BassThatHz Theater Build - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 74Likes
post #271 of 1025 Old 02-24-2013, 04:16 AM - Thread Starter
BassThatHz's Avatar
Quoted: 2031 Post(s)
Liked: 1547
I miss my full system so much. I'm having bass withdrawals, like a crack addict needing a fix tongue.gif
I didn't know she lived in Mission until I read her wiki article.
I just happen own a home in Mission, just down this road a distance. (If you live there, you know this intersection very well).
I don't live there though, and I never would want to either... [I'll explain why in a moment.]
I'm not from that area, but my cousin is, the two of them probably went to high school together. The town has only 36k people in it.
Small world, I guess...
I would NEVER want to live there though because the place smells like mold and carbon-monoxide; it's just east of Vancouver, where it gets it's wind from. A city with the 2nd worse traffic congestion on EARTH, second only to LA.
For example, you will spend 20minutes going through one 20ft intersection. It's that bad.
The mold comes from being so close to the ocean.
Whenever I'd visit to my cousins place, their weather would always be a 50% chance of rain. LOL
and that's about all I have to say about that region of space-time.
Originally Posted by JapanDave View Post
You will want to make sure that cloth is acoustically transparent if you are using it for such things.
No worries, it is just to hide my bass traps, I'm not planing to put speakers behind the material.
BassThatHz is offline
post #272 of 1025 Old 02-24-2013, 05:22 AM
chrapladm's Avatar
Quoted: 823 Post(s)
Liked: 286
Try H1 traffic in Hawaii. That is bad. LOL
chrapladm is offline
post #273 of 1025 Old 02-24-2013, 05:27 AM
Mr.Tim's Avatar
Quoted: 277 Post(s)
Liked: 180
4/0 aluminum is rated at 205A. The panels are rated at 225A each. An 800A service would have parallel 500MCM Cu conductors.
You have 800A available across both ungrounded conductors (200 per leg x 4 legs), but it's referred to as a 400A service.
Still plenty of horsepower. Twice what my house has.
Mr.Tim is offline
post #274 of 1025 Old 02-24-2013, 05:34 AM
JapanDave's Avatar
Quoted: 160 Post(s)
Liked: 116
Even base traps will affect higher frequencies if the material is not acoustically transparent.
My build thread
My 8 x RE XXX 18" Subwoofers, IB build
Couldn't pour water out of a boot with instructions on the heel.
Do you know what Nemesis means?
JapanDave is offline
post #275 of 1025 Old 02-24-2013, 09:53 AM
King George II's Avatar
Sorry for OT, but what was the music you were using for your "Rear Speaker Test"-video? It sounded somewhat familiar but I can't place it.
Great project by the way, I wish I had the resources and skills to do something like this!
King George II is offline
post #276 of 1025 Old 02-25-2013, 10:18 AM - Thread Starter
BassThatHz's Avatar
Liked: 1547
She is Norwegian FYI. Kate Havnevik - Sleepless
post #277 of 1025 Old 02-25-2013, 11:33 AM
FOH
FOH's Avatar
Quoted: 38 Post(s)
Liked: 234
I realize some are aware of this, but what many individuals forget/don't know is conductor size is based upon both the load, but also the length of the run and other factors as well (it's environment). To avoid problematic voltage drop, conductors are increased in size ... sometimes several sizes ... to alleviate the effects.
This can be occur anywhere from feeders, to branch circuits. Oftentimes it's beneficial to upsize the AWG in circuits feeding items such as subwoofer amps, so that the current delivery isn't compromised in any way ... the wire acting as a choke point for stiff voltage delivey of high current.
As stated, the branch breaker can easily pass enormous amounts of current past the normal rated size;
For example, a 20 amp circuit can pass 7-8 times the rated 20amp trip amount, .. for up to a second or more.
It will allow up to 3x the rated amount for up to 10sec or so.
And the same 20amp circuit, can allow up to 1.5-2times the rated amount for a period extending as long as 30 seconds.
So those long runs of 14awg, 12awg feeding one's amplifiers/subwoofers, could very well be a limiting factor.
Active 16.8kw, 7.3 system
(2)Seaton SubM-HP, (4)18" IB
FOH is offline
post #278 of 1025 Old 02-25-2013, 12:19 PM
Thanks, much appreciated!
post #279 of 1025 Old 02-25-2013, 12:21 PM
djkest's Avatar
Quoted: 26 Post(s)
Liked: 39
I was messing with my panel yesterday and I swear it has a 200 amp breaker as the main breaker. Seems a little weak. Is that 200 amps at 240 volts, or 200 amps at 120 Volts?
IIRC 200 amps is only ~45,000 total watts. Of course, I have a gas furnace, and a gas water heater. But that doesn't seem like a lot of juice. It's not that big of a house.
djkest is offline
post #280 of 1025 Old 02-25-2013, 05:10 PM
FOH
FOH's Avatar
Quoted: 38 Post(s)
Liked: 234
200 amps is 200 amps. If one is sizing wire size in AWG, the voltage doesn't matter, thus,.. 200 amps is 200 amps.
That said, the voltage does come in to play when determining total capability to perform work ... KVA, KW.
Voltage also comes in when determining other aspects like insulation, spacing, etc.
A 200 amp single phase service has 48kva total capability, for this discussion we'll just use kw instead of kva.
P=E(I)
(200a)(240v)=48kw
or each leg individually it's still the same
(200a)(120v)+(200a)(120v)=48kw
Your panel is a 200 amp/240 volt single phase panel
FOH is offline
post #281 of 1025 Old 02-25-2013, 05:57 PM - Thread Starter
BassThatHz's Avatar
Liked: 1547
Here's some pics of my new 320sqft master bedroom.
Walk in closet and heated 2-person bubble tub.
It's a 5 bedroom house, 3 baths. 3 up, 2 down.
post #282 of 1025 Old 02-25-2013, 07:14 PM
pokekevin's Avatar
Liked: 102
Your thread should be NSFSIU - Not Safe for slow internet users lol. Looking forward to seeing the end result!
pokekevin is offline
post #283 of 1025 Old 02-25-2013, 11:11 PM - Thread Starter
BassThatHz's Avatar
Liked: 1547
Here's 21kW's, maxing out my LMS here.
and 30kW's
Just some vids, I never uploaded.
I wouldn't be surprised if my new room has even more SPL (and hopefully SQ too).
5 windows vs none
open design vs air tight
post #284 of 1025 Old 02-26-2013, 09:15 AM
djkest's Avatar
Quoted: 26 Post(s)
Liked: 39
P=E(I)
(200a)(240v)=48kw
Yeah, I said 45kW because I"m not sure if I have 120V actual, I think last time I checked I'm getting 113 Volts. Wonder if I'll have to get my panel "expanded" if I want to add a 30 amp service to my basement theater area build? They only put like 3 outlets in the basement and 3 single bulb fixtures. Stupid.
ETA: back on topic, master bedroom looks pretty sweet. 320 square feet is a nice size, roughly 16 x 20. I think our Master is 14 x 15 and I've always wanted just a little bit more.
djkest is offline
post #285 of 1025 Old 02-26-2013, 08:32 PM
Looneybomber's Avatar
Liked: 25
Status Update: Bought 1300sqft of fabric today. Hopefully it is enough to cover it eek.gif
I bought it at a thrift store for 15cents a square foot, an amazing deal.
It's amazing what you can find in such places.
"Walk up to the club like, what up, I got a big c@%k!
I'm so pumped about some s#!t from the thrift shop"
YID DIY
Looneybomber is offline
post #286 of 1025 Old 02-26-2013, 09:51 PM - Thread Starter
BassThatHz's Avatar
Liked: 1547
It smells like R Kelly's bed sheets. Stuntin' bright like a di-a-mond. biggrin.gif
post #287 of 1025 Old 02-27-2013, 10:11 AM
Audiophile1178's Avatar
I've got only a 100amp or maybe 120amp line in my house and the "main panel" is actually a sub panel. The main breaker for the panel is below the meter outside. Anybody can turn off anybody's power whenever they want and most people don't even know that there's a breaker under the meter so they'll end up calling the electric company and waiting for something that may just be a prank. Fortunately, there was one spot left on my panel to where I was able to add a dedicated 20a breaker for my sub amp that I ran with 10 gauge cable. Unfortunately, it's not really dedicated as it powers my HTPC, Rotel amp, Processor, and a few other things but it's better than being on the same line with all of my other outlets. I'm thinking about replacing the panel with one that has more spots for breakers but am not sure if it's something that i'm up to the task of doing myself.
BTW, I live in an 800 square foot condo which used to be apartments.
Audiophile1178 is offline
post #288 of 1025 Old 02-28-2013, 08:16 AM
dstew100's Avatar
Been following along for awhile now. Really enjoying this build, thanks for documenting it and sharing it with us. This is awesome.
I'm rooting for a strong finish, keep up the great work.
dstew100 is offline
post #289 of 1025 Old 02-28-2013, 02:13 PM - Thread Starter
BassThatHz's Avatar
Liked: 1547
Status Update: The PoCo just connected up the new main line.
My new main line, same size conductor as the block's line.
I'm smack between a (total) potential of 47kV's worth of transformers at a distance of 40ft each side (left+right).
There is 16 houses here, on a 700ft span sharing this total of only 97kV's; so by comparison I'm not doing too bad compared to those suckers out at 350ft! biggrin.gif
Right Side
As you can see, they split the line, it isn't shared to the right side of my right side. (Not sure if that's a good thing or bad thing though. 20kV sitting right there that I can't get to.)
Left Side:
post #290 of 1025 Old 02-28-2013, 04:51 PM
dstew100's Avatar
I think you just made a watch list or three
ahands likes this.
dstew100 is offline
post #291 of 1025 Old 03-01-2013, 02:51 AM - Thread Starter
BassThatHz's Avatar
Liked: 1547
My profile is already in the FBI, DHS, and CSIS databases, has been for years now. I signed a document saying that they can\will have my profile in their databases.
They have biometric scans of my body parts on file, they know every place I've ever lived in, every person I've ever worked for, and for how much, and for how long. and that's not all.
They have all of this stored inside Iron Mountain. I know this because they told me so.
post #292 of 1025 Old 03-01-2013, 08:38 AM
fschris's Avatar
Quoted: 18 Post(s)
where do you live , it looks beautiful.............
ASROCK H67 GE / HT/Core i3
Emotiva XPA2 Gen2 x2
Carver AV-705 5Channel AMP
Zaph 2.5MM TT'S DIY
Emotiva UMC 200
2 x MFW 15 Clones DIY
fschris is offline
post #293 of 1025 Old 03-01-2013, 09:29 AM
FOH
FOH's Avatar
Quoted: 38 Post(s)
Liked: 234
47kv's worth?
I'm not a lineman, or ever work for a power company, but what you're looking at is a 37.5 kva single phase transformer in that fourth image. If all the pics are taken from your property (which is what it appears), you're fed off the 37.5kva transformer, which is fed from a single leg of 7200v (14.4kv phase to phase). The pole to the right appears to have three phase set of 10kva transformers, and it looks like they're not connected to you in any way. I may be wrong, and it's tough to see exactly, but it appears as if there's a raceway going down the back side of the pole, and they're likely feeding it in addition to the remaining loads to the right.
As I stated, it's tough really determining the lines on the right hand pole, but I see no connection to you.
The high voltage lines are likely 7.2kv/14.4kv, that is 7.2kv each, and phase to phase that's 14.4kv. The 10 rating you see on the right side transformers (and the 37 on the left) is the kva rating, .. or total capability in kilo-volt-amps. So you, and whomever else shares that load side lateral feed running across the bottom ... pole to pole, you all are in parallel and share that feed. In open air, the ampacity is higher. The capabilities we typically associate with grouped wiring in cable assemblies, or in conduit etc, are different. Thus POCOs can thru-put more current through a given size wire than typical residential code provides for in homes.
NOW... let's see if I can blow them up.
I can see everyone's lights dimming to the beat of a big fat, heavily EQ'd kick drum, ... your HT out-building just pulsing structurally to every thump cool.gif
Thanks for sharing, and best of luck
FOH is offline
post #294 of 1025 Old 03-01-2013, 10:10 AM
bass addict's Avatar
Quoted: 360 Post(s)
Liked: 437
5 windows vs none
Achievement Unlocked
Psychotic Episode Averted
bass addict is offline
post #295 of 1025 Old 03-01-2013, 10:21 AM
MKtheater's Avatar
Quoted: 1588 Post(s)
Liked: 1116
I don't understand how you figure your total watts? You say 21KW but that for sure would blow up that sub. You can 100KW available but you won't use that much, I bet the most you will use is closer to 10Kw and that is with everything. I don't even use 6KW(subs) to reach 130 dBs at the LP.
Marantz 7702 Atmos
MKtheater is online now
post #296 of 1025 Old 03-01-2013, 11:45 AM - Thread Starter
BassThatHz's Avatar
Liked: 1547
It's peak potential, not measured consumption.
The last time I measured the legs (old house) it was about ~47amps at 120v of real load on the legs. Which is probably just under 5000watts RMS going to the coils in 2-ch music mode + subs.
I live between the North West Cascades and the Rockies, about 150miles in land from the Pacific Ocean.
post #297 of 1025 Old 03-04-2013, 12:15 AM - Thread Starter
BassThatHz's Avatar
Liked: 1547
Ok I'm officially broke. I've spent $150,000 in cash over last 4 months buying/building all this worldly junk... and loving every minute of it. biggrin.gif
and the bills just keep stacking up higher, although their pace is slowing down, and I can see the light at the end of the tunnel, probably another 12k should cover it.
But whenever I find myself lost, I just simply recall this idiot and the 6 million dollars he has completely wasted on his butt-ugly system; and then I sleep much better at night, knowing that money is no substitute for brains. LOL
The solution, is clearly, to add more items, until it becomes the goodererest. LOL wink.gif
ZeGhostbear likes this.
post #298 of 1025 Old 03-04-2013, 01:03 AM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2573
is it my eye or is the subwoofer in the picture not even connected?
Listen. It's All Good.
LTD02 is offline
post #299 of 1025 Old 03-04-2013, 01:42 AM
audiovideoholic's Avatar
Quoted: 588 Post(s)
Liked: 185
I've always loved that setup with book shelves for treatments. It's not pretty but bet it looks/sounds perfect!
audiovideoholic is offline
post #300 of 1025 Old 03-04-2013, 03:27 AM
mazdaspeed3's Avatar
is it
No, what are you talking about? Those are the new, you can't see them ultimate transparency king of cables.tongue.gif Ha ha, good eye, saw that one before, but didn't recognize that there was no wire going to the sub.
mazdaspeed3 is offline
