Here is what I'm starting with. This has to be beefed up significantly.
For this one, I was thinking of removing all windows and using furring channels on all 5 sides with sonoclips, DD/GG/MDF with a backing of acoustimat rubber VB, Roxul and then R-20. Dricore and padded carpet on the floor.
Single studded 2x4 until spring time, and then if need-be, beefed up to double-studded and/or another DD/GG/MDF and/or with cinderblocks.
Basically, I'm trying to contain 100% of the bass... ideally / if possible
The slab is currently 20x16ft, but I'll be adding another 8ft to the front, and upgrading the 50amp to a 100amp run.
It will have an amp rack, projector hood, AC, wall heaters, track lighting, and a security alarm.
I was thinking of possibly making my own 400lb exterior soundproofed security-door, and then having another inner sliding-glass door; if need be... one of these: http://www.soundproofwindows.com/recording_studio_doors.html
