First DIY project for a guy looking to upgrade - multiple sealed 18s? - Page 31 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #901 of 1016 Old 02-19-2013, 07:32 PM
LTD02's Avatar
Quoted: 2524 Post(s)
Liked: 2867
archea summed it up well. the 3000dsp leaves a little on the table driverwise (not quite enough amp), while the 6000dsp leaves a little on the table amp wise (a little too much for the drivers). the cvx is a good match between 4 drivers and the amp, but doesn't have on board dsp. for an extra hundred the 6000dsp is probably the way to go and use the limiter to protect the drivers.
Dank1209 likes this.
Listen. It's All Good.
LTD02 is offline
post #902 of 1016 Old 02-20-2013, 08:51 AM - Thread Starter
Gorilla83's Avatar
Quoted: 378 Post(s)
Liked: 523
Originally Posted by beastaudio View Post
Order the real deal boards from LG then smile.gif probably not that bad if they ACTUALLY let you have them!!! .
Oh hell no, they will be more than the cost of a 'replacement' Sanway clone, LOL. Not to mention I'm sure there are differences between a real LG board and the Sanway versions.
For the record and clone haters out there: My amp was working 100% until I was moving a sub around, had terminals come loose, and shorted. The amp went into protection mode and has stayed there since, blowing fuses. An expensive lesson learned, but an experience and part of the 'game' nonetheless. tongue.gif
Anyway, every shipping quote I got was way too much for me. I'm ordering a few new boards and a 'backup' FP14000 amp to go with them since I will be paying shipping anyway. smile.gif I've shot a PM to Keager and have access to a few buddies (and family) that are fairly decent with this stuff so I'll enlist their help. Once the amp is fixed I'll have my power source for my ported SI 18 build upstairs. biggrin.gif
Gorilla83 is offline
post #903 of 1016 Old 02-20-2013, 10:16 AM
Diesel 48's Avatar
Quoted: 71 Post(s)
Liked: 33
Thanks for clarifying what happened. I was planning on getting the clone but started to hesitate based on your experience. Knowing that something happened due to shorting is good to know!
Diesel 48 is offline
post #904 of 1016 Old 02-20-2013, 11:32 AM
beastaudio's Avatar
Quoted: 4103 Post(s)
Liked: 3424
I buttoned mine back up last night with the fan mod completed. Minus getting used to the soldering gun in my hands again, it was a cake walk. Mine is still trucking right along as well smile.gif
beastaudio is online now
post #905 of 1016 Old 02-22-2013, 05:10 AM - Thread Starter
Gorilla83's Avatar
Quoted: 378 Post(s)
Liked: 523
Good to hear, Beast! I've got new boards on the way for mine as well as an extra amp. biggrin.gif It was tough shelling out the cash again but in the end I'll hopefully have 2 functioning beasts and some spare parts as well. cool.gif
post #906 of 1016 Old 02-22-2013, 11:57 AM
popalock's Avatar
Quoted: 1291 Post(s)
Liked: 1805
I've been meaning to call you like every day this week to get in on that buy...dammit!
popalock is offline
post #907 of 1016 Old 02-22-2013, 12:23 PM
bass addict's Avatar
Quoted: 372 Post(s)
Liked: 448
Achievement Unlocked
Psychotic Episode Averted
bass addict is online now
post #908 of 1016 Old 02-22-2013, 04:51 PM
Sibuna's Avatar
Quoted: 381 Post(s)
Liked: 446
whats this now????????????
Sibuna is offline
post #909 of 1016 Old 02-23-2013, 06:57 AM - Thread Starter
Gorilla83's Avatar
Quoted: 378 Post(s)
Liked: 523
I'm thinking I've got these nice SI drivers sitting around, might as well put them to use. I'm sure they would be a fine replacement for the 'Emps.
Originally Posted by bass addict View Post
Guys - Since the Clone has been down I've been listening to the Crown bridged on just two subs nearfield. The more I dial it in the better it sounds! I've developed a severe dislike for Audyssey and spent about an hour this morning listening with it disabled. I think I had the volume up to +5 for a straight hour without the slightest sound of distress. IMO it's an enormous improvement. I guess I'm quite fond of the midbass combination these subs and my new mains provide - simply incredible!! I could probably sell the other two subs and leave it just like this and be perfectly happy. But since I already have the other two..... biggrin.gif
post #910 of 1016 Old 02-23-2013, 07:24 AM
Java's Avatar
Thanks LTD and Archea!!
Sound advice (pun not intended), as always.
The delta between the 6000 and 3000 is more like $150. Amazon has the 6000 DSP for $500 vs the 3000 DSP for $350. I question if I'll push the subs (2x Dayton 18 HOs) to hit a wall with the 3000, but it may be good peace of mind.
On the limiter, the drivers are rated at 900 watts, but Ricci recommends up to 1500 watts: http://www.data-bass.com/data?page=system&id=89. So, if I limit to 1,500 watts is that cool or do I need take into consideration the amp might not drive at the "stated" power. I've read threads on the real vs inflated power, so I'm assuming I would take that into consideration when setting the limiter, correct?
Thanks, again
Java is online now
post #911 of 1016 Old 02-23-2013, 09:21 AM
Ricci's Avatar
Quoted: 246 Post(s)
Liked: 574
Java,
Personally I would lean towards the 6000 for very little up charge. I like more amp vs less, but that is just me. You could run 2 drivers in series at 8 ohms on one channel. That should be around 1500w or so for the 2 drivers and that should be plenty to get them going (750w each). A channel on each might be a bit much without setting some limiter settings. If you try that just be careful with the gain for awhile. Anyway with the 6000 you could add another 2 drivers down the road for the other channel and have a nice 4x18 bass system for very little or switch to some more powerful drivers later on with a 4ohm load and get a bit more power potential.
Ricci is offline
post #912 of 1016 Old 02-23-2013, 09:26 AM
LTD02's Avatar
Liked: 2867
here is a test of the 6000: http://forum.speakerplans.com/behringer-inuke-nu6000-vs-kam-kxd7200-bench-tested_topic69202_page1.html
i would assume the voltage in the limiter is right and not make any adjustment for the fact that the amp markets its peak power ratings vs. its sustainable ratings.
LTD02 is offline
post #913 of 1016 Old 02-23-2013, 07:54 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5972 Post(s)
Liked: 5025
Originally Posted by Ricci View Post
Java,
Scott Simonian is offline
post #914 of 1016 Old 02-24-2013, 08:12 AM
Java's Avatar
Java,
Yep. Sound advice.
Given the low cost of the Dayton HO and Erich's flat packs, 4 subs may be in my future (long term, mind you). Always good to "future proof".
Java is online now
post #915 of 1016 Old 02-24-2013, 08:12 AM
Java's Avatar
Cool. Thanks, LTD!
Java is online now
post #916 of 1016 Old 03-13-2013, 07:02 AM
Diesel 48's Avatar
Quoted: 71 Post(s)
Liked: 33
So based on these comments can 2 of Gorrilla's boxes (4 drivers) be run on the iNuke 6000dsp? If so how would one go about that? My boxes are almost complete. My duratex should be coming in tomorrow for final finishing. Then I will need to sell my SVS PB13 Ultra in order to buy some drivers.
post #917 of 1016 Old 03-13-2013, 11:38 AM
brian6751's Avatar
Quoted: 1140 Post(s)
Liked: 1120
i dont think 4 Daytons are a good match with the 6000. the SI D4's would work
That's not science! - Cyborg
FOR SALE: 120" 16:9 Silver Ticket AT Screen
Rivers Edge Theater
brian6751 is online now
post #918 of 1016 Old 03-13-2013, 11:43 AM
Bass Enabler
Liked: 5025
It would work, one would just have to hook two up into an 8ohm load since the 6k doesn't do 2ohm loads. However, d4's from SI would be even better and that's something I'll be doing. smile.gif
post #919 of 1016 Old 03-13-2013, 11:44 AM
Diesel 48's Avatar
Quoted: 71 Post(s)
Liked: 33
hmmm... So with the Daytons I can either use the LG clone or CV5000. I eventually plan on having 4 boxes (8 subs) but that is further down the road. If I did that I know I can use just the one LG clone but would another CV5000 be needed?
post #920 of 1016 Old 03-13-2013, 11:46 AM
Bass Enabler
Liked: 5025
Lol, guess I posted just as you were. You can use the iNuke 6000 if you want.
post #921 of 1016 Old 03-14-2013, 09:04 AM
MKtheater's Avatar
Quoted: 1735 Post(s)
Liked: 1301
I am ordering a 14K clone again.
Marantz 7702 Atmos
Outlaw 7140 and 5000
Speakers- DIY mini arrays all channels.
subs 2 XXX ported SLLT.
MKtheater is online now
post #922 of 1016 Old 03-14-2013, 10:00 AM
nube's Avatar
Quoted: 76 Post(s)
Liked: 444
Based on the frequency responses on that bench test of the NU6000, I would absolutely not use it for sealed sub duty.
From teslaman over at the speakerplans.com forums (not my image):
It's down 2dB at 10hz, but sloping down sharply. No mention of how it's performing at 5hz, but I suspect it's just like the other end of the curve, -5dB at 5hz, and -8dB at 2.5hz. This is bad if you want the lowest octaves. Why else would you go multiple sealed?
It also looks to add about 1% THD+N at significant drive levels in bass duty. Probably not worth quibbling about, but there are likely better choices for multiple sealed alignments.
MemX likes this.
nube is offline
post #923 of 1016 Old 03-15-2013, 08:14 PM
bossobass's Avatar
Quoted: 78 Post(s)
Liked: 671
I agree.
I wish folks would post a loopback of their player, AVR and any other outboard hardware that's in line (like the DCX, MiniDSP, etc.)
I have a loopback of the Onk AVRs, Oppo players and the DCX. If you add the NU amp to that chain, you're down -30dB @ 3 Hz, -14dB @ 5 Hz.
For contrast, using the new [To Be Revealed Soon] into the SEQSS and Clone, the signal chain is down -1dB @ 5 Hz and -5dB @ 3 Hz. That's when you find out what your system is made of, but you need far less displacement because it's all being used relative to the rest of the signal chain.
IOW, say you have 16-18" RS18s. That gives you 50 or so liters of displacement capability, but if you're down -14dB @ 5 Hz, and -30dB @ 3 Hz, your math is destroyed in the model which doesn't reflect that roll off in your modeled L/T and there's no safe way to compensate for it either (at least all of my attempts failed miserably).
My 8x15" Tumult based system gave me just about the same displacement as the 16x18" RS18 system, only it was 10 years ago. I was using an Outlaw pre/pro into a Marchand Bassis powered by QSC amps. I was only down -4dB @ 5 Hz and -15dB at 3 Hz and the roll off was exactly reflected in all of my posted in-room FR graphs and later in my SpecLab caps of mic'd movie scenes.
The new roll off caused a redesign of SEQSS, drivers, enclosures and power plant, but what a ride. I can best most any LMS-based system below 10 Hz using lowly 15s simply because the LMS drivers just aren't getting the signal.
Since I have 100s of SL caps for comparison, the proof, as always, will be in the pudding for anyone who cares to see.
I'm prepared for the majority to ignore it all and argue ad nauseum against the facts of the matter as SOP around here. What a shame. The recent spate of mega builds could be ramped up quite a few notches on the Holy S@%# scale.
Nice to see ya posting, Nube. Wish you'd bump your build thread with pics of how it ended up. cool.gif
bossobass is offline
post #924 of 1016 Old 03-15-2013, 09:04 PM
HuskerOmaha's Avatar
Quoted: 65 Post(s)
Liked: 55
Yes? No?
I need to buy another FP14k so I can skip my junction box.
HuskerOmaha is offline
post #925 of 1016 Old 03-21-2013, 04:11 PM
nube's Avatar
Quoted: 76 Post(s)
Liked: 444
Originally Posted by bossobass View Post
I agree.
I don't understand why more people, while jumping on the multiple (overkill) sealed bandwagon, don't make this their top priority after driver selection. If reproducing as close to DC @ reference is the pursuit, I can think of NOTHING more important than knowing your signal chain rolloff. If it's bad, you absolutely should either invest in new equipment, or give up the ghost on that pipe dream.
Likewise, bosso. smile.gif It's been awhile. I'll bump that thread with finished shots as soon as I get the tops squared away. I just took the first comprehensive exam for my PhD yesterday, and that's been the thrust of my focus this year so far. Now I have a little free time and, with summer coming up, I'll have some stuff to post about. (Assuming I'm not spending the summer in Mexico again...too hot!)
I really hope your new endeavors are shaping up and shipping out! I'm curious to see (and hear!) how it all turns out. If you ever need a guinea pig... wink.gif
Originally Posted by HuskerOmaha View Post
Yes? No?
Another stranger! Welcome back, HO.
I think another FP14k is absolutely necessary if you can afford to take another chance. On second thought, you haven't had the best luck with audio purchases from non-US suppliers...so maybe not!
nube is offline
post #926 of 1016 Old 03-21-2013, 04:19 PM
Bass Enabler
Liked: 5025
I'll speak for my situation cuz I'm going to have a crazy huge sealed system...
In my case, I'm severly limited on funds. That and I don't feel comfortable purchasing an amp like the clones which have fantastic low end capability. Also, I will have a DCX in the chain (which has some rolloff below 10hz) and it's functions are more important to me than <5hz extension. As much as I desire it. I have to place my priorities. I could wait forever and never finish this huge project that has taken up about three years of my life and save enen longer to get the clones or something better than the DCX. (I don't know of any that do what I want, maybe the MDSP) So I have to deal with the lack of flatness <10hz for a while. It's not like I can't upgrade later in my life.
post #927 of 1016 Old 03-21-2013, 04:23 PM
nube's Avatar
Quoted: 76 Post(s)
Liked: 444
See, Scott, in your exact situation I see absolutely no reason to upgrade. You already have prodigious output to 10hz. If you're not concerned with output <10hz, why change?
nube is offline
post #928 of 1016 Old 03-21-2013, 04:37 PM
Bass Enabler
Liked: 5025
No high pass no matter how hard I push the new gear, built-in capability for <10hz.
And yes.... I very much desire <10hz capability but just because it have rolloff 10hz and below doesn't mean I won't have any. A quick swap out of an amp and bamo! 5hz extension.
post #929 of 1016 Old 03-22-2013, 07:19 PM
Quoted: 65 Post(s)
Liked: 55
Send me the cash for the clone and I'll order us each one.
#maybe
post #930 of 1016 Old 03-22-2013, 08:50 PM
Quoted: 372 Post(s)
Liked: 448
Dayton Audio Rss460ho 4 18 Reference Ho Subwoofer 4 Ohm
