Transmission Line Isobaric Subwoofer for home. - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 6Likes
post #61 of 64 Old 01-05-2015, 05:17 AM - Thread Starter
Gaugster's Avatar
Quoted: 63 Post(s)
Liked: 56
I have some 2 ply birch veneer. Check out post #28.
The new sub fits but with only a mm or so to spare. Same for my orbital sander. It is very much a miracle. I sized the opening bigger so that I had more room knowing that modern subs have larger motor/magnet assemblies.
Gaugster is offline
post #62 of 64 Old 01-17-2015, 06:30 PM - Thread Starter
Gaugster's Avatar
Quoted: 63 Post(s)
Liked: 56
Some more progress on the finish..... Looking Great.....
Have to paint over the edges and some finishing touches.....
ID:	485305   Click image for larger version
ID:	485313   Click image for larger version
ID:	485321   Click image for larger version
Gaugster
Gaugster is offline
post #63 of 64 Old 01-18-2015, 06:27 PM - Thread Starter
Gaugster's Avatar
Quoted: 63 Post(s)
Liked: 56
Took a lot of will power not to bolt on the amp and fire it up. But some tedious task need to be done otherwise this thing might never be "complete".
Paper thin clearance but the speaker fits.
ID:	487090   Click image for larger version
ID:	487098   Click image for larger version
ID:	487106   Click image for larger version
ID:	487114   Click image for larger version
Gaugster
Gaugster is offline
post #64 of 64 Old 01-26-2015, 06:53 PM - Thread Starter
Gaugster's Avatar
Quoted: 63 Post(s)
Liked: 56
Did some REW sweeps over the weekend. Using a UMM-6 with a Cross-Spectrum calibration.
Mic was in a stand and measured at multiple locations across the couch. Distance is over 4 meters from the transmission line subwoofer.
Have some notches centered around 56Hz and 84Hz. These might be room modes. Planning to play with the speakers to see if I can push those notches around.
My other two subs help make the 56Hz notch less. Have to mess with the mid range speakers to see what can be done with 84Hz dip.
Gaugster
Gaugster is offline
