5-way binding posts: what's the fifth way? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By LTD02
post #1 of 7 Old 10-22-2012, 01:38 PM - Thread Starter
JakeRobb's Avatar
I couldn't find a better section than this one in which to post this question.
I count four ways:
What's the fifth way?
Living Room: Denon 2113ci + BIC V1020 + Panasonic BDT220 + AppleTV + uVerse DVR + Panasonic P42S2 plasma
Theater: Denon 2313ci + Klipsch RW12d + Panasonic BDT220 + Mac mini + uVerse wired receiver + Epson 8350 PJ + 100" screen
JakeRobb is offline
post #2 of 7 Old 10-22-2012, 01:51 PM
saeyedoc's Avatar
Quoted: 82 Post(s)
Liked: 69
Pins?
saeyedoc is offline
post #3 of 7 Old 10-22-2012, 01:52 PM
cookieattk's Avatar
Quoted: 111 Post(s)
Liked: 89
HUMM u could shove the wire through the hole where the banana goes and then into the hole for the strait wire then tighten it down.
cookieattk is offline
post #4 of 7 Old 10-22-2012, 01:54 PM
saeyedoc's Avatar
Quoted: 82 Post(s)
Liked: 69
Here's the wikipedia entry, looks like I was correct:
Commonly designed in a style called five-way or universal, such binding posts allow the connection of several different types of connections:
Banana plugs, inserted into the open end of the binding post
Pin connectors, inserted into a hole drilled through the metal post and clamped by the screw-down portion of the binding post.
Bare wire inserted through the same hole and clamped, or
Wrapped around the metal post and clamped.
A lug terminal inserted around the metal post and clamped.
saeyedoc is offline
post #5 of 7 Old 10-22-2012, 02:01 PM
Point Source
beastaudio's Avatar
Quoted: 3487 Post(s)
Liked: 2821
or curve the pin connector 6, and shove the pin connection in banana hole 7, or shove banana in pin hole 8!!!
beastaudio is offline
post #6 of 7 Old 10-22-2012, 08:32 PM
Looneybomber's Avatar
Liked: 25
I actually put my banana plugs in the drilled hole and tighten down, that way my wire is pulling nearest the chassis and thus keeps leverage on my side, i.e., it keeps from pulling too hard on the binding posts.
YID DIY
Looneybomber is offline
post #7 of 7 Old 10-22-2012, 09:16 PM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2570
"The fifth connecting method doesn’t find itself used much in modern audio applications, but the original General Radio product brochure described using “alligator clips,” which are spring loaded clips that have (you guessed it) gripping teeth."
http://www.polkaudio.com/polk-university/articles/binding-posts
bmihlfeith likes this.
Listen. It's All Good.
LTD02 is online now
