Quick question on polyfill in a push/pull enclosure - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 10-10-2012, 09:41 PM - Thread Starter
RTSW's Avatar
Liked: 30
A while ago I asked about isolating the polyfill in a push/pull enclosure from resting on the driver. However I didn't ask whether or not it was necessary. I have 2 push/pull subwoofers in this alignment (sub facing in on bottom, sub facing out from the "front"):
Do I need to use some netting or something similar to isolate the polyfill from the drivers or can I just fill it like a regular sealed enclosure?
RTSW is offline
post #2 of 6 Old 10-11-2012, 06:31 AM
Bill Fitzmaurice's Avatar
Liked: 4630
The magnet of the one driver and the cone of the other should not be in contact with damping.
RTSW likes this.
Bill Fitzmaurice is offline
post #3 of 6 Old 10-11-2012, 06:49 AM - Thread Starter
RTSW's Avatar
Liked: 30
Excellent, thanks for the response!
RTSW is offline
post #4 of 6 Old 10-11-2012, 11:34 AM
Stereodude's Avatar
Quoted: 3085 Post(s)
Liked: 2236
Originally Posted by Bill Fitzmaurice View Post
The magnet of the one driver ... should not be in contact with damping.
Isn't that sort of hard to accomplish? What's the harm in having the polyfill touch the motor assembly?
Stereodude is offline
post #5 of 6 Old 10-11-2012, 11:41 AM
KramerTC's Avatar
Quoted: 47 Post(s)
Liked: 31
My old M&K push-pull sub had a wire mesh inside the cabinet that kept the polyfill stuffing from touching the driver on the bottom.
KramerTC is offline
post #6 of 6 Old 10-11-2012, 12:09 PM
Liked: 4630
Heat build up.
