Transmission Line Isobaric Subwoofer for home. - Page 2 - AVS Forum
post #31 of 41 Old 10-14-2013, 10:14 PM
LTD02's Avatar
Quoted: 233 Post(s)
Liked: 948
for isobaric, the parameters change. how they change depends on whether you go parallel wiring or series wiring. i'm not sure if you get a different result in hornresp either way.
for isobaric drivers in SERIES:
motor force doubles. but motor force is bl^/2, so twice that value means bl increases by root 2 (1.414) all other things equal.
re doubles.
sd is just the sd of a single driver, so stays the same.
cms is the suspension compliance, so it gets reduced by 50% with two drivers. twice the suspension, twice as stiff. compliance is opposite of stiff.
rms doubles.
le doubles.
normally, all of this results in a dramatic reduction in sensitivity (6db :-0 ), but preserves the same frequency response shape of a single driver in a cab twice as large.
not sure what the result will be in hornresp. could be better. could be worse.
good luck and interesting experiment!
something like this would seem like a real winner for a pair of inexpensive, weak motored, assymetrical bl field, drivers with lots of excursion that otherwise wouldn't work in a horn loaded environment.
Gaugster likes this.
Listen. It's All Good.
LTD02 is online now
post #32 of 41 Old 10-14-2013, 10:35 PM
LTD02's Avatar
Quoted: 233 Post(s)
Liked: 948
not sure why I get totally different results than you do with the basic model in hornresp.
-25cm seems about right for the combination.
otherwise, the two look totally different.
I was going to confirm our hornresp models before then changing up the t/s parameters for isobaric loading, but can't even confirm the basic model.
LTD02 is online now
post #33 of 41 Old 10-14-2013, 10:47 PM
LTD02's Avatar
Quoted: 233 Post(s)
Liked: 948
doesn't seem to correlate with your measurements too well though. :-(
LTD02 is online now
post #34 of 41 Old 10-15-2013, 10:10 AM - Thread Starter
Gaugster's Avatar
Quoted: 29 Post(s)
Thanks for the feedback. I will post my txt file later which may help to match up the two simulation. I too will adjust the speaker parameters but for parallel isobaric and see what difference it makes.
I have to reselect 2p each time I open the program even after I import. So should be more convenient in the long run.
Gaugster
Gaugster is offline
post #35 of 41 Old 10-15-2013, 05:38 PM - Thread Starter
Gaugster's Avatar
Quoted: 29 Post(s)
Here is the output parameter files. The only difference I can see is that you used a 2P where as I used a 2p. Doubt it would be case sensitive but maybe the way the pop up features were calculated???
ID=29.00
Ang=1.0 x Pi
Eg=2.83
Rg=0.01
Fta=0.00
S1=1650.00
S2=750.00
Con=61.60
F12=0.00
S2=750.00
S3=250.00
Con=64.60
F23=0.00
S3=250.00
S4=500.00
Con=66.10
F34=0.00
S4=500.00
S5=500.00
Con=47.50
F45=0.00
Sd=506.00
Bl=10.23
Cms=4.86E-04
Rms=3.22
Mmd=51.35
Le=2.40
Re=7.00
Nd=2p
Vrc=0.00
Lrc=0.00
Fr=0.00
Tal=0.00
Vtc=0.00
Atc=0.00
Pmax=250
Xmax=8.0
Comment=12W1-8 Measured T&S parameters. IsoTL
Gaugster
Gaugster is offline
post #36 of 41 Old 10-15-2013, 06:36 PM
LTD02's Avatar
Quoted: 233 Post(s)
Liked: 948
must be a bug. i'm running v28. you have v29.
i'm getting the same thing with your numbers that i posted last night. eek.gif
that said, it was worth doing because i learned why scoops aren't more popular than they are. eek.gif
LTD02 is online now
post #37 of 41 Old 10-15-2013, 06:50 PM - Thread Starter
Gaugster's Avatar
Quoted: 29 Post(s)
I converted all the speaker inputs to a parallel isobaric configuration based on what I think they should be. Result was the same as my previous trial.
Sd remains the same. (This was one reason why i went this route to keep the enclosure size smaller)
Vas is 50% - Combined isobaric speaker has twice the moving mass, half the compliance because of the doubled suspension. This changed Cms in Hornresp.
Re is 3.5 Ohms as each speaker measures 7 ohms individually.
Bl remained the same. It is using Cms and Re so it seems the adjustments I made offset each other. I used the same Qes value as previous sims.
Rms doubled. Again it is based on Cms. I used the same Qms value as previous sims.
Le is 50% for two inductors in parallel.
Nd is default. I.e. 1 speaker - normal configuration.
Gaugster
Gaugster is offline
post #38 of 41 Old 10-15-2013, 06:54 PM - Thread Starter
Gaugster's Avatar
Quoted: 29 Post(s)
Could be a bug? idk but thanks for checking into it.
Gaugster
Gaugster is offline
post #39 of 41 Old 10-15-2013, 07:04 PM
LTD02's Avatar
Quoted: 233 Post(s)
Liked: 948
roughly the same idea as what you have.
LTD02 is online now
post #40 of 41 Old 11-27-2013, 04:14 AM
JohannesAnd's Avatar
Hi Gaugster
Must say this is a great design.
Many years ago i built a isobaric small bass reflex subwoofer with two 8" woofers to my 5.1 system.
This was scrapped and the woofers was put in the storage.
Last week I was looking around the web trying to find some idéas for a horn or TL subwoofer and reuse the speakers.
That's when i found this nice forum and project.
I used the Peerless CSH217 8 ohm woofers and design similar to your. Outside measurements approx 700*300*420 (H*W*D)
I'm surprised by the deep bass it produces, and the first test was very impressive. :)
I want to complete with 2 horn/bass reflex hybrid design speakers with fostex FE126En for a 2.1 setup.
BR
Johannes
JohannesAnd is offline
post #41 of 41 Old 11-27-2013, 04:21 PM - Thread Starter
Gaugster's Avatar
Quoted: 29 Post(s)
This Forum is a great place for inspiration! The low bass response has inspired me to get a calibration software / setup to document my results.... a work in progress!
Ps - Thank You!.
Gaugster
Gaugster is offline
User Tag List
