BassThatHz Theater Build - Page 27 - AVS Forum | Home Theater Discussions And Reviews
 19Likes
post #781 of 808 Old 06-28-2015, 11:46 AM
johnson636's Avatar
Quoted: 111 Post(s)
Originally Posted by madhuxs View Post
The iNuke manual is quite sad.
Tell me about it
johnson636 is offline
post #782 of 808 Old 06-28-2015, 06:11 PM
Quoted: 13 Post(s)
Liked: 0
are those all just for speaker and sub connections? what the heck are you planning/doing over there? :-)
Leveling the neighbors house haha
Mike dunkle is offline
post #783 of 808 Old 07-10-2015, 07:57 PM - Thread Starter
BassThatHz's Avatar
Quoted: 955 Post(s)
Liked: 777
The new kitchen appliances have just arrived. (So no theater upgrades for a while I guess...)
Even though is says "smudge resistant" I've already had to clean fingerprints off of it, and it's only been 0-days and 0-hours.
Haven't tried the induction elements yet, electrician is coming next week (upgraded from gas stove).
I think I might have to toss most of my pots and pans out, as they aren't induction capable...
ID:	823898   Click image for larger version
ID:	823906   Click image for larger version
ID:	823914   Click image for larger version
BassThatHz is offline
post #784 of 808 Old 07-10-2015, 08:20 PM
Stereodude's Avatar
Quoted: 1699 Post(s)
Liked: 1099
Too bad about the French door fridge. I have one. It's terrible!!! I'd trade it out for a side by side in a heartbeat. The drawer freezer is the worst part. You can't even stand a 32oz Nalgene bottle up in it.
Stereodude is online now
post #785 of 808 Old 07-10-2015, 08:56 PM
popalock's Avatar
Quoted: 1014 Post(s)
Liked: 1395
So, what are you plans for your kitchen appliance upgrades? Maybe throw a coat of epoxy over your the stainless to protect it. It my experience, it's easier to wipe finger prints from epoxy than stainless steel.
popalock is offline
post #786 of 808 Old 07-10-2015, 09:23 PM
coolrda's Avatar
Quoted: 194 Post(s)
Liked: 162
Thats a Manly kitchen. You can't fit a pizza box in a side by side.
Cinema 10 Max Build
Fat Man & Little Boy Build
No Raptors were harmed in the making of these subs
Grandbabies, my chance to make the same mistakes all over again.
coolrda is offline
post #787 of 808 Old 07-11-2015, 05:38 AM
fschris's Avatar
Quoted: 17 Post(s)
I have been looking at fridges. At home depot/lowes etc. I opened every single french door style freezer. I notice a lot of them the handles are bending or loose. Because o f the angle most people will tug at them and what angle they should be pulled on. Some are built better than others. I still could not decide but I like the clean look of a fridge without water dispenser/ice maker.
OP,,,, I like your kitchen cabinets. Nice color.
ASROCK H67 GE / HT/Core i3
Emotiva XPA2 Gen2 x2
Carver AV-705 5Channel AMP
Zaph 2.5MM TT'S DIY
Emotiva UMC 200
2 x MFW 15 Clones DIY
fschris is online now
post #788 of 808 Old 07-11-2015, 07:19 AM
Stereodude's Avatar
Liked: 1099
We haven't had any problem with the handle on our the bottom freezer drawer. It's still nice and secure after almost 8 years but the whole bottom drawer freezer is just a bad idea.
However, as long as you never want to put something in the freezer that has 3 dimensions larger ~7", or is taller than ~7" and needs to be stood up then I guess it's fine.
post #789 of 808 Old 07-11-2015, 02:49 PM
granroth's Avatar
Quoted: 577 Post(s)
Liked: 343
We got an induction stove a few years ago and have never regretted it. Very very nice!
It's not magic, though. I had this odd expectation that it would boil darn near any amount of water in seconds, based on all of the videos I saw beforehand. Turns out that all of the videos were only boiling a cup or so of water. When that goes up to a full stock pot's worth then it still takes an appreciable amount of time. I was very disappointed until I compared that time to the standard electric stovetop and yeah, it's much much faster on the induction top. Just not magic.
Heh, I'm precisely the opposite of you. I had only side-by-side for years and loathed them. They have a lot of theoretical space, but in my family's usage, the amount of practical usage was drastically lower. We moved to a french door model a few years ago and it's been a huge upgrade. The "rated" volume actually went down (got a "cabinet depth" model) but the amount of usable space went way way up.
I love the freezer on the bottom, too, since it can hold so much more stuff.
It's not perfect. Having an upright and shallow freezer did make it easier to access all of the materials. We had a standalone freezer for that for a few years. That was handy. Now we have to dig down for some of the bigger items and that's not fun. But at least it holds the bigger items, something the side-by-side wouldn't do at all.
granroth is offline
post #790 of 808 Old 07-12-2015, 07:10 AM
HFGuy's Avatar
Quoted: 80 Post(s)
Liked: 53
I highly recommend using some of the stainless steel appliance polish. It puts a thin protective coat on the SS, which makes it super easy to clean, which you should do periodically. Make sure to apply this stuff as soon as you buy it (ideally before you get your first finger print).
HFGuy is offline
post #791 of 808 Old 07-12-2015, 10:51 AM
Boomassiv's Avatar
Quoted: 117 Post(s)
Liked: 48
Bar keepers friend is good or SS and most everything else you want to clean around the house.
Boomassiv is offline
post #792 of 808 Old 07-12-2015, 05:21 PM - Thread Starter
BassThatHz's Avatar
Quoted: 955 Post(s)
Liked: 777
Decided to forego the water dispenser for extra room inside. It has an ice maker though (internal).
post #793 of 808 Old 07-12-2015, 05:23 PM - Thread Starter
BassThatHz's Avatar
Quoted: 955 Post(s)
Liked: 777
In my old one you could. But only one box; or crush the boxes with the big milk jug.
post #794 of 808 Old 07-12-2015, 05:27 PM - Thread Starter
BassThatHz's Avatar
Quoted: 955 Post(s)
Liked: 777
I kept the old fridge and put it downstairs, so now I have the best of both worlds.
I also have a fridge in the theater, but that's just for drinks and a few basics.
post #795 of 808 Old 07-12-2015, 06:19 PM
coolrda's Avatar
Quoted: 194 Post(s)
Liked: 162
I'm sorry, I can't live with this lie any longer. Everybody, its not the 48 subs responsible for BTH's outrageous tactile prowess but rather the two large Maytag commercial washers, hiding behind the curtain, running on high spin each loaded with four pairs of wet jeans. What'd you think that big jar of quarters was for?
derrickdj1 likes this.
Cinema 10 Max Build
coolrda is offline
post #796 of 808 Old 07-12-2015, 07:04 PM - Thread Starter
BassThatHz's Avatar
Quoted: 955 Post(s)
Liked: 777
64 commercial washers, hiding behind the curtain, running on high spin each loaded with four pairs of wet jeans.
Now THAT is a rump shaker if I ever did hear of one.
post #797 of 808 Old 07-13-2015, 10:06 AM
More is Better's Avatar
Quoted: 424 Post(s)
Liked: 242
A couple coats of duratex should keep the fingerprints from showing.
Stereodude and popalock like this.
More is Better is offline
post #798 of 808 Old 07-19-2015, 05:38 PM - Thread Starter
BassThatHz's Avatar
Quoted: 955 Post(s)
Liked: 777
OMG...whoever said that a watched pot doesn't boil quickly didn't have an induction stove!
Bubbles start forming within in 5 seconds in afterburner-mode when the pot and top started at room-temp. OMG! (My mind is blown!)
Had to turn it down before it melted a whole in the universe. (Me likes... me likes it a lot!)
Now if I could just get a subwoofer this powerful...
post #799 of 808 Old 07-19-2015, 08:43 PM
coolrda's Avatar
Quoted: 194 Post(s)
Liked: 162
https://www.youtube.com/watch?v=1S7K0G2a4i0
.........Oh, I get it now, its the cooktop. Shoot.......... I thought you just invented the Phaser.
michaelddd likes this.
Cinema 10 Max Build
coolrda is offline
post #800 of 808 Old 07-19-2015, 08:49 PM
Stereodude's Avatar
Liked: 1099
Is this really what we've come to? Worrying about how fast we can boil water?
post #801 of 808 Old 07-20-2015, 03:39 AM
popalock's Avatar
Liked: 1395
popalock is offline
post #802 of 808 Old 07-20-2015, 09:43 AM - Thread Starter
BassThatHz's Avatar
Quoted: 955 Post(s)
Liked: 777
Well, time IS money.
I asked the girls on 1-900-hot-girls and they agreed with me. $9.99 a second... (I think I over paid!) LOL
Money and price is one thing, cost and worth is a whole 'nother level...
post #803 of 808 Old 07-20-2015, 08:04 PM
Electrodynamic's Avatar
Quoted: 163 Post(s)
Liked: 243
LMAO!!! HAHAHA! Great post Austin. Totally caught me by surprise, haha.
Electrodynamic is offline
post #804 of 808 Old 07-20-2015, 09:03 PM
Quoted: 424 Post(s)
Liked: 242
Because you're all about that?
Stereodude likes this.
post #805 of 808 Old Today, 09:36 AM
Steve Crowley's Avatar
Liked: 24
Nevrdull is a great polish. Used it in the Air Force to clean brass measuring weights in PMEL. Comes in a tin and it is just wadding with cleaner in it. Use a coffee filter to remove it as they do not have lint.
Klipsch so much it Hz
Steve Crowley is online now
post #806 of 808 Old Today, 10:14 AM
Bass Enabler
Scott Simonian's Avatar
Quoted: 2199 Post(s)
Liked: 1836
Haha! Beat me to the punch.
Dat high end roll off, son.
My Dual 18" LLT subs 120dB down to 10hz ***FOR SALE***
Plan9Reloaded Co-host
Listen to the Plan9Reloaded Gaming and Technology Podcast (may contain NSFW language)
https://soundcloud.com/plan9reloaded/sets/podcast - direct pod link
http://plan9reloaded.com/site/ - main website
Scott Simonian is offline
post #807 of 808 Unread Today, 07:17 PM
fschris's Avatar
Quoted: 17 Post(s)
wow we used to send our Test set T-berd 224 , t-berd 6000 to PMEL. I was Comm in the AF.
Zaph 2.5MM TT'S DIY
Emotiva UMC 200
post #808 of 808 Unread Today, 07:50 PM
Liked: 24
I calibrated that while I was stationed in the Azores at Lajes Field and Ellsworth AFB in South Dakota.
Nevrdull is the best metal polish I have found as it does chrome better than all of the commercially available product.
PMEL is not very well known to the public as a lot of the instruments we used and calibrated were classified. Most of the people I worked with all had BSEE's with some with Masters. None of us wanted to be officers as we would have to do paperwork. lol
