Bought Energy Veritas mains and center. Need a sub and amp to DIY. Taking suggestions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 11-12-2012, 01:00 PM - Thread Starter
Fade to Black's Avatar
I pulled a trigger and purchased Energy Veritas 6.2 mains along with a 5.2 center. These will be driven by a Denon 2112CI. I have the skills and the tools needed to build a DIY sub. I come here for advice on which driver and an amp to pick up to match the Energy speakers.
The output will be roughly 50/50 HT and 2.0 music. I want a sealed setup for the sub.
Initial sub chiice is one 15 inch Dayton Titanic Mk III from parts express 800 watts RMS @ 4 ohm http://www.parts-express.com/pe/pshowdetl.cfm?&Partnumber=295-420&scqty=1
For the amp I choose Crown XLS 1500 amp http://www.parts-express.com/pe/pshowdetl.cfm?&Partnumber=245-502&scqty=1. Will I run into any issues using a pro amp for a HT application? Any special cables or adapters? I figure with this amp I will also have headroom.
Price for the 2 is $600 from parts express. This is roughly my budget, which can be upped if I get a significant performance upgrade.
With that said is this a good combo? I'm open for tips/advice/suggestions for everything: (amp, driver(s), planning, install)
Fade to Black is offline
post #2 of 8 Old 11-12-2012, 01:52 PM
LTD02's Avatar
Quoted: 2341 Post(s)
Liked: 2578
sealed subs tend to need some eq to bring up the lower end.
one budget amp with dsp is the behringer inuke3000dsp. 620 real watts per channel at 4 ohms. easy to use and very flexible eq is built in.
an alternative driver is the rss460ho 18". works well in 3.5-4.0 cubic feet sealed. ricci put one on the bench, usable excursion to 20mm. triple shorting rings. decent looking.
a little over your budget for one sub, but the upgrade path is in place for the second sub (only need to buy the driver) and everybody doubles down. :-)
Listen. It's All Good.
LTD02 is offline
post #3 of 8 Old 11-12-2012, 02:45 PM - Thread Starter
Thanks! Parts express folks seem to love those Titanic subs.Did you recommend the 18 incher due to more cone area? I dig the amp and its EQ. Would it be safe to run 1 sub in bridged 4 ohm mono? Is that too much power? Alternatively, is it safe to run that amp in 4 ohm stereo with the second channel unoccupied (only 1 sub). I apologize if these are obvious noob questions.
post #4 of 8 Old 11-12-2012, 03:12 PM
LTD02's Avatar
Liked: 2578
"Thanks! Parts express folks seem to love those Titanic subs.Did you recommend the 18 incher due to more cone area?"
the 460 will probably sound a hair better on the top end with its higher sensitivity and better inductance control. it will also have higher low end spl because it can move more total air.
"I dig the amp and its EQ. Would it be safe to run 1 sub in bridged 4 ohm mono? Is that too much power?"
it should be fine, so long as you don't get stupid running 10hz sine waves through it in free air.
edit: you can also limit the voltage in the dsp in order to prevent putting too much power through your driver.
one per channel is very safe power, almost underpowered. i was just suggesting a conservative approach.
"Alternatively, is it safe to run that amp in 4 ohm stereo with the second channel unoccupied (only 1 sub)."
yes it is safe. our preference for symmetry causes lots of folks to ask this question, but this is one place where our intuition fails us.
"I apologize if these are obvious noob questions."
no worries. questions are questions. the foolish thing would be not to ask.
LTD02 is offline
post #5 of 8 Old 11-12-2012, 04:16 PM
Point Source
beastaudio's Avatar
Quoted: 3519 Post(s)
Liked: 2835
I'll ocmment in on the XLS1500 if you go that route. The Drivecore series all have the ability to accept RCA and XLR, so no need for adapters. The Drivecore is also perfect as it's input sensitivity is able to handle readily the pro/consumer argument. I ran a 1500 and a 2000 for some time and loved them. I am actually looking at another couple drivecores to replace my XPA-5 to gain the available gain controls I lack right now. truly wonderful amps, but as LTD suggested the Behringer is a wonderful piece of equipment and the onboard EQ is an added plus for sure.
beastaudio is online now
post #6 of 8 Old 11-13-2012, 12:50 PM - Thread Starter
I did more research on using pro audio gear in HT and got a little discouraged reading the various discussions about the voltage differences and whatnot. Little disappointed, as I really wanted a pro amp, but at this point I don't want to spend more time researching how to properly use/tweak this pro audio gear for HT. With that said I bought a Dayton 1000 watt plate amp, and bought LTD02's recommendation on that Dayton 18 inch RSS460 HO.
I usually forget to take pictures of my work, but I may post a build log. This will be my first sub build. This is also my first HT upgrade in a decade. I'm very excited about my system, which will be arriving throughout this and next week smile.gif
Denon 2112CI receiver
Energy Veritas 5.2 center
Dayton RSS466 HO 18 inch sub (sealed build)
Dayton 1000 watt sub amp
I may use use my old Fluance speakers for surrounds
post #7 of 8 Old 11-13-2012, 02:34 PM
Point Source
beastaudio's Avatar
Liked: 2835
That was kind of what I was alluding to above with the drivecore series and their ability to do very well with consumer gear. Nonetheless, the plate amp you got will work just fine.
post #8 of 8 Old 11-14-2012, 06:01 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 176
I personally think that Dayton 1000 watt plate amp will work great for that Dayton 18HO! Keep us updated on the build, I can't wait to hear how it sounds.
Martycool007 is offline
