Arauco Ply / HD 'Cabinet Grade' Ply - AVS Forum | Home Theater Discussions And Reviews
post #1 of 66 Old 10-19-2012, 10:18 AM - Thread Starter
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
I've seen quite a few builds using this material.
Can anyone attest to the quality of this ply for speaker builds?
I've only used true 5' x 5' BB in the past for my builds. But the BB is always a little hard to get, and of course a tad more expensive.
smokarz is offline
post #2 of 66 Old 10-19-2012, 01:53 PM
lilmike's Avatar
Quoted: 71 Post(s)
Liked: 180
I use it when I can get it. Works better than about anything else outside of true Baltic or European Birch.
Arauco is very soft, but it is flat, relatively void-free, and works well. No complaints from me at all. Gonna buy another pile here shortly.
lilmike is offline
post #3 of 66 Old 10-19-2012, 02:59 PM - Thread Starter
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
thanks mike, good to hear.
i am not sure it's Arauco, but I am referring to the $30 4x8 3/4 sheet from Home Depot. I hope we're talking about the same thing.
smokarz is offline
post #4 of 66 Old 10-19-2012, 07:32 PM
Brad Horstkotte's Avatar
Liked: 73
In my area at least, Home Depot doesn't carry Arauco ply, but Lowes does. I used it for a pair of THT LPs and a pair of TLAHs, and it worked quite well. Baltic Birch is a bit nicer, but the Arauco works well and is cheaper.
Brad Horstkotte is offline
post #5 of 66 Old 10-20-2012, 03:19 AM
BrokenCrank's Avatar
I think you may be looking at "cabinet grade" based on your $30 price (it just went to $36 here in RI). I have used this for various things (some shelves and a translam mini-monitor that is under construction) and it is very void free. HD here in RI does have what I assume is similar to "Arauco ply"...they call it "sandeply" or something and i think it is 9 layer in 3/4".
BrokenCrank is offline
post #6 of 66 Old 10-20-2012, 04:03 AM
Mr.Tim's Avatar
Quoted: 281 Post(s)
Liked: 193
The cabinet grade ply was $35 here a few weeks ago. That's what I used in my builds and it worked fine. I noticed very few voids, and those voids were very small.
Nothing here was labeled Arauco. Didn't their plant burn down? The 9-layer ply was around $50 iirc.
Tim
Mr.Tim is offline
post #7 of 66 Old 10-20-2012, 04:58 AM
djginwis's Avatar
If it's Arauco, it will say so. It is softwood pine plywood from farm raised Radiata pines that are pruned to minimize branches, and thus knotholes. I used it for my Table Tuba. The 1/2" thick that I used did warp, but easily pulled straight for nailing. My local Menards has it.
djginwis is offline
post #8 of 66 Old 10-20-2012, 06:21 AM
Java's Avatar
Smoke,
Why are you going ply vs mdf for your SEOS build. If you are looking for a flat black finish, I'm thinking mdf is the way to go.
My noob understanding is ply is desired for a stained finish and/or lighter weight. Since this is for mains, not a mondo sub, weight isn't that bad.
Just my 2 cents...
Java
Java is offline
post #9 of 66 Old 10-20-2012, 07:08 AM - Thread Starter
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
That's exactly what I had in mind. I think they are now $32 in my area, still very cheap.
I had used them before for shelving in the basement and garage. They seem to look recent, but not sure they are 'speaker' grade.
smokarz is offline
post #10 of 66 Old 10-20-2012, 07:12 AM - Thread Starter
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
Originally Posted by Java View Post
Smoke,
Just my 2 cents...
Java
I just hate cutting MDF, and they are easily dented while building or moving them around.
I agree, Erich's MDF flatbacks look very nice and better quality than the MDF at local hardware stores.
If I hadn't invested so much $$$$ in tools, I would definitely get the flat packs. I feel really guilty doing so while the tools are lying around unused.
I am looking at the HD ply, because I'll probably end up painting them. If I desire a stain finish, I would go with the BB as I did in the past.
smokarz is offline
post #11 of 66 Old 10-20-2012, 09:43 AM
diy speaker guy's Avatar
Quoted: 505 Post(s)
Liked: 504
I've seen Arauco once at Home Depot and keep asking for it. I've always been told they've never had it and can't order it.
Then I finally realized that they call it "sanded pine", and even though it has the Arauco name stamped all over it, Home Depot employees don't recognize the name.
Once I finally figured this out and asked about availability, I was told they only get a single order once a year in November. (?!?) Oh well, it's almost November.
I've used 3/8 and 5/8. No complaints with 5/8 but the 3/8 warped terribly and due to the narrow panels I was using it was very difficult to pull back into shape during building. If I use 3/8 again I won't cut it until I'm ready to glue everything together, and do it quickly. Other than that it's lovely stuff, very light, but soft. You can dent it with a fingernail.
If anyone knows of a more consistent supplier in southwestern Ontario, let me know.
diy speaker guy is online now
post #12 of 66 Old 10-20-2012, 09:59 AM
lilmike's Avatar
Quoted: 71 Post(s)
Liked: 180
This is 1/2 inch Arauco.
3/4 looks the same, just adds 2 plies to the center. I can't get it at Lowes out here, HD used to have it. Now I have to drive up to Compton's in Seattle to get it cheap.
lilmike is offline
post #13 of 66 Old 10-20-2012, 10:07 AM
dB-Kicker's Avatar
I get mine from the local building supply. Haven't checked availability since half the Auraco factory burned down though. Pic is 3/4" sitting on 1/2". The 1/2" is factory edge - 3/4" ripped.. These are both over a year old.
dB-Kicker is offline
post #14 of 66 Old 11-04-2012, 10:51 AM - Thread Starter
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
Went to HD twice this week to look for their $30 'cabinet grade ply', but haven't seen them around.
Anyone know if they still stock them?
smokarz is offline
post #15 of 66 Old 11-04-2012, 10:55 AM
Mr.Tim's Avatar
Quoted: 281 Post(s)
Liked: 193
I was HD here about a week ago and they had the cabinet grade ply.. it's not $30-- I think it was $35 (maybe $39?). They also had "sand-e-ply" (I've forgotten the price) and some sort of oak ply for $50. I could see large voids in the edges of the oak ply.
Tim
Mr.Tim is offline
post #16 of 66 Old 11-04-2012, 11:05 AM - Thread Starter
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
I see the poplar ply, it was either $35 or $36.
I don't think it's the same stuff that I bought before.
It looks different.
smokarz is offline
post #17 of 66 Old 11-04-2012, 11:36 AM
pnw
pnw's Avatar
Quoted: 52 Post(s)
Liked: 78
Bought 3 sheets of 3/4" from the local HD (north Georgia) about 2 weeks ago for $34 per sheet. Display was marked "cabinet grade" but each sheet was labeled Arauco. Cut into about 60 pieces for a large wine rack & found only 1-2 small voids per sheet. I've also used it for several speaker builds & fill the (rare) void with wood glue.
pnw is offline
post #18 of 66 Old 11-04-2012, 12:27 PM - Thread Starter
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
Guess I'll have to go back in and ask for the cabinet grade ply.
smokarz is offline
post #19 of 66 Old 11-04-2012, 01:05 PM
Bill Fitzmaurice's Avatar
Liked: 5687
I can, as will a few thousand builders of my cab designs.
Sandeply isn't Arauco. It is poor quality, as is Blondewood. Arauco is the only big box plywood I've found to be usable.
Bill Fitzmaurice is offline
post #20 of 66 Old 11-04-2012, 01:33 PM
Mr.Tim's Avatar
Quoted: 281 Post(s)
Liked: 193
Mr.Tim is offline
post #21 of 66 Old 11-04-2012, 03:29 PM
tomlang's Avatar
Mr. Tim, I have run about 100 sheets of exactly what you show in your picture above thru my cnc machine this past year (in the summer of 2011, it was $25 a sheet but has steadily gone up). I have built speakers, large and small, murphy beds, display cabinets, kitchen cabinets, etc. and love the stuff.
tomlang is offline
post #22 of 66 Old 11-04-2012, 07:18 PM
Gorilla83's Avatar
Quoted: 378 Post(s)
Liked: 524
I recently built a workbench and speaker stands with this stuff. It seems like good material for the price although I hadn't considered it for speaker builds. Good to know, my HD usually has it in stock.
Gorilla83 is online now
post #23 of 66 Old 11-05-2012, 10:41 AM - Thread Starter
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
Found a link for this product on the HD web site. They do call it Arauco ply online.
Unfortunately, all my local HD are Out of Stock.
http://www.homedepot.com/h_d1/N-5yc1v/R-202519005/h_d2/ProductDisplay?catalogId=10053&langId=-1&keyword=cabinet+grade+ply&storeId=10051
smokarz is offline
post #24 of 66 Old 11-06-2012, 12:17 PM
beastaudio's Avatar
Quoted: 4148 Post(s)
Liked: 3504
Tim
Dont do it, had a void that ran through the entire sheet of one, didnt find it until I had cut into it. The BB i found looks as if two sheets are perfect, the other two are going back to be exchanged for two more that appear a little better on the edges. Overall I am very impressed with the wood quality tho.
Don't expect that to change for the better as their main plant in Chile burned down.
beastaudio is offline
post #25 of 66 Old 11-06-2012, 01:02 PM
Gorilla83's Avatar
Quoted: 378 Post(s)
Liked: 524
Damn, really? I just went through 2 sheets for random stuff I built of this stuff and it was virtually void free. frown.gif I'm getting ready to kick off a subwoofer build and was hoping to pick this stuff up vs. MDF since it's a bit easier to finish. I'll take a hard look at what's in stock, but I can always go back to MDF. Birch plywood is available at my local big box, but Baltic birch is no where to be found in my area. frown.gif
post #26 of 66 Old 11-06-2012, 02:44 PM
Quoted: 505 Post(s)
Liked: 504
http://www.homedepot.ca/product/5-8-inch-sanded-pine-plywood-19-32-inchx4x8/967017
Same product (except for thickness), same picture even, but in Canada they call it sanded pine.
post #27 of 66 Old 11-06-2012, 10:50 PM
Face2's Avatar
Quoted: 346 Post(s)
Liked: 208
My local HD's cabinet grade ply is full of voids. The only ply they stock which appears to have a halfway decent cross section has paper thin veneer that's certain to peel.
Face2 is offline
post #28 of 66 Old 11-07-2012, 05:31 AM
Liked: 5687
Solution: Don't go to HD. Go to a real lumberyard. If you're looking for cabinet grade plywood find a local kitchen cabinet maker in the Yellow Pages, ask him where he gets his wood.
vivatech likes this.
post #29 of 66 Old 12-05-2012, 06:13 PM
Mpray1983's Avatar
The sandeply from home depot looks good to me. The sales a associate told me it was void less. Can anyone confirm? Goes for about $45/sheet
Mpray1983 is offline
post #30 of 66 Old 12-05-2012, 07:42 PM
Liked: 5687
Sandeply is sub-standard.
