using it, but my initial impression with just LCR's and Surrounds was good. The dynamics stayed and the sound stage was good. For someone like you who can actually use software like this, I think it would be even better. Anyways, I am going to be playing around with different settings etc, which should be fun.
My build thread
post #287 of 540 Old 12-05-2012, 06:52 PM - Thread Starter
JapanDave's Avatar
Quoted: 160 Post(s)
Liked: 116
Originally Posted by Ricci View Post
Hey Dave did you think about back mounting the drivers? I couldn't remember if you had 2 layer baffles or one.
Ricci, I meant to reply to this post earlier, but in the end I could not back mount them if I wanted. I did not have enough room in between the studs at the top and bottom of the drivers.
Cheers.
My build thread
post #288 of 540 Old 12-06-2012, 03:30 PM - Thread Starter
JapanDave's Avatar
Quoted: 160 Post(s)
Liked: 116
What is the consensus on dust getting into the drivers motor? I had cut away some concrete and it made a hell of a mess and even though I had the back of the drivers covered, a fair bit of dust settled on the cage and other parts of the driver.
I cleaned them best I could with a vacuum cleaner and a cloth, but I can't get into the motor. I have also cleaned out most of the dust that has settled now and the cavity is pretty much dust free. But, How do drivers stand up against dusty situations?
My build thread
post #289 of 540 Old 12-06-2012, 04:31 PM
mjaudio's Avatar
Quoted: 39 Post(s)
Liked: 75
If it's just fine dust then the XXX motors should do a good job of blowing it out. You could always get a couple of cans of compressed air and try blowing it out that way beforehand
mjaudio is offline
post #290 of 540 Old 12-06-2012, 05:16 PM - Thread Starter
JapanDave's Avatar
Quoted: 160 Post(s)
Liked: 116
I hope it is just dust, as there was little bits of concrete flying around as well. But, that is a great idea, I will do that.
My build thread
post #291 of 540 Old 12-06-2012, 05:47 PM
FOH
FOH's Avatar
Quoted: 38 Post(s)
Liked: 234
Concrete dust and small chunks of concrete all over $8K of the finest IB drivers in the world. eek.gif
Dave, bro .... redface.gif makes me cringe.
Everything's likely alright, but;
I'd carefully, use a shop vac and exercise the motor stroke by hand, allowing the debris to fall down into the vac nozzle. I know they're heavy, but pick the entire thing up and shake them vigorously too,..maybe two of you.
Above all else, do no harm.
Good luck
FOH is offline
post #292 of 540 Old 12-06-2012, 06:08 PM - Thread Starter
JapanDave's Avatar
Quoted: 160 Post(s)
Liked: 116
Good luck
Thing is , I had them covered b/c taking them down by myself was not an option. I did have them covered, but I am being paranoid to think that a small chunk may have found its way into the motor. And it really is just two of the motors that I am concerned with. I have been doing what you suggested above and I can't feel any resistance , nor can hear any scraping, so I am sure I am fine, I was just mainly concerned with the dust that remains in the cavity when I seal it up, b/c there is no way I can get all of it.
My build thread
post #293 of 540 Old 12-07-2012, 10:37 AM
FOH
FOH's Avatar
Quoted: 38 Post(s)
Liked: 234
Cool, prolly no problem.
You may hit them with some signal, and shop vac right up at the motor while they're stroking.
FOH is offline
post #294 of 540 Old 12-07-2012, 03:45 PM - Thread Starter
JapanDave's Avatar
Quoted: 160 Post(s)
Liked: 116
Well I have finally got the wiring sorted for the 3 x 30 amp breakers done today (by a professional), and that will give 180 amp worth of breakers just for the theater. So I will be able to fire up the Lab Gruppen 10000Q into all 4 of these drivers. eek.gif And FOH, I was thinking of doing what you said , slowly increasing the volume just to knock out any remaining dust.
The wall is almost completely sealed , I just have to run a bead of silicon around the center speaker and that is done.
I will also be getting a whole heap of pink batts for the cavity today and the absorbtion material for the baffle wall face as well. So if all goes well I will be done this weekend!!!!cool.gif
My build thread
post #295 of 540 Old 12-08-2012, 01:48 AM - Thread Starter
JapanDave's Avatar
Quoted: 160 Post(s)
Liked: 116
Well I fired up all 4 drivers today and good lord, these things are insane!!!!
Played the WOTW pod scene and the drivers are barely breaking a sweat, but the room is just shaking. I think I am going to wait until the wife is out of the house before I explore the limits of these things, but I have a feeling I will reach my limit before they do. Looks like REW is coming back out of hybernation to get some measurements to see how much room gain I am getting. A hell of a lot from what I can tell.
My build thread
post #296 of 540 Old 12-08-2012, 06:06 AM
keager's Avatar
Yessss!
keager is offline
post #297 of 540 Old 12-08-2012, 10:32 AM
mjaudio's Avatar
Quoted: 39 Post(s)
Liked: 75
That's sounds like an insane amount of fun!
mjaudio is offline
post #298 of 540 Old 12-08-2012, 05:57 PM
keager's Avatar
Tell us more Dave!
keager is offline
post #299 of 540 Old 12-08-2012, 06:04 PM
mjaudio's Avatar
Quoted: 39 Post(s)
Liked: 75
Originally Posted by keager View Post
Tell us more Dave!
I am anxiously awaiting updates too!
You guys and your XXX IB's are making me jumpy. I wish I could do a IB, RE is just down the street from me just teasing me to buy some more XXX's.
mjaudio is offline
post #300 of 540 Old 12-08-2012, 06:14 PM - Thread Starter
JapanDave's Avatar
Quoted: 160 Post(s)
Liked: 116
Hard to explain really. I have never ever really felt base like this in this room. I am not sure if it is shaking the floor or just vibration in the chairs. I am guessing it is just shaking the chairs b/c when in other parts of the house nothing is really being transferred into the walls of the house, so the base on the 2nd floor in the kids room is inaudible. The ULF however moves the upstairs windows and I can feel my pants vibrating a little when standing outside the room and outside my house near the basement walls, but the base is inaudible (My basement has no windows and the only openings are a hole in the wall for and exhaust fan and another on the other side of the room where the air comes in) Incredible really as to how the ULF is passing through 10" solid reinforced concrete walls.
Getting back to inside the room, base is just effortless. I have the receiver down 30dB's from when I was free airing one driver through the receiver. I was getting a fair bit of movement to try and see where the drivers limits were, but at 30dB down from there I have a long way to go now that they are in the wall. I just turned on the laptop and it has crashed again, so out to buy a new one today and get REW set up. I will try and get some measurements and see if I can't show you guys what I am feeling.
My build thread
